[Ovmsdev] SSL Support
Fri Feb 14 06:25:10 HKT 2020
Mark,
something's wrong now with the Mongoose SSL support. I could do this javascript call before (example from scripting API doc):
HTTP.Request({
url: "https://dexters-web.de/f/test.json",
always: function() { JSON.print(this, false); }
This now no longer works, neither with the previous opts.ssl_ca_cert = "*":
E (37350) mongoose: mg_ssl_if_mbed_err 0x3f85befc SSL error: -17040
I (37410) script: [eval:3:] {"url":"https://dexters-web.de/f/test.json","always":function () { [ecmascript code] },"redirectCount":0,"error":"SSL error"}
…nor with opts.ssl_ca_cert = MyOvmsTLS.GetTrustedList(), it then sometimes fails with…
{"url":"https://dexters-web.de/f/test.json","always":function () { [ecmascript code] },"redirectCount":0,"error":"Failed to create SSL session"}
…but mostly causes some kind of lockup (USB console not responding) and / or wifi / mongoose restart:
I (55980) wifi: bcn_timout,ap_probe_send_start
I (58480) wifi: ap_probe_send over, resett wifi status to disassoc
I (58480) wifi: state: run -> init (c800)
I (58490) wifi: pm stop, total sleep time: 35296441 us / 53655320 us
I (58490) wifi: new:<11,0>, old:<11,2>, ap:<11,2>, sta:<11,0>, prof:11
E (58490) mongoose: mg_ssl_if_mbed_err 0x3f85dd64 SSL error: -1
D (58520) events: Signal(server.web.socket.closed)
I (58580) script: [eval:3:] {"url":"https://dexters-web.de/f/test.json","always":function () { [ecmascript code] },"redirectCount":0,"error":"SSL error"}
W (58600) wifi: Haven't to connect to a suitable AP now!
W (58630) wifi: Haven't to connect to a suitable AP now!
W (58640) wifi: Haven't to connect to a suitable AP now!
W (58660) wifi: Haven't to connect to a suitable AP now!
W (58680) wifi: Haven't to connect to a suitable AP now!
W (58700) wifi: Haven't to connect to a suitable AP now!
W (58720) wifi: Haven't to connect to a suitable AP now!
W (58740) wifi: Haven't to connect to a suitable AP now!
D (58770) events: Signal(system.event)
D (58780) events: Signal(system.wifi.sta.disconnected)
I've seen you set opts.ssl_server_name in server V2 & V3. This could be left NULL for using the hostname before, is it now necessary to set this?
Am 13.02.20 um 08:26 schrieb Mark Webb-Johnson:
> And #2 now done. To add to the trusted CA list we can now add the CA into firmware (like the 3 already there), or put the PEM formatted certificate in
> /store/trustedca on the module itself. A set of commands (like ’tls trusted reload’, ’tls trusted list’, etc) are also now provided to help management.
> I’ve also added a short document to the user guide to explain this.
>> On 12 Feb 2020, at 3:25 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> I managed to get quite a lot done last night, and just committed my changes. Current status:
>> #1 is done. An extension had to be made to mongoose to support this, so please update submodules. I’ve added the trusted CAs for openvehicles, dexters
>> (letsencrypt) and pushover.
>> #3 is done. A couple of lines of code. It is enabled by ‘config set server.v2 tls yes’.
>> #4 is done. A couple of lines of code. It is enabled by ‘config set server.v3 tls yes’.
>> #5 is done, and live on api.openvehicles.com <http://api.openvehicles.com/>.
>> #8 can start when ready. Have a look at the ovms_server_v[23] code for an example - it is literally a couple of lines to be added.
>> I did find a few servers that didn’t support the segment size negotiation option in SSL that we were relying on (including mosquitto!). So had to change my
>> sdkconfig to:
>> CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
>> I suggest you do the same for best compatibility.
>> The rest is pending. I will work on #2 next, then move on to the iOS App.
>>> On 10 Feb 2020, at 11:24 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>> Given that we use the mongoose library for most of our stuff, adding SSL support should not be hard. This would finally bring strong encryption and server
>>> side authentication. Given the number of attacks now on IoT devices that would not be a bad thing.
>>> I think what we need is:
>>> 1. A set of helper functions to make it easier for components to use SSL. Build on top of mongoose.
>>> 2. A way to manage a list of trusted Certificate Authorities, including adding to the trusted list via:
>>> * Components providing Certificate Authorities in firmware.
>>> * Certificate Authorities in configuration.
>>> 3. Extensions to ovms_server_v2 to support an SSL connection option.
>>> 4. Extensions to ovms_server_v3 to support an SSL connection option.
>>> 5. Extensions to the Ovms Server v2 code to support an SSL connection listener.
>>> 6. Extensions to the iOS App to support an SSL connection option.
>>> 7. Extensions to the Android App to support an SSL connection option.
>>> 8. Migration of any components already supporting SSL to this new standardised approach.
>>> 9. Then we can open up the discussion of the whole thing of passwords. We have far too many of these at the moment (user account+password, vehicle ID,
>>> server password, module password, hologram account+password, etc). Once we have an encrypted connection, we don’t need to use the password for
>>> encryption, but merely for authentication. That simplifies things, as we can perhaps just use the user account+password for most things (giving access
>>> to all vehicles registered under that user account - in a similar way to MQTT does it already for ovms_server_v3).
>>> I will take on the majority of this project. I can do #1, #2, #3, #4, #5, and #6).
>>> If anyone has any feedback on requirements, please let me know.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200213/65e0bf29/attachment.html>
