[Ovmsdev] Fireplace app
Tue Dec 29 03:12:28 HKT 2020
I've found the issue: gradle build variables don't work correctly
anymore. I need to set the target SDK version manually on both modules.
Sharkcow, I'll merge your PR and do the changes I suggested.
Am 28.12.20 um 19:57 schrieb Michael Balzer:
> Sharkcow,
> according to your PR you want to add the service interval info to the
> "S" (status) message. IMO that's not the most appropriate place. I'd
> rather add this to the "F" message, as that's already carrying the
> VIN, and also is meant to be updated less frequently.
> Also, we should pass through new fields to the Intent broadcast by
> default, to avoid stumbling upon missing fields as with the HVAC. So
> please add the respective puts to getBroadcastData().
> Can you do these changes short term?
> Am 28.12.20 um 18:36 schrieb sharkcow:
>> bad news for some might be good news for others... maybe that way my
>> recent pull request has a chance of making it into the next version? :)
>> Thanks,
>> sharkcow
>> Am 28.12.20 um 18:13 schrieb Michael Balzer:
>>> Chris,
>>> I thought "of course, should be a matter of minutes"… and *zapp* came
>>> Google along. It doesn't let me upload the new APK, keeps telling me it
>>> needs to be targeted for API 29, which it is built for according to
>>> Android Studio, but apparently the APK manifest keeps API 28 despite
>>> all
>>> my config efforts. I'll need to spend some more hours investigating
>>> this… *sigh*
>>> Am 28.12.20 um 16:54 schrieb Chris van der Meijden:
>>>> Cool ...
>>>> Could you perhaps compile a 3.17.3 with that one?
>>>> Would also give me the new images "officially" :-)
>>>> Thanx
>>>> Chris
>>>> Am Montag, den 28.12.2020, 16:31 +0100 schrieb Michael Balzer:
>>>>> Done.
>>>>> Am 28.12.20 um 16:26 schrieb Michael Balzer:
>>>>>> Chris,
>>>>>> nice :-)
>>>>>> Just checked: the App doesn't yet transmit the HVAC flag via the
>>>>>> update intent, but that's really simple to add. I'll do that
>>>>>> right now.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 28.12.20 um 14:53 schrieb Chris van der Meijden:
>>>>>>> The app is up and running.
>>>>>>> https://github.com/devmarxx/OVMS-Fireplace
>>>>>>> This is still very, very beta. It just does what it needs to do,
>>>>>>> without any checks on user entries or responses from the vehicle.
>>>>>>> But it works and makes me smile :-))
>>>>>>> Regards
>>>>>>> Chris
>>>>>>> Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer:
>>>>>>>> Chris,
>>>>>>>> TL;DR: simply add the command to execute after the "7," intro,
>>>>>>>> e.g.
>>>>>>>> "7,climatecontrol on".
>>>>>>>> The SendCommand API was built around the V2 message protocol,
>>>>>>>> so you
>>>>>>>> need to send commands as MP commands, see
>>>>>>>> https://docs.openvehicles.com/en/latest/protocol_v2/commands.html
>>>>>>>> for
>>>>>>>> a
>>>>>>>> list. MP command code 7 passes standard text (former SMS) commands
>>>>>>>> to
>>>>>>>> the shell, that's what the Wiki example shows (for V2 command
>>>>>>>> "STAT?").
>>>>>>>> You can get the command response by listening to the CommandResult
>>>>>>>> intent and reading the "cmd_data" extra. Be aware all command
>>>>>>>> result
>>>>>>>> will be sent as intents, so you need to check if a result matches
>>>>>>>> your
>>>>>>>> command (could possibly be improved if needed).
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 28.12.20 um 10:34 schrieb Chris van der Meijden:
>>>>>>>>> I'm writing a little Android app with Cordova to do something
>>>>>>>>> similar
>>>>>>>>> as Tesla's "Romance mode". The app will turn climate control
>>>>>>>>> on or
>>>>>>>>> off
>>>>>>>>> and will show a burning log fire while the car is heating.
>>>>>>>>> As cordova uses HTML and Javascript you can see an online preview
>>>>>>>>> here:
>>>>>>>>> http://www.arachnon.de/fire/test.html
>>>>>>>>> When you click or tap on the fireplace the countdown for turning
>>>>>>>>> "climatecontrol" on ticks down for 17 seconds. After that the
>>>>>>>>> fire
>>>>>>>>> starts "moving" and on webkit browsers you will hear a tickling
>>>>>>>>> sound.
>>>>>>>>> When you click or tap again the tickling will stop and you
>>>>>>>>> will get
>>>>>>>>> a
>>>>>>>>> static image again. You will also get a red bar for 10 seconds,
>>>>>>>>> turning
>>>>>>>>> "climatecontrol" off and blocking any new commands for those 10
>>>>>>>>> seconds.
>>>>>>>>> When you click or tap on the yellow bar you will be able to store
>>>>>>>>> your
>>>>>>>>> OVMS credentials (vehicle ID and password). Cave: this is done in
>>>>>>>>> plain
>>>>>>>>> text with window.localstorage so the password will be plain
>>>>>>>>> readable
>>>>>>>>> from the local storage within the browser on your device.
>>>>>>>>> The credentials are needed to communicate with the Android OVMS
>>>>>>>>> app, as
>>>>>>>>> I am planning to use the "SendCommand Broadcast Intent data"
>>>>>>>>> functionality of the OVMS app. I should be able to do that via
>>>>>>>>> this
>>>>>>>>> cordova plugin:
>>>>>>>>> https://github.com/cordova-misc/cordova-webintent
>>>>>>>>> I read the OVMS "SendCommand Broadcast Intent data" documentation
>>>>>>>>> here:
>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma
>>>>>>>>> nd-B
>>>>>>>>> roadcast-Intent-data
>>>>>>>>> but it is not clear to me, how I can initiate the "climatecontrol
>>>>>>>>> on"
>>>>>>>>> shell command over the broadcast. So would like to ask for
>>>>>>>>> help on
>>>>>>>>> that
>>>>>>>>> Once the app is up and running it should be usable for any
>>>>>>>>> vehicle
>>>>>>>>> with
>>>>>>>>> OVMS climate control implemented.
>>>>>>>>> Just a little gimmick. But fun :-))
>>>>>>>>> Regards
>>>>>>>>> Chris
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>> <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201228/2ce96a61/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201228/2ce96a61/attachment-0001.sig>
