[Ovmsdev] Anyone using HTTP API?
Thu Feb 20 11:09:47 HKT 2020
Even stranger. This conversation obviously triggered someone to try it and then raise a support ticket that HTTP API authentication didn’t work.
It seems  a change was made back in 2016-02-01 23:59:22 (1b73a7f8) that broke the pw_encode function (drupal_password). It was also weird because we had drupal_password and drupal_password_check functions, doing pretty much the same thing (one used by HTTP API and the other by MQ authentication).
I standardised to use a new pw_check (overridable in the config) parameter, which defaults to:
drupal_password_check($passwordhash,$password)
and stopped using the pw_encode config value. I also changed the MQ authentication stuff to use the same pw_check parameter (so both authentication uses are now able to be changed in the same config). If using something other than drupal, just need to change the pw_check parameter in the config.
I realise that this may break other users of the server, but it doesn’t seem a difficult fix to make, and is a much better approach.
> On 19 Feb 2020, at 1:53 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Strange. I have zero using mine. Must be a EU thing?
> I’ll keep it in mind and try not to break anything.
>> On 18 Feb 2020, at 8:41 PM, Michael Balzer <dexter at expeedo.de> wrote:
>> Mark,
>> grep "main: http" in the log: yes, I've got some users accessing the API frequently.
>> Usage is mostly /api/charge followed by /api/status & /api/historical, but almost all calls have been used during the last days.
>> Am 18.02.20 um 04:28 schrieb Mark Webb-Johnson:
>>> Is anyone here using the HTTP API at all?
>>> It seems so tied to the v2 protocol, as to not be much use.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200220/70509f0d/attachment.htm>
