[Ovmsdev] Please test: poller protocol extension
Tue Dec 22 23:50:02 HKT 2020
I've merged the rework into the master now.
Am 17.12.20 um 09:21 schrieb Michael Balzer:
> Everyone,
> in case you missed the BMW i3 thread: I've added support for the
> ISO-TP "extended addressing scheme" to our poller (see below for details).
> The extension should not affect standard polling, but I had to touch
> all polling lists to add the protocol tag.
> I've tested the change with my car (Twizy) but would like to get some
> test results for other vehicle modules before merging into the master.
> Please pull, checkout and build from the "isotp-extadr" branch to test
> this with your car, and report your results.
> Thanks!
> Am 13.12.20 um 17:24 schrieb Michael Balzer:
>> Steve,
>> please try the poller rework I just pushed to the new "isotp-extadr"
>> branch.
>> These poll_pid_t records would define the example shown in the ELM327
>> manual:
>>     { 0x7b004, 0x7c0f1, VEHICLE_POLL_TYPE_OBDIISESSION, 0x81, {  20,
>> 0, 0 }, 0, ISOTP_EXTADR },
>>     { 0x7b004, 0x7c0f1, VEHICLE_POLL_TYPE_OBDIIGROUP,   0xa2, {  30,
>> I've used these + matching faked rx frames to verify the implementation.
>> Your SOC poll should look like this:
>>     { 0x6F107, 0x607F1, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xDDBC, {
>> 0, 10, 60 }, 0, ISOTP_EXTADR },
>> …and your IncomingPollReply() should receive the reply with pid ==
>> 0x607F1.
>> Please report your results.
>> Thanks,
>> Am 13.12.20 um 11:33 schrieb Michael Balzer:
>>> Steve,
>>> sorry, totally missed that. That's very unusual, haven't seen that
>>> before. I first thought maybe that's using CAN extended frame mode,
>>> but that's a totally different thing: it seems the i3 uses the
>>> *ISO-TP extended addressing scheme*.
>>> Quoting from Wikipedia: https://en.wikipedia.org/wiki/ISO_15765-2
>>>> ISO-TP can be operated with its own addressing as
>>>> so-called/Extended Addressing/or without address using only the CAN
>>>> ID (so-called/Normal Addressing/). Extended addressing uses the
>>>> first data byte of each frame as an additional element of the
>>>> address, reducing the application payload by one byte.
>>> So it's standard frames, with just an additional byte inserted
>>> before the protocol, used to extend the CAN ID.
>>> The OVMS poller doesn't support this yet.
>>> But it shouldn't be hard to add support for this, as it basically
>>> just fills the first frame byte from the lower 8 bits of the TX and
>>> RX IDs, reduces the payload size by one byte and shifts the offsets
>>> by one. PollerSend() and PollerReceive() need to be extended for
>>> this, and poll_pid_t needs to be extended by an addressing scheme tag.
>>> I'll have a look. Tell me if you'd like to take care of this.
>>> Am 13.12.20 um 09:58 schrieb Steve Davies:
>>>> On Sat, 12 Dec 2020 at 17:28, Michael Balzer <dexter at expeedo.de
>>>> <mailto:dexter at expeedo.de>> wrote:
>>>>     with log level verbose for canlog, you can simply activate CAN
>>>>     logging via:
>>>>     can log start monitor crtd
>>>>     …that will log all frames, if that's too much, add a filter
>>>>     like this:
>>>>     can log start monitor crtd 600-7ff
>>>> To see what was happening I had to "log level verbose canlog-monitor"
>>>> I see this being transmitted:
>>>> V (62436161) canlog-monitor: 1607847148.142477 1T11 6F1 03 22 dd bc
>>>> 00 00 00 00
>>>> There is no reply.
>>>> The other app I looked at does this on the LM327 as setup before
>>>> sending the request:
>>>> 2020-11-15 10:34:35.115 --> ATCEA07⏎ "extended address" 0x07
>>>> 2020-11-15 10:34:35.127 <-- OK⏎⏎>
>>>> Looking at the LM327 data sheet this configures an "extended
>>>> address" which is sent after the 0x6F1
>>>> I'm not sure if that 0x03 in what OVMS is sending is that byte, and
>>>> I need to somehow replace it wih 07, or if I have to get another
>>>> inserted?
>>>> Perhaps this is old hat to those more experienced than me.
>>>> From the data sheet and the trace it seems I'm also responsible to
>>>> customise the flow control messages :-
>>>> 2020-11-15 10:34:35.129 --> ATFCSH6F1⏎ Flow control header
>>>> 2020-11-15 10:34:35.141 <-- OK⏎⏎>
>>>> 2020-11-15 10:34:35.143 --> ATFCSD07300800⏎ Flow control data
>>>> 2020-11-15 10:34:35.156 <-- OK⏎⏎>
>>>> 2020-11-15 10:34:35.157 --> ATFCSM1⏎ Flow control mode
>>>> 2020-11-15 10:34:35.170 <-- OK⏎⏎>
>>>> I think that comes down to a flow control being "06 F1 07 30 08 00"
>>>> Here's the page in the LM327 to help understand what it does:
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/4f55ea54/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/4f55ea54/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/4f55ea54/attachment-0001.sig>
