[Ovmsdev] Ready for 3.2.009
Greg D
gregd2350 at gmail.com
Mon Feb 3 10:49:25 HKT 2020
Hi Mark,
Saw the update Metrics look good now. What changed?
The module is reporting another update is pending for tonight. 3.2.009-2-g39cdb7e. Same version number...
Greg
On February 2, 2020 4:24:35 PM PST, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>Greg,
>On the server I am seeing you running 3.2.008-134-ge6ac0c7/ota_0/edge
>and all the data looks fine. For example:
>ovms> metric list v.b
>Vehicle Response:
> v.b.12v.voltage 13.04V
> v.b.12v.voltage.ref 12.6V
> v.b.cac 136.777Ah
> v.b.consumption 0Wh/km
> v.b.current 1A
>v.b.health CAC 136.78Ah SOC 94% LIM 83%
>MIN 83% MAX 85%
> v.b.p.level.max 85%
> v.b.p.level.min 83%
> v.b.power 0.3985kW
> v.b.range.est 196.339km
> v.b.range.ideal 255.885km
> v.b.soc 95%
> v.b.soh 82.9213%
>ovms> metric list v.c
>Vehicle Response:
> v.c.charging no
> v.c.climit 24A
> v.c.current 0A
> v.c.duration.full 14Min
> v.c.kwh 9kWh
> v.c.mode standard
> v.c.pilot yes
> v.c.state done
> v.c.substate powerwait
> v.c.time 0Sec
> v.c.voltage 0V
>The temperature bug for Roadster is a known issue, and is fixed in
>4082bb2a (and released in 3.2.009).
>I triggered an update for you (to 3.2.009-1-g92cc5ed), and that
>installed ok. I’ll try to find out if the temperature bug is fixed now
>or not.
>Regards, Mark.
>> On 3 Feb 2020, at 5:08 AM, Greg D. <gregd2350 at gmail.com> wrote:
>> Um, I just noticed that all the metrics except for the 12v battery
>> voltage are zero. The car is awake and charging right now, but
>hasn't
>> been driven since the software update to 3.2.008-134-ge6ac0c7, if
>that
>> matters. I believe the TPMS metrics don't update until it's driven,
>but
>> I should be seeing the temps. All gray and zero.
>> I tried putting the car in Drive (just sitting there), and the TPMS
>data
>> came on after a few minutes. But the rest of the metrics are still
>zero
>> and gray.
>> The VDS shows the correct temps, and is operating normally.
>> Oops?
>> Greg
>> Greg D. wrote:
>>> My module updated to 3.2.008-134-ge6ac0c7 last night (2am local),
>and
>>> did the single update as it should. m.version is consistent with
>this.
>>> The module sees your 3.2.009-1-g92cc5ed as available. Presume it
>will
>>> update tonight.
>>> So, all "go" from this console.
>>> Greg
>>> Mark Webb-Johnson wrote:
>>>> I’ve tagged 3.2.009 based on where we are today, and built on my
>edge.
>>>> If no problems reported overnight, I’ll push to EAP tomorrow.
>>>> Regards, Mark.
>>>>> On 2 Feb 2020, at 6:21 PM, Michael Balzer <dexter at expeedo.de>
>wrote:
>>>>> Am 02.02.20 um 02:13 schrieb Mark Webb-Johnson:
>>>>>> Seems we are ready for another release. I made a number of fixes
>yesterday, and maybe able to make a few more today, then I am done and
>ready to release 3.2.009.
>>>>>> Anything else to put in this?
>>>>> OK, nothing open here.
>>>>> Regards,
>>>>> Michael
>>>>>> Regards, Mark
>>>>>> OvmsDev mailing list
This space for rent...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200202/eeb6cc23/attachment-0001.html>
