[Ovmsdev] OBD/UDS Poller receiver rework
Sat Aug 29 03:15:45 HKT 2020
Thanks to Soko (UpMiiGo tests) and Thomas (Smart rewrite & tests).
The Smart code makes extensive use of polling, so we're probably good to go.
If other vehicle maintainers would like to test before merging into the
master, please let me know.
Am 28.08.20 um 15:28 schrieb Soko:
> Hi Michael,
> I can give you a :thumbup: from the UpMiiGo department. First test of
> the changes (including a short drive) showed no issues. Neither with
> the fast-polling nor with the multi-frame-processing with OBDIIEXTENDED.
> thanks
> Soko
> On 27.08.2020 22:00, Michael Balzer wrote:
>> Everyone,
>> I've just pushed the poller receiver changes I announced into the new
>> "poller-rework" branch:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/0b306ad4f5e7a1eb63a471a11ec7f1a6d69d8647
>> OBD/UDS Poller Receiver Rework:
>>   - Fix race condition between CAN RX and PollerReceive
>>   - Separation of ISO-TP & OBD/UDS layer meta data analysis
>>   - Fix incomplete meta data validation
>>   - Allow single/multi frame responses on all service types
>>   - Validate multi frame response sequences
>>   - Fix single frame payload lengths
>>   - Fix type 0x22 first frame payload offset & overall length
>>   - Add negative response code handling → IncomingPollError()
>>   - Add response frame timing control → PollSetResponseSeparationTime()
>> This rework has been on my list for some time before, as the previous
>> solution had some general shortcomings, especially by it's hard coded
>> coupling of the expected response transport form with the request
>> type, which fails already on some type 0x01 requests.
>> The major bug in the receiver that now triggered the rework was in
>> the overall payload length calculation and the first frame payload
>> passing of the type 0x22 (VEHICLE_POLL_TYPE_OBDIIEXTENDED) multi
>> frame response handling. That up to now basically only turned up as a
>> visible issue for the Smart ED, as all other vehicles either don't
>> get multi frame responses on 0x22 queries or (like the Kia) generally
>> discard the first frame and don't use the overall length at all.
>> On the Smart ED, all handlers have been deliberately written assuming
>> the bug was a feature -- all payload addressing is shifted by one
>> byte. This needs to be rewritten now.
>> All other vehicles should not see any difference and should not need
>> to change any code. Except maybe in the UpMiiGo development, which
>> isn't yet part of the master.
>> Other bugs like the missing frame sequence validation and late
>> response detection may have been the causes for some spurious and
>> hard to track crashes and data errors. We should try to get this
>> change tested short term on "edge", so we can see if this actually
>> improves stability as I hope.
>> As this is a major rework (mainly of the PollerReceive() method),
>> audits and tests are very welcome. I can only test on the Twizy,
>> which doesn't make much use of the poller yet.
>> You can see what the new poller does by raising the log level for
>> "vehicle" to debug. Example of some Twizy regular polling:
>> D (136323) vehicle: PollerSend(1): send [type=10, pid=C0], expecting
>> 743/763-763
>> D (136343) vehicle: PollerReceive[763]: process OBD/UDS response
>> 10(C0) frm=0 len=0 off=0 rem=0
>> V (136343) v-twizy: OBD2: ignored reply [10 c0]
>> D (137323) vehicle: PollerSend(1): send [type=21, pid=81], expecting
>> 743/763-763
>> D (137343) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(81) frm=0 len=4 off=0 rem=15
>> D (137373) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(81) frm=1 len=7 off=4 rem=8
>> D (137403) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(81) frm=2 len=7 off=11 rem=1
>> D (137423) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(81) frm=3 len=1 off=18 rem=0
>> D (137433) v-twizy: OBD2: got VIN='XXXXXXXXXXXXXXXXX'
>> D (138323) vehicle: PollerSend(1): send [type=21, pid=13], expecting
>> 743/763-763
>> D (138343) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=0 len=4 off=0 rem=106
>> D (138373) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=1 len=7 off=4 rem=99
>> D (138403) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=2 len=7 off=11 rem=92
>> D (138423) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=3 len=7 off=18 rem=85
>> D (138453) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=4 len=7 off=25 rem=78
>> D (138483) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=5 len=7 off=32 rem=71
>> D (138513) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=6 len=7 off=39 rem=64
>> D (138543) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=7 len=7 off=46 rem=57
>> D (138563) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=8 len=7 off=53 rem=50
>> D (138593) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=9 len=7 off=60 rem=43
>> D (138623) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=10 len=7 off=67 rem=36
>> D (138653) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=11 len=7 off=74 rem=29
>> D (138683) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=12 len=7 off=81 rem=22
>> D (138703) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=13 len=7 off=88 rem=15
>> D (138733) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=14 len=7 off=95 rem=8
>> D (138763) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=15 len=7 off=102 rem=1
>> D (138793) vehicle: PollerReceive[763]: process OBD/UDS response
>> 21(13) frm=16 len=1 off=109 rem=0
>> W (141323) v-twizy: OBD2 Cluster DTC NEW #01: 4/21 rev0 G1 INT MEM
>> Ef|   @ 57871km 11kph SOC=60% BV=14V TC=0 IC=255
>> W (141333) v-twizy: OBD2 Cluster DTC NEW #02: 4/1 rev0 G1 MEM|   @
>> 57892km -1kph SOC=86% BV=14V TC=0 IC=255
>> W (141343) v-twizy: OBD2 Cluster DTC NEW #03: 1/37 rev0 G1 INT MEM
>> Ef|   @ 57892km -1kph SOC=86% BV=14V TC=0 IC=255
>> W (141353) v-twizy: OBD2 Cluster DTC NEW #04: 3/59 rev0 G2 INT MEM|
>> @ 57926km 34kph SOC=78% BV=14V TC=0 IC=255
>> W (141363) v-twizy: OBD2 Cluster DTC NEW #05: 4/40 rev0 G2 MEM Ef|
>> @ 57926km 35kph SOC=78% BV=14V TC=0 IC=255
>> W (141373) v-twizy: OBD2 Cluster DTC NEW #06: 3/58 rev0 G2 INT MEM|
>> @ 58711km 41kph SOC=46% BV=14V TC=0 IC=255
>> A manual multi frame poll:
>> I (147723) webcommand: HttpCommandStream[0x3f8540f4]: 3801804 bytes
>> free, executing: x o r bm 2104
>> D (148323) vehicle: PollerSend(1): send [type=21, pid=4], expecting
>> 79b/7bb-7bb
>> D (148343) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=0 len=4 off=0 rem=70
>> D (148353) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=1 len=7 off=4 rem=63
>> D (148393) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=2 len=7 off=11 rem=56
>> D (148433) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=3 len=7 off=18 rem=49
>> D (148473) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=4 len=7 off=25 rem=42
>> D (148513) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=5 len=7 off=32 rem=35
>> D (148553) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=6 len=7 off=39 rem=28
>> D (148593) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=7 len=7 off=46 rem=21
>> D (148633) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=8 len=7 off=53 rem=14
>> D (148673) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=9 len=7 off=60 rem=7
>> D (148713) vehicle: PollerReceive[7BB]: process OBD/UDS response
>> 21(4) frm=10 len=7 off=67 rem=0
>> OVMS# x o r bm 2104
>> Response:
>> 08 cc 3c 08 d4 3c 08 cb 3c 08 d6 3c 08 ce 3c 08 | ..<..<..<..<..<.
>> d1 3c 08 d2 3c ff ff ff ff ff ff ff ff ff ff ff | .<..<...........
>> ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff | ................
>> ff ff ff ff ff ff ff ff 3c 3c                   | ........<<
>> An example of the new error response handling:
>> I (165023) webcommand: HttpCommandStream[0x3f8479f4]: 3791052 bytes
>> free, executing: x o r bm 221405
>> D (165323) vehicle: PollerSend(1): send [type=22, pid=1405],
>> expecting 79b/7bb-7bb
>> D (165343) vehicle: PollerReceive[7BB]: process OBD/UDS error
>> 22(1405) code=11
>> OVMS# x o r bm 221405
>> ERROR: request failed with response error code 11
>> Code 11 = "serviceNotSupported" (see ISO 14229 Annex A.1 for more codes)
>> Feedback is welcome.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200828/8119f5a4/attachment.htm>
