[Ovmsdev] Refactoring MODEM/SIMCOM for v3.3
    Fri Aug 21 02:53:50 HKT 2020
Good to know you're working on this.
Other modem options may become a necessity sooner than we like, if more
companies follow and extend on that "lite" transmitter station concept
Chris reported… :-/
Am 20.08.20 um 15:35 schrieb Mark Webb-Johnson:
> I have started the work on refactoring the modem driver to support
> virtual driver implementations (SIMCOM 5360 being just one of them).
> This is a major refactoring that will take some time to complete. It
> is likely that the following components/files will be affected:
>   * Component simcom (major changes)
>   * New component ovms_modem introduced
>   * ovms_webserver/dev/commands.htm
>   * ovms_webserver/src/web_cfg_init.cpp
>   * ovms_webserver/src/web_cfg.cpp
>   * Component powermgmt
>   * And several other components mentioning Simcom, but only very
>     minor changes
> I would appreciate it if no major changes were made to those
> components in the next week or two, as that may make merging difficult.
> Once I’ve got the modem code refactored, and a compatible SIMCOM 5360
> driver working, I’ll publish to the for-v3.3 branch for wider testing.
> I can then add the other modem drivers I have been working on.
> P.S. Pretty obvious that this work is to abstract out the modem type
> specific code, to make it easier to add support for other modem types
> in OVMS. This is a long-term project, and not something happening
> anytime soon, but I am working on it.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200820/c194d043/attachment.htm>
