[Ovmsdev] CAN callbacks / VW e-Up read/poll via OBD is working
Soko ovms at soko.cc
Sun Aug 9 20:13:27 HKT 2020
Thanks Michael,
With my current knowledge of the behavior of  the eUp I don't think this
will help. Reason: When the polls are too frequent the car will never
shut down. So the only possibility is to use the 12V voltage level to
see if the 12V battery is charging or not.
I will go forward now and put some usable features into the source. I
will go and have a VCDS session tomorrow (hopefully) to see what it is
doing and to sniff the ExtendedDiagSession messages which it hopefully uses.
Soko
On 09.08.2020 13:04, Michael Balzer wrote:
> UpMiiGo guys,
> Am 30.07.20 um 14:43 schrieb Soko:
>> Can I somehow get called (in my vehicle-class) if an can-error is thrown?
> Am 30.07.20 um 16:17 schrieb Michael Balzer:
>> CAN tx errors can be caused by other issues as well, so should
>> generally not be interpreted that way.
> According to Chris on the GE forum, you're also seeing CAN tx errors
> on the Komfort CAN bus, so maybe it actually makes sense for you to
> check for CAN errors.
> There are two options:
>  1. Register a TX callback for a specific TX frame
>  2. Register a general TX callback
> _
> Option 1_ is currently not supported by the poller framework (but
> could be added). For a manual frame transmission, simply set the frame
> callback pointer to your handler:
> static void CAN_tx_callback(const CAN_frame_t* frame, bool success){
>   if (!success) {
>     // tx failure
>   CAN_frame_t txframe;
>   txframe = {};
>   txframe.MsgID = 0x705;
>   txframe.FIR.B.DLC = 8;
>   txframe.data = { 0x…, 0x…, … };
>   txfrane.callback = CAN_tx_callback;
>   txframe.Write(m_can3);
> _Option 2_ uses the same handler signature. A handlers is registered
> as a general callback like this, e.g. on vehicle init:
>     MyCAN.RegisterCallback(TAG, CAN_tx_callback, true);
> You can also register an RX callback by passing "false" or omitting
> the third argument. On unloading the vehicle module, simply do:
>     MyCAN.DeregisterCallback(TAG);
> CAN callbacks are called directly within the CAN driver context prior
> to all standard queues, so can be used for very fast CAN responses --
> and thus need to be very fast too, to not affect CAN driver
> throughput. Don't do any complex processing in the handler, avoid
> anything that could block the task.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200809/823b4cfb/attachment.htm>
