[Ovmsdev] Android Studio first-time setup
Derek Caudwell
d.caudwell at gmail.com
Fri Aug 21 03:42:41 HKT 2020
Ok, so with a bit of trial and error on Android Studio for Windows I have
got to the point it will build the Apk successfully.
In case it assists others here are the steps I took (not all may be
necessary):
Under Tools | SDK Manager select Android Pie API level 28
Also check under Tools | SDK Manager | SDK Tools that Android SDK Build -
Tools and Android SDK Platform - Tools are selected.
Under gradle scripts create a gradle.properties file with the following:
android.useAndroidX=true
android.enableJetifier=false
This step removed the AndroidX build dependency requirement error.
However, doing so then creates build dependency errors on pre-AndroidX
libraries.
Under Settings | Required Plugins select Android APK Support and
Android Support.
The normal Build process should then complete without any errors.
regards
Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200821/17a86f41/attachment.html>
