[Ovmsdev] Fireplace app
Chris van der Meijden
chris at arachnon.de
Mon Dec 28 23:54:53 HKT 2020
Cool ...
Could you perhaps compile a 3.17.3 with that one?
Would also give me the new images "officially" :-)
Thanx
Chris
Am Montag, den 28.12.2020, 16:31 +0100 schrieb Michael Balzer:
> Done.
> Am 28.12.20 um 16:26 schrieb Michael
> Balzer:
> > Chris,
> > nice :-)
> > Just checked: the App doesn't yet transmit the HVAC flag via
> > the
> > update intent, but that's really simple to add. I'll do that
> > right
> > now.
> > Regards,
> > Michael
> > Am 28.12.20 um 14:53 schrieb Chris van der Meijden:
> > > The app is up and running.
> > > https://github.com/devmarxx/OVMS-Fireplace
> > > This is still very, very beta. It just does what it needs
> > > to do,
> > > without any checks on user entries or responses from the
> > > vehicle.
> > > But it works and makes me smile :-))
> > > Regards
> > > Chris
> > > Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael
> > > Balzer:
> > > > Chris,
> > > > TL;DR: simply add the command to execute after the
> > > > "7," intro,
> > > > e.g.
> > > > "7,climatecontrol on".
> > > > The SendCommand API was built around the V2 message
> > > > protocol,
> > > > so you
> > > > need to send commands as MP commands, see
> > > > https://docs.openvehicles.com/en/latest/protocol_v2/commands.ht
> > > > ml for
> > > > a
> > > > list. MP command code 7 passes standard text (former
> > > > SMS)
> > > > commands
> > > > to
> > > > the shell, that's what the Wiki example shows (for V2
> > > > command
> > > > "STAT?").
> > > > You can get the command response by listening to the
> > > > CommandResult
> > > > intent and reading the "cmd_data" extra. Be aware all
> > > > command
> > > > result
> > > > will be sent as intents, so you need to check if a
> > > > result
> > > > matches
> > > > your
> > > > command (could possibly be improved if needed).
> > > > Regards,
> > > > Michael
> > > > Am 28.12.20 um 10:34 schrieb Chris van der Meijden:
> > > > > I'm writing a little Android app with
> > > > > Cordova to do something
> > > > > similar
> > > > > as Tesla's "Romance mode". The app will turn
> > > > > climate control
> > > > > on or
> > > > > off
> > > > > and will show a burning log fire while the car is
> > > > > heating.
> > > > > As cordova uses HTML and Javascript you can see
> > > > > an online
> > > > > preview
> > > > > here:
> > > > > http://www.arachnon.de/fire/test.html
> > > > > When you click or tap on the fireplace the
> > > > > countdown for
> > > > > turning
> > > > > "climatecontrol" on ticks down for 17 seconds.
> > > > > After that
> > > > > the fire
> > > > > starts "moving" and on webkit browsers you will
> > > > > hear a
> > > > > tickling
> > > > > sound.
> > > > > When you click or tap again the tickling will
> > > > > stop and you
> > > > > will get
> > > > > a
> > > > > static image again. You will also get a red bar
> > > > > for 10
> > > > > seconds,
> > > > > turning
> > > > > "climatecontrol" off and blocking any new
> > > > > commands for those
> > > > > 10
> > > > > seconds.
> > > > > When you click or tap on the yellow bar you will
> > > > > be able to
> > > > > store
> > > > > your
> > > > > OVMS credentials (vehicle ID and password). Cave:
> > > > > this is
> > > > > done in
> > > > > plain
> > > > > text with window.localstorage so the password
> > > > > will be plain
> > > > > readable
> > > > > from the local storage within the browser on your
> > > > > device.
> > > > > The credentials are needed to communicate with
> > > > > the Android
> > > > > OVMS
> > > > > app, as
> > > > > I am planning to use the "SendCommand Broadcast
> > > > > Intent data"
> > > > > functionality of the OVMS app. I should be able
> > > > > to do that
> > > > > via this
> > > > > cordova plugin:
> > > > > https://github.com/cordova-misc/cordova-webintent
> > > > > I read the OVMS "SendCommand Broadcast Intent
> > > > > data"
> > > > > documentation
> > > > > here:
> > > > > https://github.com/openvehicles/Open-Vehicle-Android/wiki/Sen
> > > > > dComma
> > > > > nd-B
> > > > > roadcast-Intent-data
> > > > > but it is not clear to me, how I can initiate the
> > > > > "climatecontrol
> > > > > on"
> > > > > shell command over the broadcast. So would like
> > > > > to ask for
> > > > > help on
> > > > > that
> > > > > Once the app is up and running it should be
> > > > > usable for any
> > > > > vehicle
> > > > > with
> > > > > OVMS climate control implemented.
> > > > > Just a little gimmick. But fun :-))
> > > > > Regards
> > > > > Chris
> > > > > _______________________________________________
> > > > > OvmsDev mailing list
> > > > > OvmsDev at lists.openvehicles.com
> > > > > http://lists.openvehicles.com/mailman/listinfo/ov
> > > > > msdev
> > > > http://lists.openvehicles.com/mailman/listinfo/ovmsde
> > > > v
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201228/abc2848d/attachment.htm>
