[Ovmsdev] Help me get my first data item on the I3
Mon Dec 14 00:24:02 HKT 2020
Steve,
please try the poller rework I just pushed to the new "isotp-extadr" branch.
These poll_pid_t records would define the example shown in the ELM327
manual:
{ 0x7b004, 0x7c0f1, VEHICLE_POLL_TYPE_OBDIISESSION, 0x81, { 20, 0,
0 }, 0, ISOTP_EXTADR },
{ 0x7b004, 0x7c0f1, VEHICLE_POLL_TYPE_OBDIIGROUP, 0xa2, { 30, 0,
I've used these + matching faked rx frames to verify the implementation.
Your SOC poll should look like this:
{ 0x6F107, 0x607F1, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xDDBC, { 0,
10, 60 }, 0, ISOTP_EXTADR },
…and your IncomingPollReply() should receive the reply with pid == 0x607F1.
Please report your results.
Thanks,
Am 13.12.20 um 11:33 schrieb Michael Balzer:
> Steve,
> sorry, totally missed that. That's very unusual, haven't seen that
> before. I first thought maybe that's using CAN extended frame mode,
> but that's a totally different thing: it seems the i3 uses the *ISO-TP
> extended addressing scheme*.
> Quoting from Wikipedia: https://en.wikipedia.org/wiki/ISO_15765-2
>> ISO-TP can be operated with its own addressing as so-called/Extended
>> Addressing/or without address using only the CAN ID (so-called/Normal
>> Addressing/). Extended addressing uses the first data byte of each
>> frame as an additional element of the address, reducing the
>> application payload by one byte.
> So it's standard frames, with just an additional byte inserted before
> the protocol, used to extend the CAN ID.
> The OVMS poller doesn't support this yet.
> But it shouldn't be hard to add support for this, as it basically just
> fills the first frame byte from the lower 8 bits of the TX and RX IDs,
> reduces the payload size by one byte and shifts the offsets by one.
> PollerSend() and PollerReceive() need to be extended for this, and
> poll_pid_t needs to be extended by an addressing scheme tag.
> I'll have a look. Tell me if you'd like to take care of this.
> Am 13.12.20 um 09:58 schrieb Steve Davies:
>> On Sat, 12 Dec 2020 at 17:28, Michael Balzer <dexter at expeedo.de
>> with log level verbose for canlog, you can simply activate CAN
>> logging via:
>> can log start monitor crtd
>> …that will log all frames, if that's too much, add a filter like
>> this:
>> can log start monitor crtd 600-7ff
>> To see what was happening I had to "log level verbose canlog-monitor"
>> I see this being transmitted:
>> V (62436161) canlog-monitor: 1607847148.142477 1T11 6F1 03 22 dd bc
>> 00 00 00 00
>> There is no reply.
>> The other app I looked at does this on the LM327 as setup before
>> sending the request:
>> 2020-11-15 10:34:35.115 --> ATCEA07⏎ "extended address" 0x07
>> 2020-11-15 10:34:35.127 <-- OK⏎⏎>
>> Looking at the LM327 data sheet this configures an "extended address"
>> which is sent after the 0x6F1
>> I'm not sure if that 0x03 in what OVMS is sending is that byte, and I
>> need to somehow replace it wih 07, or if I have to get another inserted?
>> Perhaps this is old hat to those more experienced than me.
>> From the data sheet and the trace it seems I'm also responsible to
>> customise the flow control messages :-
>> 2020-11-15 10:34:35.129 --> ATFCSH6F1⏎ Flow control header
>> 2020-11-15 10:34:35.141 <-- OK⏎⏎>
>> 2020-11-15 10:34:35.143 --> ATFCSD07300800⏎ Flow control data
>> 2020-11-15 10:34:35.156 <-- OK⏎⏎>
>> 2020-11-15 10:34:35.157 --> ATFCSM1⏎ Flow control mode
>> 2020-11-15 10:34:35.170 <-- OK⏎⏎>
>> I think that comes down to a flow control being "06 F1 07 30 08 00"
>> Here's the page in the LM327 to help understand what it does:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201213/135f8b70/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201213/135f8b70/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201213/135f8b70/attachment-0001.sig>
