[Ovmsdev] Help me get my first data item on the I3
Steve Davies
steve at telviva.co.za
Sat Dec 12 17:19:23 HKT 2020
Hi,
Can I ask someone to help me get started with pulling data off the OBD-2 on
the I3.
I have info on what works via an LM327 and I know the pids, but it would
help me for some pointers as to how to do it on the OVMS.
You know - the goal to get the first one working.
Here's an example definition - the SOC of the main battery. This is
extracted from decompiling a definition file for ediasbas/ediasblib:
(The "_EN" text is translated using Google cloud translate so the German is
the original)
The "job" is defined like so:
"SERVICE" : "22",
"ID" : "0xDDBC",
"DIV" : "-",
"INFO" : "aktueller Anzeige Soc",
"RES_TABELLE" : "RES_0xDDBC_D",
"ARG_TABELLE" : "-",
"EINHEIT" : "-",
"DATENTYP" : "-",
"ARG" : "ANZEIGE_SOC",
"LABEL" : "-",
"ADD" : "-",
"MUL" : "-",
"INFO_EN" : "current advertisement Soc",
"L/H" : "-",
"RESULTNAME" : "-",
"NAME" : "-",
"SG_ADR" : "-"
The "results" are defined like so:
"RES_0XDDBC_D" : [
"DIV" : "10.0",
"DATENTYP" : "unsigned int",
"EINHEIT" : "%",
"MASKE" : "-",
"RESULTNAME" : "STAT_ANZEIGE_SOC_WERT",
"L/H" : "high",
"MUL" : "1.0",
"ADD" : "0.0",
"NAME" : "-"
"NAME" : "-",
"ADD" : "0.0",
"MUL" : "1.0",
"L/H" : "high",
"RESULTNAME" : "STAT_MAXIMALE_ANZEIGE_SOC_WERT",
"INFO" : "obere Grenze des Anzeige Soc",
"MASKE" : "-",
"INFO_EN" : "upper limit of the display Soc",
"EINHEIT" : "%",
"DIV" : "10.0"
"RESULTNAME" : "STAT_MINIMALE_ANZEIGE_SOC_WERT",
"L/H" : "high",
"MUL" : "1.0",
"NAME" : "-",
"ADD" : "0.0",
"DIV" : "10.0",
"INFO_EN" : "lower limit of the display Soc",
"EINHEIT" : "%",
"INFO" : "untere Grenze des Anzeige Soc",
"MASKE" : "-"
I read it that three unsigned ints (16 bits each) are returned.
Each is divided by 10 to return a "%".
I traced an app that can retrieves this parameter using an LM327 based OBD2
interface.
That app initialises the LM327 like so:
2020-11-15 10:34:28.831 --> ATD Return all settings to default
2020-11-15 10:34:28.849 --> ATE0 Disable command echo
2020-11-15 10:34:28.861 --> ATH1 Show CAN message headers
2020-11-15 10:34:28.875 --> ATAL Allow long messages
2020-11-15 10:34:28.887 --> ATPBE101 Set programmable param 0x2c to 0xE1,
0x2d to 0x01
- 2c=0xE1:
- 11 bit IDs
- variable data-length code
- 11 or 29 bit received IDs
- use data format ISO 15765-4 (CAN)
- 2d=0x01
- Use rate divisor of 1
2020-11-15 10:34:28.901 --> ATSPB Use protocol USER1 CAN (as set above I
think)
2020-11-15 10:34:28.949 --> ATBI Bypass initialisation - apparently a bad
idea... ?
2020-11-15 10:34:28.964 --> ATSH6F1 Set header bytes to 0x6F1 ( 0x06F1 ? )
2020-11-15 10:34:28.978 --> ATAT0 Disable adaptive timing - wait up to ATSF
time
2020-11-15 10:34:28.992 --> ATSTFF Maximum wait
Then, when it fetches this PID it does the following:
2020-11-15 10:34:35.101 --> ATCRA607⏎ // Listen for
0x607
2020-11-15 10:34:35.114 <-- OK⏎⏎>
2020-11-15 10:34:35.115 --> ATCEA07⏎ // "extended
address" 0x07 [matches 607?]
2020-11-15 10:34:35.127 <-- OK⏎⏎>
2020-11-15 10:34:35.129 --> ATFCSH6F1⏎ // Flow control
header
2020-11-15 10:34:35.141 <-- OK⏎⏎>
2020-11-15 10:34:35.143 --> ATFCSD07300800⏎ // Flow control
data
2020-11-15 10:34:35.156 <-- OK⏎⏎>
2020-11-15 10:34:35.157 --> ATFCSM1⏎ // Flow control
mode
2020-11-15 10:34:35.170 <-- OK⏎⏎>
2020-11-15 10:34:36.367 --> 22␣DD␣BC⏎ // asking for
"extended" PID 0xDDBC
2020-11-15 10:34:36.474 <-- 607␣F1␣03␣7F␣22␣78␣⏎ // this is some
unrelated packet?
2020-11-15 10:34:36.539 <-- 607␣F1␣10␣09␣62␣DD␣BC␣02␣4C␣⏎ // reply -->
0x24C = 588 = 58.8 SOC
607␣F1␣21␣03␣A6␣00␣69␣FF␣FF␣⏎ // 0x03A6 = =
93.4%, 0x0069 = 10.5%
2020-11-15 10:34:37.598 <-- ⏎>
Remember the LM327 takes the sent bytes and wraps with into a full CAN
message - though I'm not sure exactly how that comes out - I presume that
"extended address" goes in somewhere.
--> 22 DD BC is the PID
<-- 2 part reply. First has the SOC. Second has 0x03A6 (934) and 0x0069
(105)
First int is 588 or 58.8% which is the physical SOC of the battery.
934 is 93.4 which is the physical SOC level which the car displays as
"100%" (i3 keeps some headroom "reserved").
105 is 10.5 which is the physical SOC level that the car displays as 0%.
I'd appreciate some help to give me a head-start to be able to retrieve
this attribute on the OVMS box.
Thanks,
Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201212/fdd05966/attachment-0003.htm>
