[Ovmsdev] Fireplace app
sharkcow
sharkcow at gmx.de
Tue Dec 29 01:36:39 HKT 2020
bad news for some might be good news for others... maybe that way my
recent pull request has a chance of making it into the next version? :)
Thanks,
sharkcow
Am 28.12.20 um 18:13 schrieb Michael Balzer:
> Chris,
> I thought "of course, should be a matter of minutes"… and *zapp* came
> Google along. It doesn't let me upload the new APK, keeps telling me it
> needs to be targeted for API 29, which it is built for according to
> Android Studio, but apparently the APK manifest keeps API 28 despite all
> my config efforts. I'll need to spend some more hours investigating
> this… *sigh*
> Am 28.12.20 um 16:54 schrieb Chris van der Meijden:
>> Cool ...
>> Could you perhaps compile a 3.17.3 with that one?
>> Would also give me the new images "officially" :-)
>> Thanx
>> Chris
>> Am Montag, den 28.12.2020, 16:31 +0100 schrieb Michael Balzer:
>>> Done.
>>> Am 28.12.20 um 16:26 schrieb Michael Balzer:
>>>> Chris,
>>>> nice :-)
>>>> Just checked: the App doesn't yet transmit the HVAC flag via the
>>>> update intent, but that's really simple to add. I'll do that right now.
>>>> Regards,
>>>> Michael
>>>> Am 28.12.20 um 14:53 schrieb Chris van der Meijden:
>>>>> The app is up and running.
>>>>> https://github.com/devmarxx/OVMS-Fireplace
>>>>> This is still very, very beta. It just does what it needs to do,
>>>>> without any checks on user entries or responses from the vehicle.
>>>>> But it works and makes me smile :-))
>>>>> Regards
>>>>> Chris
>>>>> Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer:
>>>>>> Chris,
>>>>>> TL;DR: simply add the command to execute after the "7," intro, e.g.
>>>>>> "7,climatecontrol on".
>>>>>> The SendCommand API was built around the V2 message protocol, so you
>>>>>> need to send commands as MP commands, see
>>>>>> https://docs.openvehicles.com/en/latest/protocol_v2/commands.html for
>>>>>> a
>>>>>> list. MP command code 7 passes standard text (former SMS) commands
>>>>>> to
>>>>>> the shell, that's what the Wiki example shows (for V2 command
>>>>>> "STAT?").
>>>>>> You can get the command response by listening to the CommandResult
>>>>>> intent and reading the "cmd_data" extra. Be aware all command result
>>>>>> will be sent as intents, so you need to check if a result matches
>>>>>> your
>>>>>> command (could possibly be improved if needed).
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 28.12.20 um 10:34 schrieb Chris van der Meijden:
>>>>>>> I'm writing a little Android app with Cordova to do something
>>>>>>> similar
>>>>>>> as Tesla's "Romance mode". The app will turn climate control on or
>>>>>>> off
>>>>>>> and will show a burning log fire while the car is heating.
>>>>>>> As cordova uses HTML and Javascript you can see an online preview
>>>>>>> here:
>>>>>>> http://www.arachnon.de/fire/test.html
>>>>>>> When you click or tap on the fireplace the countdown for turning
>>>>>>> "climatecontrol" on ticks down for 17 seconds. After that the fire
>>>>>>> starts "moving" and on webkit browsers you will hear a tickling
>>>>>>> sound.
>>>>>>> When you click or tap again the tickling will stop and you will get
>>>>>>> a
>>>>>>> static image again. You will also get a red bar for 10 seconds,
>>>>>>> turning
>>>>>>> "climatecontrol" off and blocking any new commands for those 10
>>>>>>> seconds.
>>>>>>> When you click or tap on the yellow bar you will be able to store
>>>>>>> your
>>>>>>> OVMS credentials (vehicle ID and password). Cave: this is done in
>>>>>>> plain
>>>>>>> text with window.localstorage so the password will be plain
>>>>>>> readable
>>>>>>> from the local storage within the browser on your device.
>>>>>>> The credentials are needed to communicate with the Android OVMS
>>>>>>> app, as
>>>>>>> I am planning to use the "SendCommand Broadcast Intent data"
>>>>>>> functionality of the OVMS app. I should be able to do that via this
>>>>>>> cordova plugin:
>>>>>>> https://github.com/cordova-misc/cordova-webintent
>>>>>>> I read the OVMS "SendCommand Broadcast Intent data" documentation
>>>>>>> here:
>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma
>>>>>>> nd-B
>>>>>>> roadcast-Intent-data
>>>>>>> but it is not clear to me, how I can initiate the "climatecontrol
>>>>>>> on"
>>>>>>> shell command over the broadcast. So would like to ask for help on
>>>>>>> that
>>>>>>> Once the app is up and running it should be usable for any vehicle
>>>>>>> with
>>>>>>> OVMS climate control implemented.
>>>>>>> Just a little gimmick. But fun :-))
>>>>>>> Regards
>>>>>>> Chris
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
