[Ovmsdev] Cannot reset simcom stuck in PoweringOn state without removing module power
    Craig Leres
    leres at xse.com
    Sun Jan  5 12:16:28 HKT 2020
The simcom on one of my modules wedged today and had some time to poke
at it. When I turn on simcom debugging I see "AT" commands once a second:
     D (1199981) simcom: tx scmd ch=0 len=4   : AT
     D (1200981) simcom: tx scmd ch=0 len=4   : AT
but no responses.
I wanted to see if I could talk to the simcom via the usb connector on
the modem card so I sacrificed a micro usb cable and hacked the molded
end off so I could plug it in without detaching the modem board from the
main board (see attached).
Next I spent a few minutes with a spare module looking for a windows 10
driver. The sim5360 (rar) archive from techship.com didn't work but the
windows 8 zip file from here did:
https://github.com/botletics/SIM7000-LTE-Shield/tree/master/SIM7000%20Documentation/Drivers
I ended up with four com ports (at, nema, diagnostic, and audio) and was
able to talk to the spare modem.
Then I went out to plug into the simcom in the car. The first thing I
noticed was that the blue led on the modem board is not lit and (as
expected) I got nothing from the at com port.
For completeness I tried rebooting the module but it help.
I now believe wedging the simcom involves running the car for a short
amount of time. In this particular case I moved the car out of the
garage to make room for some work on my other car. An hour later I moved
it back. The run time was 1-2 minutes each time. A bit later when I
tested Mark's new ios app I noticed that the car was not reporting a
location.
I looked at the simcom docs a bit and it's too bad the simcom RESET pin
isn't connected to a pio pin.
It'll be a couple of days before I'll need the gps to work in case there
are ideas of what can be done via software to wake up the simcom. I
might trying add a simcom command to set PWKEY to an arbitrary state to
see if holding it low for more than one second does anything.
		Craig
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200104/1afc6f42/attachment-0001.jpg>
