[Ovmsdev] boot loop with RegisterCommand
Thu Dec 17 22:17:39 HKT 2020
Do you call OBDInit() after the cmd_xvu init?
Am 17.12.20 um 15:02 schrieb sharkcow:
> Sorry, obviously should have included this. The includes are copied from
> the twizy files.
> In my main header file, I have:
> class OvmsVehicleVWeUp : public OvmsVehicle
>   protected:
>     OvmsCommand *cmd_xvu;
>   public:
>     // Shell commands:
>     static void shell_obd_request(int verbosity, OvmsWriter* writer,
> OvmsCommand* cmd, int argc, const char* const* argv);
> in the main cpp file:
> OvmsVehicleVWeUp::OvmsVehicleVWeUp()
> // init commands:
>     cmd_xvu = MyCommandApp.RegisterCommand("xvu", "VW e-Up");
> in the obd cpp file:
> void OvmsVehicleVWeUp::OBDInit()
>     // init commands:
>     OvmsCommand* cmd;
>     OvmsCommand* obd;
>     obd = cmd_xvu->RegisterCommand("obd", "OBD2 tools");
>     cmd = obd->RegisterCommand("request", "Send OBD2 request, output
> response");
>     cmd->RegisterCommand("device", "Send OBD2 request to a device",
> shell_obd_request, "<txid> <rxid> <request>", 3, 3);
>     cmd->RegisterCommand("broadcast", "Send OBD2 request as broadcast",
> shell_obd_request, "<request>", 1, 1);
>     cmd->RegisterCommand("01motelec", "Send OBD2 request to ECU01 motor
> electronics", shell_obd_request, "<request>", 1, 1);
> Am 17.12.20 um 08:54 schrieb Mark Webb-Johnson:
>> Can you post an extract of your command registry code?
>>> On 17 Dec 2020, at 2:50 PM, sharkcow <sharkcow at gmx.de> wrote:
>>> Hi all,
>>> I tried to steal some code from the Twizy module but obviously don't
>>> understand how it works... my code results in a boot loop.
>>> I would like to have a possibility to test OBD codes in the shell
>>> (something I think would be immensely useful as a general function;
>>> that
>>> way, getting started with a new vehicle would be much easier.)
>>> Anyway, the problem seems to be in the lookup of the command name I'm
>>> trying to register, see stack trace below. Any help is greatly
>>> appreciated!
>>> Thanks,
>>> sharkcow
>>> 0x400fc115 is in std::_Rb_tree<char const*, std::pair<char const*
>>> const,
>>> OvmsCommand*>, std::_Select1st<std::pair<char const* const,
>>> OvmsCommand*> >, CompareCharPtr, std::allocator<std::pair<char const*
>>> const, OvmsCommand*> > >::find(char const* const&)
>>> (/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:663).
>>> 658          (this->_M_impl._M_header._M_parent);
>>> 659          }
>>> 660
>>> 661          _Link_type
>>> 662          _M_end() _GLIBCXX_NOEXCEPT
>>> 663          { return
>>> reinterpret_cast<_Link_type>(&this->_M_impl._M_header); }
>>> 664
>>> 665          _Const_Link_type
>>> 666          _M_end() const _GLIBCXX_NOEXCEPT
>>> 667          { return
>>> reinterpret_cast<_Const_Link_type>(&this->_M_impl._M_header); }
>>> 0x400fc15c is in OvmsCommandMap::FindCommand(char const*)
>>> (/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_map.h:846).
>>> 841           *  past-the-end ( @c end() ) iterator.
>>> 842           */
>>> 843
>>> 844          iterator
>>> 845          find(const key_type& __x)
>>> 846          { return _M_t.find(__x); }
>>> 847
>>> 848    #if __cplusplus > 201103L
>>> 849          template<typename _Kt>
>>> 850        auto
>>> 0x400fd87e is in OvmsCommand::RegisterCommand(char const*, char const*,
>>> void (*)(int, OvmsWriter*, OvmsCommand*, int, char const* const*), char
>>> const*, int, int, bool, int (*)(OvmsWriter*, OvmsCommand*, int, char
>>> const* const*, bool))
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_command.cpp:542).
>>> 537      return m_parent;
>>> 538      }
>>> 539
>>> 540    OvmsCommand* OvmsCommand::FindCommand(const char* name)
>>> 541      {
>>> 542      return m_children.FindCommand(name);
>>> 543      }
>>> 544
>>> 545    void help(int verbosity, OvmsWriter* writer, OvmsCommand*
>>> cmd, int
>>> 546      {
>>> 0x401ac67a is in OvmsVehicleVWeUp::OBDInit()
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle_vweup_all/src/vweup_obd.cpp:228).
>>> 223    //    cmd->RegisterCommand("reset", "Reset OVMS DTC statistics",
>>> shell_obd_resetdtc,
>>> 224    //        "Resets internal DTC buffer and presence counters.\n"
>>> 225    //        "No change is done on the car side.");
>>> 226
>>> 227        OvmsCommand* obd;
>>> 228        obd = cmd_xvu->RegisterCommand("obd", "OBD2 tools");
>>> 229        cmd = obd->RegisterCommand("request", "Send OBD2 request,
>>> output
>>> response");
>>> 230        cmd->RegisterCommand("device", "Send OBD2 request to a
>>> device",
>>> 231        cmd->RegisterCommand("broadcast", "Send OBD2 request as
>>> broadcast", shell_obd_request, "<request>", 1, 1);
>>> 232        cmd->RegisterCommand("01motelec", "Send OBD2 request to
>>> ECU01
>>> motor electronics", shell_obd_request, "<request>", 1, 1);
>>> 0x401abd4e is in OvmsVehicleVWeUp::ConfigChanged(OvmsConfigParam*)
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle_vweup_all/src/vehicle_vweup_all.cpp:210).
>>> 205        if (vweup_enable_t26)
>>> 206            T26Init();
>>> 207        vweup_con = vweup_enable_obd * 2 + vweup_enable_t26;
>>> 208    //    ESP_LOGD(TAG,"vweup_con: %i",vweup_con);
>>> 209        if (vweup_enable_obd || (vweup_modelyear<2020 &&
>>> vweup_modelyear_new>2019) || (vweup_modelyear_new<2020 &&
>>> vweup_modelyear>2019)) // switch between generations: reload OBD
>>> poll list
>>> 210            OBDInit();
>>> 211        if (!vweup_enable_obd)
>>> 212            OBDDeInit();
>>> 213        vweup_modelyear = vweup_modelyear_new;
>>> 214        if (!vweup_con)
>>> 0x401abf5f is in OvmsVehicleVWeUp::OvmsVehicleVWeUp()
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle_vweup_all/src/vehicle_vweup_all.cpp:124).
>>> 119    {
>>> 120        ESP_LOGI(TAG, "Start VW e-Up vehicle module");
>>> 121
>>> 122    // init configs:
>>> 123        MyConfig.RegisterParam("xvu", "VW e-Up", true, true);
>>> 124        ConfigChanged(NULL);
>>> 125
>>> 126    //    if (vweup_con % 2){ // T26A connected
>>> 127    //    }
>>> 128    //    if (vweup_con > 1){ // OBD connected
>>> 0x401abf9a is in CreateVehicle<OvmsVehicleVWeUp>()
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.h:456).
>>> 451        virtual bool FormatBmsAlerts(int verbosity, OvmsWriter*
>>> writer,
>>> bool show_warnings);
>>> 452      };
>>> 453
>>> 454    template<typename Type> OvmsVehicle* CreateVehicle()
>>> 455      {
>>> 456      return new Type;
>>> 457      }
>>> 458
>>> 459    class OvmsVehicleFactory
>>> 460      {
>>> 0x401656ff is in OvmsVehicleFactory::NewVehicle(char const*)
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:873).
>>> 868    OvmsVehicle* OvmsVehicleFactory::NewVehicle(const char*
>>> VehicleType)
>>> 869      {
>>> 870      OvmsVehicleFactory::map_vehicle_t::iterator iter =
>>> m_vmap.find(VehicleType);
>>> 871      if (iter != m_vmap.end())
>>> 872        {
>>> 873        return iter->second.construct();
>>> 874        }
>>> 875      return NULL;
>>> 876      }
>>> 877
>>> 0x40165737 is in OvmsVehicleFactory::SetVehicle(char const*)
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:900).
>>> 895        m_currentvehicle->m_ready = false;
>>> 896        delete m_currentvehicle;
>>> 897        m_currentvehicle = NULL;
>>> 898        m_currentvehicletype.clear();
>>> 899        }
>>> 900      m_currentvehicle = NewVehicle(type);
>>> 901      if (m_currentvehicle)
>>> 902      {
>>> 903          m_currentvehicle->m_ready = true;
>>> 904      }
>>> 0x40165825 is in OvmsVehicleFactory::AutoInit()
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:914).
>>> 909
>>> 910    void OvmsVehicleFactory::AutoInit()
>>> 911      {
>>> 912      std::string type = MyConfig.GetParamValue("auto",
>>> "vehicle.type");
>>> 913      if (!type.empty())
>>> 914        SetVehicle(type.c_str());
>>> 915      }
>>> 916
>>> 917    OvmsVehicle* OvmsVehicleFactory::ActiveVehicle()
>>> 918      {
>>> 0x400f80f3 is in Housekeeping::Init(std::__cxx11::basic_string<char,
>>> std::char_traits<char>, std::allocator<char> >, void*)
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_housekeeping.cpp:208).
>>> 203        ESP_LOGI(TAG, "Auto init modem (free: %zu bytes)",
>>> heap_caps_get_free_size(MALLOC_CAP_8BIT|MALLOC_CAP_INTERNAL));
>>> 204        MyPeripherals->m_simcom->AutoInit();
>>> 205    #endif // #ifdef CONFIG_OVMS_COMP_MODEM_SIMCOM
>>> 206
>>> 207        ESP_LOGI(TAG, "Auto init vehicle (free: %zu bytes)",
>>> 208        MyVehicleFactory.AutoInit();
>>> 209
>>> 210    #ifdef CONFIG_OVMS_COMP_OBD2ECU
>>> 211        ESP_LOGI(TAG, "Auto init obd2ecu (free: %zu bytes)",
>>> 212        obd2ecuInit.AutoInit();
>>> 0x400f7d06 is in std::_Function_handler<void
>>> (std::__cxx11::basic_string<char, std::char_traits<char>,
>>> std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void
>>> (Housekeeping::*)(std::__cxx11::basic_string<char,
>>> std::char_traits<char>, std::allocator<char> >, void*)> (Housekeeping*,
>>> std::_Placeholder<1>, std::_Placeholder<2>)>
>>> >::_M_invoke(std::_Any_data
>>> const&, std::__cxx11::basic_string<char, std::char_traits<char>,
>>> std::allocator<char> >&&, void*&&)
>>> (/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
>>> 595          template<typename... _Args, typename _Req
>>> 596                   = _Require<typename _Traits::__lvalue,
>>> 597 _CheckArgs<_Pack<_Args...>>>>
>>> 598        result_type
>>> 599        operator()(_Class* __object, _Args&&... __args) const
>>> 600        { return
>>> (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
>>> 601
>>> 602          // Handle smart pointers, references and pointers to
>>> derived
>>> 603          template<typename _Tp, typename... _Args, typename _Req
>>> 604                   = _Require<_NotSame<_Class, _Tp>,
>>> _NotSame<_Class*, _Tp>,
>>> 0x400f457e is in std::function<void (std::__cxx11::basic_string<char,
>>> void*)>::operator()(std::__cxx11::basic_string<char,
>>> std::char_traits<char>, std::allocator<char> >, void*) const
>>> (/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
>>> 2266        function<_Res(_ArgTypes...)>::
>>> 2267        operator()(_ArgTypes... __args) const
>>> 2268        {
>>> 2269          if (_M_empty())
>>> 2270        __throw_bad_function_call();
>>> 2271          return _M_invoker(_M_functor,
>>> std::forward<_ArgTypes>(__args)...);
>>> 2272        }
>>> 2273
>>> 2274    #if __cpp_rtti
>>> 2275      template<typename _Res, typename... _ArgTypes>
>>> 0x400f4711 is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_events.cpp:229).
>>> 224          {
>>> 225          for (EventCallbackList::iterator itc=el->begin();
>>> itc!=el->end(); ++itc)
>>> 226            {
>>> 227            m_current_started = monotonictime;
>>> 228            m_current_callback = *itc;
>>> 229 m_current_callback->m_callback(m_current_event,
>>> msg->body.signal.data);
>>> 230            m_current_callback = NULL;
>>> 231            }
>>> 232          }
>>> 233        }
>>> 0x400f47f4 is in OvmsEvents::EventTask()
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_events.cpp:187).
>>> 182            {
>>> 183            case EVENT_none:
>>> 184              break;
>>> 185            case EVENT_signal:
>>> 186              m_current_event = msg.body.signal.event;
>>> 187              HandleQueueSignalEvent(&msg);
>>> 188              esp_task_wdt_reset(); // Reset WATCHDOG timer for
>>> this task
>>> 189              m_current_event.clear();
>>> 190              break;
>>> 191            default:
>>> 0x400f4859 is in EventLaunchTask(void*)
>>> (/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_events.cpp:57).
>>> 52
>>> 53    void EventLaunchTask(void *pvParameters)
>>> 54      {
>>> 55      OvmsEvents* me = (OvmsEvents*)pvParameters;
>>> 56
>>> 57      me->EventTask();
>>> 58      }
>>> 59
>>> 60    void event_trace(int verbosity, OvmsWriter* writer,
>>> OvmsCommand* cmd,
>>> 61      {
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201217/c58671c2/attachment-0001.sig>
