[Ovmsdev] Polling keeps car awake (VW e-Up at least)
Sun Aug 9 04:12:17 HKT 2020
Am 08.08.20 um 20:23 schrieb Soko:
> OK, thanks heaps. Just to clarify: So if I know my session code I
> replace your 0xC0 with it, correct?
Yes.
> Is this session code global for all ECUs and static? The wiki link for
> UDS speaks about different sessions...
Yes and no. There are standard codes, but they need not apply. See the
PDF I sent you on diagnostic sessions.
> Does this one source code line also take care about the "tester
> present" message?
Yes. You either do a login and keep that active by sending "tester
presence", or repeat the login. See the PDF I sent you on tester presence.
> Your pacience with me is highly appreciated :)
> Soko
> On 8 August 2020 19:47:45 CEST, Michael Balzer <dexter at expeedo.de> wrote:
>     Soko,
>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_renaulttwizy/src/rt_obd2.cpp#L64
>     as simple as that. But you need to know the session code you need
>     to use for the gateway. 0xC0 is in the manufacturer specific range.
>     I would test the gateway behaviour using manual CAN commands, a
>     script or a web plugin. That way you're much more flexible.
>     Regards,
>     Michael
>     Am 08.08.20 um 19:09 schrieb Soko:
>>     Hmmm... ok lets forget the 2nd log and talk about the first one.
>>     It must somehow be related to OVMS though as the replies get in
>>     immediately I swap the poll states. If I change the threshold
>>     from 5 secs to 3 or to 6 its always the same: once the poll state
>>     swaps the replies come in. So it must be related to the poll stat
>>     switch. The canlog shows all polls look the same... so the
>>     gateway must get confused every time exactly when the threshold*4
>>     is over?
>>     Hmmm... or maybe the gateway gets confused after a certain number
>>     of polls. So the threshold doesnt matter.
>>     When I change the factor 4 to i.e. 6 I could validate this
>>     hypothesis.
>>     Havent had time for session implementation yet.
>>     Is there a OVMS framework for a tester session? Or at least a
>>     vehicle implementation which does it?
>>     On 8 August 2020 16:58:25 CEST, Michael Balzer
>>         Soko,
>>         lines 33 and 34 of your second log are due to the CAN TX
>>         buffer, which seems to have held back the frame until the bus
>>         became available.
>>         Besides that, I don't see an RX in that log after switching
>>         the polling state. So I assume the RX in your first log also
>>         isn't related to the poll state switch.
>>         There is an RX buffer, but that's just the internal queue of
>>         the vehicle CAN listener task. There is no delay on the
>>         processing unless you block the task somehow, for example by
>>         doing long term loops / communication in that context (which
>>         you shouldn't do).
>>         You still don't send a session login or tester presence, so
>>         maybe the gateway is simply confused by the requests, runs
>>         into some timeout, then restarts… something like that.
>>         Regards,
>>         Michael
>>         Am 08.08.20 um 13:20 schrieb Soko:
>>>         Soooo....
>>>         I've finally found time to test this again.
>>>         Basically the same behaviour as described below.
>>>         *VWUP_OFF_TICKER_THRESHOLD 5 with 4 trys.log*
>>>         Car was locked initially. Unlocked the car before line 21
>>>         (around time mark 60.000). Locked around time mark 80.000.
>>>         Car stayed responsive until line 108 (time mark 100.000).
>>>         At line 130 (tm=116.814) I swap back to PollState=0. The
>>>         poll for PollState=0 gets an immediate reply (line 131-133)
>>>         and therefore I swap back to PollState=1.
>>>         The weird thing is that line 132 (which got a reply) is
>>>         exactly the same as 126 (or 118 or 110) which didn't get a
>>>         reply!?!? So the car has no idea of the poll states as the
>>>         data is the same? There must be some issue/bug/behavior
>>>         inside OVMS (maybe even in the hardware buffer) which gets
>>>         triggered by a PollState change. Or the canlog-monitor uses
>>>         somehow a cache and doesn't show the messages immediately.
>>>         *VWUP_OFF_TICKER_THRESHOLD 10 with 4 trys.log*
>>>         Same as below. One thing I've noticed though: Car was locked
>>>         until line 32 (tm=63.814). Then I've unlocked it and the
>>>         lines 33 and 34 showed up immediately. This indicates a
>>>         buffer/cache/etc. issue with the canlog-monitor as well (imho).
>>>         Soko
>>>         On 03.08.2020 13:10, Michael Balzer wrote:
>>>>         Soko,
>>>>         I don't see any obvious mistakes on a first check.
>>>>         Please do the tests again with CAN monitoring, so we can
>>>>         see what's actually going on on the bus.
>>>>         An OBD device normally logs into the device sending a UDS
>>>>         diag session command (0x10), then keeps that session alive
>>>>         by sending tester present (0x3E) evers 30-60 seconds. See
>>>>         the UDS documentation I sent you, or for an overview, see
>>>>         https://de.wikipedia.org/wiki/Unified_Diagnostic_Services
>>>>         You should be able to get the session type and protocol by
>>>>         logging what your VCDS does on the bus.
>>>>         Regards,
>>>>         Michael
>>>>         Am 03.08.20 um 06:19 schrieb Soko:
>>>>>         Mornin,
>>>>>         Source is here:
>>>>>         https://github.com/devmarxx/Open-Vehicle-Monitoring-System-3/tree/master/vehicle/OVMS.V3/components/vehicle_vweup/src
>>>>>         Attached are two logs. I haven't had the can-monitor
>>>>>         active unfortuantely..
>>>>>         As the name says it polls every 5 seconds in PollState=1
>>>>>         and swaps back to PollState=0 after 5*4=20 seconds.
>>>>>         Until line 35 you see the CAN errors as the vehicle is
>>>>>         OFF. Then I unlocked the car and in line 38 I get the
>>>>>         first reply.
>>>>>         Around line 90 I locked the car again. It polls, but gets
>>>>>         no reply, _but not error either_ (?!).
>>>>>         Line 118 sets the PollState=0 and suddenly a response
>>>>>         comes in. So in Line 123 I set the PollState=1 again.
>>>>>         The the game starts again: Polls get send, no reply but no
>>>>>         error either. After 21 CarOffTickers I switch to
>>>>>         PollState=0 and suddenly a reply comes in...
>>>>>         *Here I unlocked at line 57 and locked around line 100.
>>>>>         After that polls get send, no reply, _but errors happen_.
>>>>>         And the car is finally off.
>>>>>         Although I've tried the same thing later that day and the
>>>>>         car didn't even go to sleep with Threshold=30!?!? So the
>>>>>         behavior is not 100% reproducible (yet)...
>>>>>         @gateway throttling: In VCDS (which - hopefully - does
>>>>>         only polling too) I have a little number showing me the
>>>>>         refresh rates of the values. It indicates ~8 refreshes per
>>>>>         second. So with 1 second shouldn't be any throttling.
>>>>>         @OBD "tester": I have no clue what this is ;) So if the
>>>>>         polling framework doesn't do it, I don't do it. All I do
>>>>>         is in the obd_eup.* files.
>>>>>         Soko
>>>>>         On 02.08.2020 20:12, Michael Balzer wrote:
>>>>>>         Soko,
>>>>>>         polling may keep the car awake, that's also an issue on
>>>>>>         the Kia e-Niro IIRC.
>>>>>>         Changing the PollState can only affect the car indirectly
>>>>>>         via the changed polls. Maybe you could add your code & a log?
>>>>>>         Regarding the poll replies stopping, is that also
>>>>>>         reflected in a CAN log? Maybe the OBD gateway throttles
>>>>>>         if it sees too many requests? (Hopefully not…)
>>>>>>         If the gateway does throttling: do you login to the OBD
>>>>>>         as a "tester" and keep the session active by periodically
>>>>>>         sending the "tester present" frame?
>>>>>>         Regards,
>>>>>>         Michael
>>>>>>         Am 02.08.20 um 19:30 schrieb Soko:
>>>>>>>         Heya again,
>>>>>>>         I'm trying to develop a detection for when the car is
>>>>>>>         off/locked but I'm encountering a weird phenomena:
>>>>>>>           * Car is shut down and locked
>>>>>>>           * OVMS connected
>>>>>>>           * CAN poll for voltage (only one poll value active)
>>>>>>>             with 30 secs fails with error (so far nothing weird)
>>>>>>>           * Unlock the car via car-key remote
>>>>>>>           * Poll succeeds and I'm switching from PollState=0 to
>>>>>>>             PollState=1 where I poll every 2 secs
>>>>>>>           * Lock the car via car-key remote
>>>>>>>           * _After 1 hour the polls still work and the car is
>>>>>>>             active_
>>>>>>>         Is something like this known from other vehicles? So
>>>>>>>         basically my car never shuts down :(
>>>>>>>         Another secondary weird thing:
>>>>>>>         When increasing the time to 5 secs for PollState=1 the
>>>>>>>         polls get no reply and after 20 secs I swap back to
>>>>>>>         PollState=0.
>>>>>>>         BUT the second the PollState changes the car replies
>>>>>>>         again...
>>>>>>>         Even more weirdness: When PollState=1 time is 10 secs
>>>>>>>         and I swap back to Pollstate=0 after 40 secs the same
>>>>>>>         thing happens! Immediately I swap to PollState=0 the car
>>>>>>>         replies again.
>>>>>>>         As if the PollState switching somehow wakes the car up??!
>>>>>>>         Any ideas?
>>>>>>>         Soko
>>>>>>>         _______________________________________________
>>>>>>>         OvmsDev mailing list
>>>>>>>         OvmsDev at lists.openvehicles.com
>>>>>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>         Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>         Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200808/4525112a/attachment.htm>
