[Ovmsdev] lost important event => aborting
Mon Aug 31 17:42:11 HKT 2020
Merge is pushed.
Am 31.08.20 um 10:52 schrieb Mark Webb-Johnson:
> My work is in the public for-v3.3 branch.
>> On 31 Aug 2020, at 4:24 PM, Michael Balzer <dexter at expeedo.de> wrote:
>> I've made a stupid mistake leading to events at least not being
>> forwarded correctly to Duktape, fix is pushed.
>> PS: Mark, your split of the scripting module may not allow easy
>> merging of my two commits. They are simple, but I can do the merge if
>> you push them into a branch.
>> Am 29.08.20 um 15:54 schrieb Michael Balzer:
>>> I think I've found & fixed this, maybe also the events starvation issue.
>>> See
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/418#issuecomment-683286134
>>> and
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/6b709a0cb399d1a7c3866f68d7f9dbf92f9246c8
>>> Please test.
>>> Am 29.08.20 um 10:34 schrieb Michael Balzer:
>>>> I've just found another clue to the events task starvations:
>>>> TL;DR: the events task can be blocked by running lower priority tasks as
>>>> well, not just higher priority tasks.
>>>> So raising the events task priority cannot be the solution.
>>>> Regards,
>>>> Michael
>>>> Am 26.08.20 um 20:28 schrieb Michael Balzer:
>>>>> Am 26.08.20 um 06:17 schrieb Mark Webb-Johnson:
>>>>>> It seems to be a web socket (web ui?) connection went away, a logging
>>>>>> message was produced, and that overflowed the queue. Perhaps the user
>>>>>> is just logging too much? Can you log at debug level to web uI (or
>>>>>> does it cause the problem I mentioned earlier about debug logging the
>>>>>> debug logs)? Any ideas?
>>>>> I haven't been able to get a correlation to any specific configuration
>>>>> or system situation yet on these event queue overflows.
>>>>> The event queue has room for 40 entries by default, so the system
>>>>> normally has been in an overload situation (starved event task) for at
>>>>> least 30-40 seconds when the abort is triggered.
>>>>>> Event: ticker.1 at EventScript 0 secs
>>>>> …tells the events task wasn't completely stuck before the abort, just
>>>>> didn't get a lot of CPU share. That's why I thought raising the task
>>>>> priority could have an effect.
>>>>> I totally need user data on this, as the crash doesn't happen at all on
>>>>> my module. So it's also possible the issue is caused by a vehicle module
>>>>> bug, or by the poller receive bug we discovered a few days ago:
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/405#issuecomment-674499551
>>>>> This is solved now by the merge of the fast polling branch, which
>>>>> includes the fixes for this. So we may see already an improvement with
>>>>> the next build.
>>>>> But there are at least three more bugs/shortcomings in the current
>>>>> poller which can potentially also cause this issue (and others) by high
>>>>> vehicle task load / wrong memory allocations / out of bounds accesses.
>>>>> Which is why I'm currently working on a rewrite of the receiver.
>>>>> Regards,
>>>>> Michael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200831/46fa512f/attachment.htm>
