[Ovmsdev] Double updates - Normal?
Tamás Kovács
kommykt at gmail.com
Thu Jan 30 20:00:11 HKT 2020
Some time the m.version not set on Mitsubishi i-Miev .
2020. január 30., csütörtök dátummal Thomas Heuer <egon at heuer-humfeld.de>
ezt írta:
> The issue was on boot, the events: SignalEvent: queue overflow, event
> 'system.start' dropped in some case.
> the problem was the egpio settings in OvmsVehicleSmartED::ConfigChanged(OvmsConfigParam*
> param)
> https://github.com/Dimitrie78/Open-Vehicle-Monitoring-System-3/commit/
> 21e1a0339c029adf5c746dfd6fecddbc9455a947#diff-
> 9106f33dff1f6160884b2e78d145607fL155-L160
> line 155 – 160
> *Von:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im Auftrag von *Mark
> Webb-Johnson
> *Gesendet:* Donnerstag, 30. Januar 2020 11:35
> *An:* OVMS Developers <ovmsdev at lists.openvehicles.com>
> *Betreff:* Re: [Ovmsdev] Double updates - Normal?
> Just had a thought.
> Events used to be synchronous, but we switched to deliver in a different
> task. Maybe the startup sequence relies on that in some way.
> On 30 Jan 2020, at 6:32 PM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> Seems identical. The changes don’t seem to affect the dispatch of the
> system.start event.
> I think it must be a race condition.
> Mark
> On 30 Jan 2020, at 5:56 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> a similar issue was happening on some Smart ED and fixed by Dimitrie later
> on:
> https://github.com/openvehicles/Open-Vehicle-
> Monitoring-System-3/issues/293
> I thought that was a Smart specific issue, maybe I was wrong.
> Am 30.01.20 um 06:17 schrieb Mark Webb-Johnson:
> Still stumped…
> The OTA code doesn’t call GetOVMSVersion(), but instead just looks
> at StandardMetrics.ms_m_version (which we know is blank). That is why
> this is happening.
> But why is StandardMetrics.ms_m_version empty (as is the hardware value
> as well).
> The ovms_version code hooks into ’system.start’ event, and sets the
> version and hardware metrics. So, obviously that is not being called. That
> event is raised just after ’Starting USB console…”. The event is also
> listened to be ovms_time, ovms_mdns, and swcan.
> MDNS outputs “Starting MDNS” when it sees that. The ovms_time sets the
> environment variable TZ. Your car is showing:
> ovms> time status
> Vehicle Response:
> Time Zone: Not defined
> UTC Time: 2020-01-30 05:00:53 UTC
> Local Time: 2020-01-30 05:00:53 GMT
> Provider: None
> So looks like TZ is not being set. Presumably that means the call is not
> happening. I had a look at the ovms_events code, but can’t find anything
> obvious.
> So, tried a hacky test:
> ovms> metric list version
> Vehicle Response:
> m.version
> ovms> event raise system.start
> Vehicle Response:
> Raising event: system.start
> Vehicle Response:
> m.version 3.2.008-121-g4c6c9fe/ota_0/edge
> (build idf v3.3-beta3-775-gdc1ca69 Jan 29 2020 00:00:52)
> ovms> ota status
> Vehicle Response:
> Firmware: 3.2.008-121-g4c6c9fe/ota_0/edge (build idf
> Running partition: ota_0
> Boot partition: ota_0
> Factory image: 3.1.001
> OTA_O image: 3.2.008-121-g4c6c9fe
> OTA_1 image: 3.2.008-121-g4c6c9fe
> Server Available: 3.2.008-121-g4c6c9fe (no update required)
> Can you try to boot from USB (module reset) and provide the serial boot
> log? Particularly around the lines ’Starting USB console’.
> Maybe a race condition at startup, or some other issue delivering events
> early on?
> Only other thing I see are some scripts on /store/events regarding vehicle
> on/off - perhaps you can try disabling those to see if they trigger the
> issue? I tried recreating them on my box, but couldn’t repeat your problem.
> On 30 Jan 2020, at 11:55 AM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> Greg,
> It seems your car can’t pickup currently running firmware version:
> ovms> open ROADSTER834B
> Connected and logged in to ROADSTER834B
> Vehicle Response:
> m.version
> By comparison, here’s mine:
> Vehicle Response:
> m.version 3.2.008-121-g4c6c9fe/ota_1/edge
> ovms> ota status
> Vehicle Response:
> Firmware: 3.2.008-121-g4c6c9fe/ota_1/edge (build idf
> Running partition: ota_1
> Boot partition: ota_1
> Factory image: 3.2.002
> OTA_O image: 3.2.008-120-gcfb7864
> Your m.hardware metric is also blank.
> I’ll keep looking, but at the moment this seems bizarre.
> On 30 Jan 2020, at 11:21 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi Mark, Michael,
> Seems like what is happening is that the module keeps thinking a new
> update is available. Today was especially active for some reason.
> Screenshot of the Android application's log screen, attached. All
> versions appear to be the same. The car has simply been sitting in the
> garage on WiFi; no transitions of network access.
> Output of 'ota status' attached as well.
> Sorry, but I don't appear to have logging enabled. What specifically
> would you like logged?
> Greg
> Mark Webb-Johnson wrote:
> Not normal. Can you send us the logs. Also the output of ‘ota status’
> would be helpful.
> Are you sure this isn't just a notification of the update, and is the
> update itself? Perhaps a screenshot of the double notifications you receive?
> On 25 Jan 2020, at 11:35 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi folks,
> I moved my car's OVMSv3 to the Edge firmware a bit ago, and notice that
> every update seems to be doubled. Besides being a bit annoying, it ends
> up without a previous version to fall back to since both partitions end
> up being the same.
> Is this behavior normal? Can it be prevented?
> I'm only on Edge because of the bug in obd2ecu, and will probably move
> to EAP after we get an EAP build with the fix in it. Is the behavior
> the same there?
> I used to be on Main, and all seemed fine there.
> Thanks,
> Greg
> <Repeated updates.png><Repeated updates ota status
> output.txt>_______________________________________________
> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal <https://www.google.com/maps/search/Helkenberger+Weg+9+*+D-58256+Ennepetal?entry=gmail&source=g>
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200130/0a529507/attachment-0001.html>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200130/0a529507/attachment-0001.png>
