[Ovmsdev] Weirdest value conversion ever
Soko ovms at soko.cc
Tue Aug 18 16:34:06 HKT 2020
Thanks Michael,
A lot of options to check out here, great!
After reading my email again I had a light bulb moment which relates to
your 100/255 factor example. I thought what if they wanted to make the
maximum number a (kinda) nice value. So I gave math a try and found that
a factor of (2^32/2)/250200 works perfectly for the kWh values. So they
may have said 250200 kWh is the maximum value we want to represent with
4 bytes. 250000 would have been more nice but it doesn't give me the
VCDS values. Having said that: If VCDS does also reverse engineering
maybe they got it wrong ;) Or do they pay VW for the data?
I've also made a copy the VCDS Runtime and all files. But I can't
believe that they would put such crucial info in an XML file or
something similar. I reckon you need a disassembler at least...
Soko
On 18.08.2020 10:05, Michael Balzer wrote:
> Soko,
> sometimes values are encoded in two parts, for example a 32 bit value
> may consist of a 20 bit part + a 12 bit part, with different scaling
> on each part (low + high resolution).
> Scaling factors also can be non-intuitive, even the OBD2 standard
> includes factors like 100/255. Internal values like these may be
> multiples of some odd current sensor resolution.
> If (!) bit chunked parts represent integer and fractional parts of the
> value, you may get more insight if you catch a change from (x).999 to
> (x+1).000. Be aware three fractional digits may be a rounded
> representation.
> Another option to check is the VCDS software. These systems normally
> are rule based, so if you can find the rule set, you may be able to
> find the value conversion scheme.
> Yet another option is to send crafted fake values to the VCDS to see
> how they translate.
> Am 18.08.20 um 09:36 schrieb Soko:
>> Morning,
>> Sorry, I reckon I've been at it for too long and did imply a lot of
>> things which are not obvious for someone who didn't do it a million
>> times already (as it feels to me :/ ). Let's do it step by step and
>> (hopefully) my error is somewhere in the early steps...
>> I have OVMS (no polls active) and VCDS connected to the OBD port via
>> a Y cable. In OVMS I turn the canlog on so I can see what VCDS is
>> sending...
>> In VCDS I go into the 8C ECU and choose "Erweiterte Messwerte". There
>> I have a list of all values which I can activate so VCDS polls it
>> from the ECU. VCDS polls/refreshes those chosen values roughly 10
>> times a second.
>> So I activate AmpHrs charged and discharged, and KwH charged and
>> discharged from the list (4 values in total). VCDS shows me the final
>> converted values on the screen:
>> OVMS logs the following on the bus:
>> As far as I understand it are the red lines the polls by VCDS (as
>> they are 7E5=the header of the ECU) and the green lines are the
>> replies. I don't understand the red "7E5 30..." line but I reckon its
>> just like a "Please give me the rest of the data".
>> All 4 values are in the same PID "1E 32" (red, bold and underlined
>> above). And the green lines, the bold and underlined HEX values are
>> the actual data with the last "aa" being no part of it.
>> This is my procedure to get the data bytes from the canlog-monitor
>> lines...Maybe here is my first error somewhere?!
>> So I have 16 bytes in total to get the 4 values VCDS is showing me:
>> *00 09 de e1 ff f6 53 21 00 31 62 92 ff d0 88 04*
>> Simplicity and the value-Ids (some internal numbers) in the list of
>> VCDS suggest that same order as given above. So the first 4 bytes is
>> AmpHrs Chrg, than AmpHrs Dischrg and so on. This leads us to this
>> relation:
>> I've also confirmed this by waiting (with ignition on) until the last
>> fraction of AmpHrs/kWh discharged values where changing in VCDS to
>> -1154,307 and -362,448 and comparing it with the changed hex values.
>> These hex numbers changed:
>> *00 09 de e1 ff f6 53 2_/0/_ 00 31 62 92 ff d0 88 0_/3/_*
>> Having said that: Not every change in the hex value changes the
>> display value. I have more detail data to this if needed...
>> The way they change suggests 2's complement storage. So let's convert
>> them into integers:
>> Now, for kWh Dischrg as an example, the factor to get from -3110908
>> to -326,447 is: -3110908/-362,447=8583,07007645256. This is a weird
>> one as all the other factors so far have been nice numbers!
>> If I do this for all 4 values I get these factors:
>> This cannot be right and therefore a waited a few weeks and did
>> everything above again. The result was the same unfortunately:
>> Some other values have an offset. Like the power-efficiency on the
>> charger-ECU. The value=0x00 means 75% and 0x06 means 75,6%. It's a
>> quite clever way of using just one byte for this value!
>> So I thought they use some offset here to. But if I take the delta of
>> both days I logged I get the same factors:
>> For AmpHrs Chrg the first value was 1177,611 and the value week later
>> was 1424,809 which gives the delta of 247,198.
>> So now I'm really out of ideas and thought I ask you guys. As you can
>> see all conversion factors are close to each other but not exactly
>> the same. And given that the VW engineers are quite clever I can't
>> accept they would use such weird factors for a conversion.
>> If you have now another look at the one screenshot I took in my first
>> mail you should understand it as it is just the complete version of
>> the bits I did here...
>> Any ideas are highly welcome.
>> Soko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0014.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0015.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0016.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0017.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0018.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0019.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/53001515/attachment-0020.png>
