[Ovmsdev] boot loop with RegisterCommand
sharkcow
sharkcow at gmx.de
Thu Dec 17 14:50:58 HKT 2020
Hi all,
I tried to steal some code from the Twizy module but obviously don't
understand how it works... my code results in a boot loop.
I would like to have a possibility to test OBD codes in the shell
(something I think would be immensely useful as a general function; that
way, getting started with a new vehicle would be much easier.)
Anyway, the problem seems to be in the lookup of the command name I'm
trying to register, see stack trace below. Any help is greatly appreciated!
Thanks,
sharkcow
0x400fc115 is in std::_Rb_tree<char const*, std::pair<char const* const,
OvmsCommand*>, std::_Select1st<std::pair<char const* const,
OvmsCommand*> >, CompareCharPtr, std::allocator<std::pair<char const*
const, OvmsCommand*> > >::find(char const* const&)
(/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_tree.h:663).
658 (this->_M_impl._M_header._M_parent);
659 }
660
661 _Link_type
662 _M_end() _GLIBCXX_NOEXCEPT
663 { return reinterpret_cast<_Link_type>(&this->_M_impl._M_header); }
664
665 _Const_Link_type
666 _M_end() const _GLIBCXX_NOEXCEPT
667 { return
reinterpret_cast<_Const_Link_type>(&this->_M_impl._M_header); }
0x400fc15c is in OvmsCommandMap::FindCommand(char const*)
(/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/stl_map.h:846).
841 * past-the-end ( @c end() ) iterator.
842 */
843
844 iterator
845 find(const key_type& __x)
846 { return _M_t.find(__x); }
847
848 #if __cplusplus > 201103L
849 template<typename _Kt>
850 auto
0x400fd87e is in OvmsCommand::RegisterCommand(char const*, char const*,
void (*)(int, OvmsWriter*, OvmsCommand*, int, char const* const*), char
const*, int, int, bool, int (*)(OvmsWriter*, OvmsCommand*, int, char
const* const*, bool))
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_command.cpp:542).
537 return m_parent;
538 }
539
540 OvmsCommand* OvmsCommand::FindCommand(const char* name)
541 {
542 return m_children.FindCommand(name);
543 }
544
545 void help(int verbosity, OvmsWriter* writer, OvmsCommand* cmd, int
argc, const char* const* argv)
546 {
0x401ac67a is in OvmsVehicleVWeUp::OBDInit()
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle_vweup_all/src/vweup_obd.cpp:228).
223 // cmd->RegisterCommand("reset", "Reset OVMS DTC statistics",
shell_obd_resetdtc,
224 // "Resets internal DTC buffer and presence counters.\n"
225 // "No change is done on the car side.");
226
227 OvmsCommand* obd;
228 obd = cmd_xvu->RegisterCommand("obd", "OBD2 tools");
229 cmd = obd->RegisterCommand("request", "Send OBD2 request, output
response");
230 cmd->RegisterCommand("device", "Send OBD2 request to a device",
shell_obd_request, "<txid> <rxid> <request>", 3, 3);
231 cmd->RegisterCommand("broadcast", "Send OBD2 request as
broadcast", shell_obd_request, "<request>", 1, 1);
232 cmd->RegisterCommand("01motelec", "Send OBD2 request to ECU01
motor electronics", shell_obd_request, "<request>", 1, 1);
0x401abd4e is in OvmsVehicleVWeUp::ConfigChanged(OvmsConfigParam*)
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle_vweup_all/src/vehicle_vweup_all.cpp:210).
205 if (vweup_enable_t26)
206 T26Init();
207 vweup_con = vweup_enable_obd * 2 + vweup_enable_t26;
208 // ESP_LOGD(TAG,"vweup_con: %i",vweup_con);
209 if (vweup_enable_obd || (vweup_modelyear<2020 &&
vweup_modelyear_new>2019) || (vweup_modelyear_new<2020 &&
vweup_modelyear>2019)) // switch between generations: reload OBD poll list
210 OBDInit();
211 if (!vweup_enable_obd)
212 OBDDeInit();
213 vweup_modelyear = vweup_modelyear_new;
214 if (!vweup_con)
0x401abf5f is in OvmsVehicleVWeUp::OvmsVehicleVWeUp()
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle_vweup_all/src/vehicle_vweup_all.cpp:124).
119 {
120 ESP_LOGI(TAG, "Start VW e-Up vehicle module");
121
122 // init configs:
123 MyConfig.RegisterParam("xvu", "VW e-Up", true, true);
124 ConfigChanged(NULL);
125
126 // if (vweup_con % 2){ // T26A connected
127 // }
128 // if (vweup_con > 1){ // OBD connected
0x401abf9a is in CreateVehicle<OvmsVehicleVWeUp>()
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.h:456).
451 virtual bool FormatBmsAlerts(int verbosity, OvmsWriter* writer,
bool show_warnings);
452 };
453
454 template<typename Type> OvmsVehicle* CreateVehicle()
455 {
456 return new Type;
457 }
458
459 class OvmsVehicleFactory
460 {
0x401656ff is in OvmsVehicleFactory::NewVehicle(char const*)
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:873).
868 OvmsVehicle* OvmsVehicleFactory::NewVehicle(const char* VehicleType)
869 {
870 OvmsVehicleFactory::map_vehicle_t::iterator iter =
m_vmap.find(VehicleType);
871 if (iter != m_vmap.end())
872 {
873 return iter->second.construct();
874 }
875 return NULL;
876 }
877
0x40165737 is in OvmsVehicleFactory::SetVehicle(char const*)
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:900).
895 m_currentvehicle->m_ready = false;
896 delete m_currentvehicle;
897 m_currentvehicle = NULL;
898 m_currentvehicletype.clear();
899 }
900 m_currentvehicle = NewVehicle(type);
901 if (m_currentvehicle)
902 {
903 m_currentvehicle->m_ready = true;
904 }
0x40165825 is in OvmsVehicleFactory::AutoInit()
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:914).
909
910 void OvmsVehicleFactory::AutoInit()
911 {
912 std::string type = MyConfig.GetParamValue("auto", "vehicle.type");
913 if (!type.empty())
914 SetVehicle(type.c_str());
915 }
916
917 OvmsVehicle* OvmsVehicleFactory::ActiveVehicle()
918 {
0x400f80f3 is in Housekeeping::Init(std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >, void*)
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_housekeeping.cpp:208).
203 ESP_LOGI(TAG, "Auto init modem (free: %zu bytes)",
heap_caps_get_free_size(MALLOC_CAP_8BIT|MALLOC_CAP_INTERNAL));
204 MyPeripherals->m_simcom->AutoInit();
205 #endif // #ifdef CONFIG_OVMS_COMP_MODEM_SIMCOM
206
207 ESP_LOGI(TAG, "Auto init vehicle (free: %zu bytes)",
208 MyVehicleFactory.AutoInit();
209
210 #ifdef CONFIG_OVMS_COMP_OBD2ECU
211 ESP_LOGI(TAG, "Auto init obd2ecu (free: %zu bytes)",
212 obd2ecuInit.AutoInit();
0x400f7d06 is in std::_Function_handler<void
(std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void
(Housekeeping::*)(std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >, void*)> (Housekeeping*,
std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data
const&, std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >&&, void*&&)
(/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
595 template<typename... _Args, typename _Req
596 = _Require<typename _Traits::__lvalue,
597 _CheckArgs<_Pack<_Args...>>>>
598 result_type
599 operator()(_Class* __object, _Args&&... __args) const
600 { return (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
601
602 // Handle smart pointers, references and pointers to derived
603 template<typename _Tp, typename... _Args, typename _Req
604 = _Require<_NotSame<_Class, _Tp>, _NotSame<_Class*, _Tp>,
0x400f457e is in std::function<void (std::__cxx11::basic_string<char,
void*)>::operator()(std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >, void*) const
(/opt/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
2266 function<_Res(_ArgTypes...)>::
2267 operator()(_ArgTypes... __args) const
2268 {
2269 if (_M_empty())
2270 __throw_bad_function_call();
2271 return _M_invoker(_M_functor,
std::forward<_ArgTypes>(__args)...);
2272 }
2273
2274 #if __cpp_rtti
2275 template<typename _Res, typename... _ArgTypes>
0x400f4711 is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_events.cpp:229).
224 {
225 for (EventCallbackList::iterator itc=el->begin();
itc!=el->end(); ++itc)
226 {
227 m_current_started = monotonictime;
228 m_current_callback = *itc;
229 m_current_callback->m_callback(m_current_event,
msg->body.signal.data);
230 m_current_callback = NULL;
231 }
232 }
233 }
0x400f47f4 is in OvmsEvents::EventTask()
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_events.cpp:187).
182 {
183 case EVENT_none:
184 break;
185 case EVENT_signal:
186 m_current_event = msg.body.signal.event;
187 HandleQueueSignalEvent(&msg);
188 esp_task_wdt_reset(); // Reset WATCHDOG timer for this task
189 m_current_event.clear();
190 break;
191 default:
0x400f4859 is in EventLaunchTask(void*)
(/opt/Open-Vehicle-Monitoring-System-3_Unh/vehicle/OVMS.V3/main/ovms_events.cpp:57).
52
53 void EventLaunchTask(void *pvParameters)
54 {
55 OvmsEvents* me = (OvmsEvents*)pvParameters;
56
57 me->EventTask();
58 }
59
60 void event_trace(int verbosity, OvmsWriter* writer, OvmsCommand* cmd,
int argc, const char* const* argv)
61 {
