[Ovmsdev] New pull requests pending
Mon Aug 17 11:39:54 HKT 2020
I see the discussion on the pull request itself is happening on the pull request and Michael is assisting.
Regarding the process, I think in general we need to keep the core system stable and it is best not to commit partial implementations. I myself sometime violate that rule, but try not to. The better approach is to create a branch and do the work there (committing and sharing to others as you wish). Then, when all is done and ready, you can merge that branch in to master and submit a pull request. These branches can be either local (private) or on your GitHub clone (public). In rare cases, we also publish branches on the main openvehicles GitHub repository (for example, the SPIRAM branch that was there for a year before merging to master, and the upcoming 3.3 branch I am about to create for the changes to move from v3.2 -> v3.3).
> On 14 Aug 2020, at 5:18 PM, Soko <ovms at soko.cc> wrote:
> I see the point in not having unfinished code in the master so I removed my OBD implementation from this pull request.
> Whats left is just the same source as before but with preparation for the OBD part.
> @others: Please let me know your thoughts
> On 14.08.2020 10:56, Chris van der Meijden wrote:
>> I agree on not further discussing this. I made my point.
>> Chris
>> Am Freitag, den 14.08.2020, 10:02 +0200 schrieb Soko:
>>> I'm not quite sure if we should discuss this here or in the pull request itself. Maybe Mark or Michael should say whats best. Anyhow... Let me put you to ease with my answers below...
>>> On 14.08.2020 09:18, Chris van der Meijden wrote:
>>>> Hey Soko,
>>>> sorry I don't agree on this pull request.
>>> Just to make things clear with the other guys: You are talking about one of the pull requests, the one with the source split.
>>>> We have already discussed this.
>>>> Lets put this straight. My code for the T26A part is not ready yet. Climate control is still very buggy and it would confuse the user to have such a buggy feature within a possible OVMS release. It will take me probably a week or two, maybe longer, to get the climate control fixed. Then we can do a pull request to the master.
>>> The T26A code in my pull request is not the one from your fork. It's the one that is officially in the master branch of openvehicles. So nothing changes for the user and not one source line is different then before.
>>>> An other point we also talked about, is that you have not documented your OBD part at all. This is also not acceptable. You can't put features with in the official OVMS repository that are not documented at all. How does the user use your VW e-Up OBD part? What hardware is needed? Where does the user see the results in the webfrontend? Does the app work with your code? ...
>>> The user is not able to use any of the OBD code as pointed out in the pull request description. This is more an esthetic question as the code is not active. If the others feel the same I can remove my obd_*.* files from the pull request. The outcome is the same...
>>>> You can't put unready code in the master.
>>>> That is the reason why we use forks. We merge a fork when we have kind of stable code with features that are well documented.
>>>> This is not the case at the moment with the splitted VW e-Up code.
>>> To sum up: Nothing at all changes for the user with me my pull request. Well... besides the name of the VW e-Up vehicle. But is taken care of in the upgrade method.
>>> I even prepared everything so you have it as easy as possible when this pull request is put into the master: When you pull it your fork you only have to backup your three t26_*.* files from your fork. Then just take 1:1 the openvehicles-master and put your backup back.
>>> At least that's how I would do it as I'm not familiar how this is done in git directly ;)
>>>> Regards
>>>> Chris
>>>> Am Freitag, den 14.08.2020, 07:06 +0200 schrieb Soko:
>>>>> Hey guys,
>>>>> Just want to let you know on this way as well about the two pull
>>>>> requests I have opened yesterday.
>>>>> Let me know your thoughts. Would be cool if they will be merged very
>>>>> soon so I can continue my work on the VW e-Up.
>>>>> regards,
>>>>> Soko
>>>>> OvmsDev mailing list
>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200817/f1a0fd92/attachment.htm>
