[Ovmsdev] Reverse connections (module -> developer)
Mon Feb 10 14:24:58 HKT 2020
I guess the limiting factor to be the WolfSSH speed in the module. Probably far slower than a server/workstation. But then again, perhaps the SSL overhead would be equally as bad. Once I’ve got SSL running we can compare OTA over HTTPS vs HTTP to see.
> On 10 Feb 2020, at 2:01 PM, Stephen Casner <casner at acm.org> wrote:
>> I am also concerned about performance. For console access, that
>> shouldn’t matter - but for can bus dumps we need every bps of speed
>> we can get.
> Assuming some reasonable server machine, I would not expect that to be
> the bottleneck.  My guess is the limiting factor would be the
> networking software in OVMS.
