[Ovmsdev] Apple push notifications no longer working
Mon Dec 14 14:17:43 HKT 2020
Push notifications are still working ok for me. What is the error you get back from the gateway?
We are using this protocol (see apns_send function):
https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/RemoteNotificationsPG/BinaryProviderAPI.html <https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/RemoteNotificationsPG/BinaryProviderAPI.html>
We need to convert to this one:
https://developer.apple.com/documentation/usernotifications/setting_up_a_remote_notification_server/sending_notification_requests_to_apns/ <https://developer.apple.com/documentation/usernotifications/setting_up_a_remote_notification_server/sending_notification_requests_to_apns/>
But have until the end of March 2021 to do it. The switch is not complex, and is probably slightly easier for us. It becomes just a simple http request, with pretty much the same payload we currently use (in json format).
> On 11 Dec 2020, at 12:27 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> Mark,
> a user informed me he no longer gets any push notifications to iOS.
> Looking into the logs, it seems the initial connect to the gateway fails in a way the perl code does not handle.
> I've found this in the Apple forums: https://developer.apple.com/forums/thread/667248
> It seems the protocol we use has been deprecated, but it should continue to work until March. Do you see a similar effect on your server?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/32f85db4/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/32f85db4/attachment.sig>
