[Ovmsdev] Addition to OVMS Developer Guide
Thu Dec 31 16:51:29 HKT 2020
Steve,
very good to read and spot on now in my opinion.
Regarding command options: for my latest command addition (obdii
requests) I checked if we can use getopt_r(). Problems are a) it's not
in the newlib included in esp-idf, and b) we also would need to change
all handler signatures to allow getopt to modify the argv array. I also
checked if some clever C++ getopt class is available but found none.
I returned to implementing the option scanning the classical way, but
took a note to implement a support class for this later on.
Am 30.12.20 um 03:23 schrieb Stephen Casner:
> Michael,
> OK, I've added a couple of paragraphs about duplicate registrations
> and unregistering.  I also added code exerpts for the two source
> references and did some more wordsmithing and annotation cleanup.
> I think this is finished for now, but let me know if you see something
> that needs attention.
>                                                          -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201231/6591ddc5/attachment.sig>
