[Ovmsdev] OVMS v3 v3.2.010 Release to Early Access Program
Tue Feb 4 02:38:22 HKT 2020
Done.
Am 03.02.20 um 04:22 schrieb Mark Webb-Johnson:
> @Michael: Please release on your EU server when you have time…
> Today, we are pleased to release v3.2.010 to Early Access Program. A summary of the major changes is here:
> 2020-02-03 MWJ  3.2.010 OTA release
> - EGPIO: address multiple ports by input & output command
> - SmartED: issue #293 fixed
>   change savestatus from store to sd
>   Add ecoscore system to drive report and web interface like defunct
>   smart web app. (added by frantek)
> - New command: "vfs df" -- show disk usage
> - Scripting API: added VFS.Load() & VFS.Save()
> - Scripting API: renamed HTTP.request() to HTTP.Request() for consistency
> - Scripting API: added OvmsMetrics.GetValues()
> - Web UI: editor extended by embedded Javascript evaluation
> - Webserver: /api/execute: support for Javascript evaluation
> - Scripting API: added OvmsConfig.GetValues() & OvmsConfig.SetValues()
> - Config: added dedicated "usr" param for plugin configurations
> - Scripting API: HTTP.request() added
> - SmartED: add BMS diagnose report
>   New commands:
>     xse rptdata     get a Battery Status Report
>     xse bmsdiag     get Battery Diagnose Report
> - #225 Fix charge duration display in iOS App
> - #228 AutoFlashSD cleanup ovms3.done before rename
> - #293 Event queue overflow on startup
> - #299 Fix Tesla Roadster vehicle type for 2012 cars
> - #328 Tesla Roadster: Vehicle AWAKE metric not correct
> For full detail on all changes, check the GitHub revision history. The v3 modules can be updated over the air (wifi), via SD CARD, or over USB - all without
> requiring special hardware programmers like the PICKIT used for v2. The simplest way to update the module firmware is to connect it as a client to your wifi
> network (or phone hotspot), and then use the web interface Config / Firmware / Flash-from-Web; that will show you the version you are running, as well as the
> latest version available for update. One click on 'Flash now' and the update will be downloaded and installed. Alternatively, you can download the firmware
> update to a file named ovms3.bin in the root directory of a FAT formatted SD CARD and insert the card into the module's slot - the new firmware will be
> updated automatically and the file renamed ovms3.done to signify completion. This firmware also includes the feature to check for and automatically update to
> newly available firmware, every night (so long as the vehicle is connected to WiFi). After updating to 3.1.005 or later, you can enable this for future
> firmware releases with 'config ota auto yes'.
> You can choose the release level by setting 'config ota tag edge | eap | main', as one of:
>   * edge: Bleeding edge developer nightly-builds
>   * eap: Early Access Program (full releases, but with little public testing)
>   * main: Publicly tested full releases (the most stable)
> Thank you to all the open source developers who have contributed to this, and previous, releases, and thank you for your support of the project.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200203/d9096dc3/attachment.htm>
