[Ovmsdev] Addition to OVMS Developer Guide
Sun Dec 27 05:42:35 HKT 2020
Michael,
The documentation I added was in the Google Doc OVMS Developer Guide:
https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/
Is that document supposed to be replaced by the github-based
Sphinx/RTD documentation that you mention?  The Google Doc appears
quite unfinished in that there are many blank pages between sections
and the TOC is not updated.
On Tue, 22 Dec 2020, Michael Balzer wrote:
> Thanks, Steve.
> That reminds me of looking for a solution to generate RTD pages from the C++
> sources, e.g. by sphinx-autodoc or similar. I prefer looking into the source,
> but have to admit the API documentation of the esp-idf is usable. We probably
> need to restructure most existing method & class comments and add the missing
> ones, but maintaining the API documentation would be easy afterwards.
> Am 22.12.20 um 09:14 schrieb Stephen Casner:
> > At Mark's request I have added a description of how to add commands to
> > the console command interpreter including the usage string syntax.
> > This should be considered a draft at this point; questions and
> > comments are welcome.
> > I added this under Vehicle Firmware Overview, but that might not be
> > the right place.  There is no general description of the core
> > firmware.
> >                                                          -- Steve
> > OvmsDev mailing list
