[Ovmsdev] WiFi client not switching to better AP
Mon Dec 21 03:49:14 HKT 2020
Steve,
I just bewildered my neighbours by walking through the house, holding a
black box into the corners while staring onto my laptop screen… ;)
Works nicely. With "wifi reconnect" on the event, it scans immediately
for the next wifi net, without the script it doesn't scan until it
actually loses the connection, so works as before. I've seen no
duplicate "good" or "bad" events as well.
We could add an option for that reconnect strategy to the network
configuration already, so users don't need to create an event script to
get this behaviour.
I think the second part, keeping TCP connections alive on AP changes,
will require some more changes – if it's possible at all with the
current Wifi & LwIP stack.
Am 19.12.20 um 21:51 schrieb Stephen Casner:
> OK, a proposed change is attached.
>                                                          -- Steve
> On Sat, 19 Dec 2020, Michael Balzer wrote:
>> The reason to emit that event is to inform all potential listeners of the new
>> state, so they can keep their internal state synchronized.
>> Am 19.12.20 um 19:09 schrieb Stephen Casner:
>>> We don't need to emit the network.wifi.sta.bad event to cause
>>> WifiDisconnect() to be called because that is already happening.  Is
>>> there some other reason for emitting that event?
>>>                                                           -- Steve
>>>> It's also the event emission, keeping the handling close together is for
>>>> code
>>>> readability. The compiler will probably inline that call anyway.
>>>> Regards,
>>>> Michael
>>>> Am 19.12.20 um 18:32 schrieb Stephen Casner:
>>>>>> If we need to force good/bad state, I suggest adding a method for this
>>>>>> right
>>>>>> after WifiStaCheckSQ().
>>>>> Rather than just adding m_wifi_good = false in some place like
>>>>> WifiStaStop()?  Another method doesn't seem warranted.  That is a
>>>>> member variable, not something local to WifiStaCheckSQ().
>>>>>                                                            -- Steve
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201220/e5b29321/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201220/e5b29321/attachment-0001.sig>
