[Ovmsdev] new metric maintenance distance/days
sharkcow sharkcow at gmx.de
Fri Dec 11 20:32:38 HKT 2020
Thanks for the clarification Michael! I'm still on the (for me pretty
steep:) learning curve... I'll move it to the vehicle info.
sharkcow
Am 11.12.20 um 09:09 schrieb Michael Balzer:
> Sharkcow,
> the point is, this isn't something that needs to be present
> continuously. Live displays should display important momentary status
> data, not long term background info.
> It's totally sufficient to add this to the vehicle info menu.
> Am 10.12.20 um 21:16 schrieb sharkcow:
>> I get your point. How about showing it under the energy counters as
>> attached?
>> If no one objects, I would submit a pull request for the app and ovms
>> with the two new standard metrics.
>> sharkcow
>> Am 08.12.20 um 07:20 schrieb Mark Webb-Johnson:
>>> I would suggest two different metrics. One for distance, one for days.
>>> Perhaps v.service.days and v.service.range? Or v.e.service.days and
>>> v.e.service.range?
>>> N.B. Tesla Roadster also has this (although we haven’t decoded the
>>> CAN bus message for it)
>>> P.S. I am not sure if it needs to be so prominent in the App? It
>>> doesn’t seem that important.
>>>> On 7 Dec 2020, at 10:17 PM, sharkcow <sharkcow at gmx.de> wrote:
>>>> Dear all,
>>>> I would like to suggest a new metric for the distance and days until
>>>> the
>>>> next maintenance is due. This would be one more step for the VW
>>>> e-UP/Mii/Citigo module to convince users to switch from the original VW
>>>> cloud service (which has this feature).
>>>> Attached is a suggestion how the metric could be displayed in the
>>>> Android app (at the very top in front of the car).
>>>> Any comments are most welcome; I would also need some guidance in
>>>> how to
>>>> implement the metric so it is transmitted correctly (if it is
>>>> approved).
>>>> Best wishes,
>>>> sharkcow
>>>> <maintenance.png>_______________________________________________
>>>> OvmsDev mailing list
