[Ovmsdev] Advice - mapping I3 data to the standard metrics
Fri Dec 18 04:09:30 HKT 2020
Steve,
Am 17.12.20 um 13:40 schrieb Steve Davies:
> Hi Michael et al,
> I set my first goal to get all the metrics that are required for the
> standard dashboard to work on the I3. I've got some questions about
> the intended use of the metrics. Hope someone can give advice:
> I'm sorry this is a tome, I did work to shorten it.
> 1) How do I understand a "trip"?
> My car has a trip-meter that you can reset. It also by itself seems
> to have some heuristic for trips that it uses for the "ecodrive"
> stuff. There are some PIDS that return trip-related data but I must
> still figure out when they reset - whether it goes by the trip
> feature. But what does OVMS regard as a "trip"?
What you want it to be, what makes the most sense for your users. If
your car has multiple trip odometers you can read, choose the most
appropriate or make if configurable which one to use. If not, implement
your own.
> For me: I would want it to work automatically - ie reset the trip
> stats each time the car goes to READY except perhaps if it has just
> been a few minutes since it was turned off.
> 2) About temperatures: The i3 has SO MANY temperature sensors,
> especially in the "electrical machine electronics" - how to map them
> to the standard metrics in OVMS?
Map only those to the standards which match their meaning. Map others to
custom metrics.
> I guess you will say it's my call, but I'd like what I do to be
> consistent with other vehicles.
> There are the following standard metrics relating to temperature (you
> can see some I mapped already)
> a) Battery temps: These I took from a PID that returns a "coldest",
> "hottest" and mean for the pack as a whole :
> v.b.p.temp.avg 21.27°C
> v.b.p.temp.max 21.83°C
> v.b.p.temp.min 21.04°C
> v.b.p.temp.stddev
> v.b.p.temp.stddev.max
> v.b.temp 21.27°C
> A min, max, and mean doesn't give me enough to work out a standard
> deviation. And: what is a "maximum" stddev? Is that over time?
These are for the overall cell values.
See the comments in main/metrics_standard.h, also at
https://docs.openvehicles.com/en/latest/userguide/metrics.html
> And for v.b.temp I just used the avg temp from above. I could have
> used the max instead - any view? :
If you don't have a separate battery temperature (outside the cells),
that's reasonable.
> b) v.e.temp: ("environmental temp") Found a value for outside /
> ambient temp :
> v.e.temp 21.5°C
> c) v.m.temp - motor temp: There are two temps for the "e-machine".
> These are inside the actual electric motor. I used the hotter of the
> two :
> v.m.temp 25.3968°C
> d) v.e.cabintemp: I haven't looked into the aircon system yet:
> e) v.i.temp: Inverter temp:
> There are 4 inverter temps:
> // Temperature converter phase U / Temperatur Umrichter Phase U
> 2020-12-16 17:59:10 SAST D (289275) v-bmwi3: From ECU EME, pid
> AE_TEMP_LE: got STAT_TEMP_UMRICHTER_PHASE_U_WERT=35.8020"°C"
> // Temperature converter phase V / Temperatur Umrichter Phase V
> AE_TEMP_LE: got STAT_TEMP_UMRICHTER_PHASE_V_WERT=35.0532"°C"
> // Temperature converter phase W / Temperatur Umrichter Phase W
> AE_TEMP_LE: got STAT_TEMP_UMRICHTER_PHASE_W_WERT=34.7568"°C"
> // Temperature inverter gate driver / Temperatur Inverter
> Gatedriver
> AE_TEMP_LE: got STAT_TEMP_UMRICHTER_GT_WERT=45.5832"°C"
> I just took the highest.
As above, whatever makes the most sense technically. On the Twizy, which
uses a SEVCON Gen4, I've used the short-term average overall internal
temperature instead of the highest one, as the highest is an ultra short
term estimation (simulation) of some internal transistor temperature.
The last of your temperatures sounds similar to that, so may be a bad
choice.
Then again, for some motor sports enthusiast, all these values may be of
interest, so why not just provide them in custom metrics.
> f) v.c.temp: charger temp:
> For v.c.temp there are also 4 measurements:
> // Temperature SLE-PowerFactorCorrection / Temperatur
> 2020-12-16 17:59:10 SAST D (289285) v-bmwi3: From ECU EME, pid
> AE_TEMP_LE: got STAT_TEMP_SLE_PFC_WERT=27.0972"°C"
> // Temperature SLE rectifier / Temperatur SLE-Gleichrichter
> AE_TEMP_LE: got STAT_TEMP_SLE_GR_WERT=28.0488"°C"
> // Temperature SLE push-pull converter / Temperatur
> SLE-Gegentaktwandler
> AE_TEMP_LE: got STAT_TEMP_SLE_GTW_WERT=27.5652"°C"
> // Temperature of the SLE board / Temperatur des SLE Boards
> AE_TEMP_LE: got STAT_TEMP_SLE_BO_WERT=29.0004"°C"
> (SLE also called KLE elsewhere - Komfort Ladeelectronik I think it is)
> I took the hottest.
Same as above.
> My car also has DC charging but if I understand that rightly there
> isn't any high power electrical stuff onboard for that, contactors are
> closed to give the external - so nothing to get hot except the battery
> itself.
> Then I have some more temps -
> DC/DC converter used to supply the 12v systems (and to charge the 12
> battery).
> I don't see any standard metrics for this subsystem?
> // Temperature of the DCDC board / Temperatur des DCDC Boards
> AE_TEMP_LE: got STAT_TEMP_DCDC_BO_WERT=35.8488"°C"
> // Temperature DC / DC push-pull converter / Temperatur
> DC/DC-Gegentaktwandler
> AE_TEMP_LE: got STAT_TEMP_DCDC_GTW_WERT=32.0892"°C"
> // Temperature DC / DC buck converter / Temperatur
> DC/DC-Tiefsetzer
> AE_TEMP_LE: got STAT_TEMP_DCDC_TS_WERT=59.9976"°C"
> AE_TEMP_LE: got STAT_TEMP_DCDC_GR_WERT=31.6524"°C"
No standard metrics, but that's a candidate. But again, only one
temperature (the most relevant for the user) will be standard.
> - "ELUP power output stage". Dunno what "ELUP" is and didn't find it
> in the technical training info I have.
> // Temperature on the power board - measuring point ELUP power
> output stage / Temperatur auf dem Powerbord -
> // Messstelle ELUP Leistungsendstufe
> AE_TEMP_LE: got STAT_TEMP_ELUP_LE_WERT=30.0768"°C"
> - And 2 processor temps:
> // Temperature processor MC0 / Temperatur Prozessor MC0
> AE_TEMP_LE: got STAT_TEMP_PROZESSOR_MC0_WERT=39.9048"°C"
> // Temperature processor MC2 / Temperatur Prozessor MC2
> AE_TEMP_LE: got STAT_TEMP_PROZESSOR_MC2_WERT=39.9048"°C"
See above: custom metrics.
> 3) What to do about "range".
> So I found a pid that returns a "range" - but it always be the range
> in so-called "Comfort" mode. The car instrument display actually
> shows range according to the mode the car is in. I normally drive
> in "Eco-pro".
> There's another PID that gives a figure for each of the 4 modes my car
> has got.
> How do other vehicles handle this?
> I'd like to show users all the ranges, and then put the range in the
> current mode into the standard metric v.b.range.est
> And I don't think I understand exactly the difference between "est",
> "ideal", and "full".
> My best guess for how to make them work:
> "est" is the figure the car gives up - either that "comfort mode"
> number or the number for the current mode
> "ideal": my best idea for how to get this is the WLTP range for the
> car's battery capacity scaled by the SOH% and the SOC% to come up with
> some sort of theoretically "possible" figure?
> "full": not sure - My idea would be to take the "est" figure from the
> car and scale it up to a range if the battery was full.
Estimated range = car figure for current driving mode & conditions, or
your own calculation if the car delivers no/poor/undependable figures
Ideal range = either the best range the car calculates, or your own
calculation for the best case driving conditions if the car delivers
Full range = Ideal range at 100% SOC & current conditions
Don't use the WLTP figures if they are totally unrealistic. Try to
create additional, dependable value for the user.
> Thanks,
> Steve
Regard,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201217/c8048e81/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201217/c8048e81/attachment-0001.sig>
