[Ovmsdev] Ready for 3.2.009
Mon Feb 3 08:24:35 HKT 2020
Greg,
On the server I am seeing you running 3.2.008-134-ge6ac0c7/ota_0/edge and all the data looks fine. For example:
ovms> metric list v.b
Vehicle Response:
  v.b.12v.voltage                          13.04V
  v.b.12v.voltage.ref                      12.6V
  v.b.cac                                  136.777Ah
  v.b.consumption                          0Wh/km
  v.b.current                              1A
  v.b.health                               CAC 136.78Ah SOC 94% LIM 83% MIN 83% MAX 85%
  v.b.p.level.max                          85%
  v.b.p.level.min                          83%
  v.b.power                                0.3985kW
  v.b.range.est                            196.339km
  v.b.range.ideal                          255.885km
  v.b.soc                                  95%
  v.b.soh                                  82.9213%
ovms> metric list v.c
Vehicle Response:
  v.c.charging                             no
  v.c.climit                               24A
  v.c.current                              0A
  v.c.duration.full                        14Min
  v.c.kwh                                  9kWh
  v.c.mode                                 standard
  v.c.pilot                                yes
  v.c.state                                done
  v.c.substate                             powerwait
  v.c.time                                 0Sec
  v.c.voltage                              0V
The temperature bug for Roadster is a known issue, and is fixed in 4082bb2a (and released in 3.2.009).
I triggered an update for you (to 3.2.009-1-g92cc5ed), and that installed ok. I’ll try to find out if the temperature bug is fixed now or not.
> On 3 Feb 2020, at 5:08 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Um, I just noticed that all the metrics except for the 12v battery
> voltage are zero.  The car is awake and charging right now, but hasn't
> been driven since the software update to 3.2.008-134-ge6ac0c7, if that
> matters.  I believe the TPMS metrics don't update until it's driven, but
> I should be seeing the temps.  All gray and zero.
> I tried putting the car in Drive (just sitting there), and the TPMS data
> came on after a few minutes.  But the rest of the metrics are still zero
> and gray.
> The VDS shows the correct temps, and is operating normally.
> Oops?
> Greg
> Greg D. wrote:
>> My module updated to 3.2.008-134-ge6ac0c7 last night (2am local), and
>> did the single update as it should.  m.version is consistent with this.
>> The module sees your 3.2.009-1-g92cc5ed as available.  Presume it will
>> update tonight.
>> So, all "go" from this console.
>> Greg
>> Mark Webb-Johnson wrote:
>>> I’ve tagged 3.2.009 based on where we are today, and built on my edge.
>>> If no problems reported overnight, I’ll push to EAP tomorrow.
>>>> On 2 Feb 2020, at 6:21 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Am 02.02.20 um 02:13 schrieb Mark Webb-Johnson:
>>>>> Seems we are ready for another release. I made a number of fixes yesterday, and maybe able to make a few more today, then I am done and ready to release 3.2.009.
>>>>> Anything else to put in this?
>>>> OK, nothing open here.
>>>> Regards,
>>>> Michael
>>>>> Regards, Mark
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200203/c5793ef7/attachment.htm>
