[Ovmsdev] VW e-Up read/poll via OBD is working
Thu Aug 13 01:18:25 HKT 2020
Chris,
yes, that would do. But…
a) you shouldn't overwrite the vehicle name, that's a user
configuration, and
b) if you would overwrite the vehicle name, you would set "name" in
"vehicle", not "vehicle.name" in "auto" (which doesn't exist).
Am 12.08.20 um 18:59 schrieb Chris van der Meijden:
> Hi Michael
> I found some time for the "hanging upgrade" issue since we splitted
> the vehicle ID from VWUP to VWUP.T26 and VWUP.OBD.
> Would this code in ovms_config.cpp within OvmsConfig::upgrade()
> prevent the "hanging" after an upgrade?
> // Migrate vehicle ID VWUP to VWUP.T26
> if (GetParamValue("auto", "vehicle.type") == "VWUP")
> SetParamValue("auto", "vehicle.type", "VWUP.T26");
> SetParamValue("auto", "vehicle.name", "VW e-Up (Komfort CAN)");
> If so, I would put that in a pull request as soon as we have a new
> "release worthy" version?
> Thanx for checking.
> Greetinx
> Chris
> Am Freitag, den 31.07.2020, 11:34 +0200 schrieb Michael Balzer:
>> Chris,
>> the framework shouldn't get stuck if a vehicle cannot be loaded, it
>> should fall back to booting without a vehicle. I'll have a look at that.
>> Btw, to automatically update user configurations, you can extend
>> OvmsConfig::upgrade(). Users shouldn't need to take care of special
>> update preparations.
>> Am 31.07.20 um 11:05 schrieb Chris van der Meijden:
>>> Welcome to my trial and error T26A world :-))
>>> This morning I flashed the new T26A/OBD version to my OVMS. After
>>> the OTA flash the device did not come back to the networks. Only USB
>>> terminal access was left.
>>> The reason was, that I did no remove the old vehicle config "VWUP"
>>> before flashing and rebooting. The new image has "VWUP.T26" and
>>> "VWUP.OBD" as vehicle config, but no more "VWUP". So the device
>>> could not find its vehicle config and got stuck.
>>> From the USB terminal I bootet back to OTA_0, said in the vehicle
>>> config that my vehicle was a Nissan Leaf and then booted back to
>>> OTA_1. The device came up with the new firmware and I could change
>>> the vehicle config to "VWUP (Komfort CAN)".
>>> Everything is now running fine ...
>>> I will write this down in the documentation for the e-Up.
>>> Greetinx
>>> Chris
>>> Am Freitag, den 31.07.2020, 09:50 +0200 schrieb Michael Balzer:
>>>> Soko,
>>>> you only had the door open, but not turned on the car? If there are
>>>> additional buses, they may be switched off until the car is turned on…
>>>> The OBD connector scheme is the general pin assignment, I meant the
>>>> specific VW e-Up schematics. But if you don't see any voltages with
>>>> the car turned on, that's bad news.
>>>> There may still be some command interface for the OBD gateway to
>>>> enable live data, but without any info about the gateway, it will
>>>> be hard to even find out how to address it.
>>>> Regards,
>>>> Michael
>>>> Am 31.07.20 um 09:06 schrieb Soko:
>>>>> Hey guys,
>>>>> If I did nothing wrong I have bad news:
>>>>> @Michael:
>>>>> With OBD port schematics I think you mean this
>>>>> https://en.wikipedia.org/wiki/On-board_diagnostics#OBD-II_diagnostic_connector
>>>>> Specifically if there are some other pins used than the standard
>>>>> CAN pins 6 and 14.
>>>>> So I had the drivers door open, no key in ignition and measured
>>>>> the voltages of all pins in relation to pin 5 (signal ground).
>>>>> There is no voltage on any pin besides 2.5V on 6 and 14, and 12V
>>>>> on 16 of course. So there are no hidden CAN buses (or any other
>>>>> signals) afaict.
>>>>> @Mark:
>>>>> Thanks for the hint with the can log. It's way easier than RE
>>>>> Tools for just checking if there is any traffic.
>>>>> Having said that... there is no traffic whatsoever besides what I
>>>>> am polling and the reply. Even when ignition is on I only see the
>>>>> poll and the reply on the can log
>>>>> So it seems devmarxx was right: The gateway shields everything and
>>>>> there are even no other hidden signals on the OBD port.
>>>>> I'm happy to try any other ideas you guys have. Just let me know!
>>>>> Soko
>>>>> On 31.07.2020 02:11, Mark Webb-Johnson wrote:
>>>>>> If you are just looking for traffic on the CAN bus, a simple can
>>>>>> log would be the easiest. Assuming you are on USB console, it is:
>>>>>> OVMS# log level verbose canlog-monitor
>>>>>> OVMS# can log start monitor crtd
>>>>>> If you are using ssh, you need to add a:
>>>>>> OVMS# log monitor yes
>>>>>> To stop the logging:
>>>>>> OVMS# can log stop
>>>>>> Documentation here:
>>>>>> https://docs.openvehicles.com/en/latest/crtd/can_logging.html
>>>>>> For my work, I personally prefer this arrangement:
>>>>>> OVMS# can log start tcpserver transmit gvret-b :23
>>>>>> And then I use SavvyCAN <https://www.savvycan.com/> on a laptop
>>>>>> to connect over wifi and work.
>>>>>> Regarding the ‘re’ system, it is a work-in-progress, and not
>>>>>> currently documented. It is still kind of a mess at the moment
>>>>>> (particularly for multiplexed message IDs), as I continue to work
>>>>>> on DBC integration. That said, it is basically functional.
>>>>>> To start it:
>>>>>> OVMS# re start
>>>>>> To stop it:
>>>>>> OVMS# re stop
>>>>>> To see discovered IDs:
>>>>>> OVMS# re list
>>>>>> It will (by default) listen on all open CAN buses, and show you
>>>>>> the discovered ID, message count, interval (in ms), and last
>>>>>> message seen.
>>>>>> It has some rudimentary ability to monitor active polling
>>>>>> protocols with ‘re obdii extended <min> <max>’ (or standard),
>>>>>> specifying the range of IDs used by the ECUs.
>>>>>> Regards, Mark
>>>>>>> On 30 Jul 2020, at 11:56 PM, Soko <ovms at soko.cc
>>>>>>> <mailto:ovms at soko.cc>> wrote:
>>>>>>> @devmarxx: Is there any doc/guide on how to use this RE Tools?
>>>>>>> @Michael: Yeah, I know. You would have done my 1-day work in 5
>>>>>>> mins. I know C++ but I don't know the OVMS framework. But its
>>>>>>> like with any project: The issue is not the language, its the
>>>>>>> framework.
>>>>>>> Until you have yours you have to settle with me unfortunately ;)
>>>>>>> My cousin has a working VCDS HEX interface and I have an
>>>>>>> y-adapter so I can listen with an ELM327 adapter to the commands
>>>>>>> VCDS is sending. Maybe I can find any car status there. Device
>>>>>>> 09 is a good hint.
>>>>>>> But as you said: I have still have to poll this, even if I find
>>>>>>> a status.
>>>>>>> I can't say (of course) if there's another CAN bus @ OBD port.
>>>>>>> All this CAN/OBD/Bus stuff is completely new to me.. ModBus
>>>>>>> RTU/TCP, MBus etc. I would know ;)
>>>>>>> So if you can point me in any direction what to try - or what
>>>>>>> you would do - I happy to dig into it.
>>>>>>> Soko
>>>>>>> PS: Any idea when you'll get your Mii?
>>>>>>> On 30.07.2020 17:14, Michael Balzer wrote:
>>>>>>>> If only I had my Mii already…
>>>>>>>> If the OBD port is shielded from the CAN traffic, you need to
>>>>>>>> poll some device. ECU = Engine Control Unit = device 01.
>>>>>>>> I would suspect the basic car status info to be available from
>>>>>>>> device 09 (central electrics), but it seems no PIDs have been
>>>>>>>> RE'd from there yet. So maybe you need to derive the info from
>>>>>>>> some other mode/status register.
>>>>>>>> It's bad needing to continuosly poll to get the live status
>>>>>>>> data. Is possibly another, unfiltered CAN bus available at the
>>>>>>>> OBD port?
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 30.07.20 um 16:43 schrieb Soko:
>>>>>>>>> Ahhh OK, I've found OvmsVehicle::virtual void
>>>>>>>>> TickerXXX(uint32_t ticker);
>>>>>>>>> Got it! This was exactly my issue as I didn't know about any
>>>>>>>>> function which gets called regularly so I could check
>>>>>>>>> something like this...
>>>>>>>>> It's not an ideal situation though: I just can slow down the
>>>>>>>>> poll after my fail-counter gets too high as I need to check
>>>>>>>>> when the car gets powered again. So all I can do is polling,
>>>>>>>>> lets say every 60 secs when the car is off, and increase it
>>>>>>>>> once its on. But there is now way around this 60-sec polling
>>>>>>>>> if the only thing I can do is poll :(
>>>>>>>>> Afaik there is only the sharkcow's list below, reverse
>>>>>>>>> engineered by him from ODBeleven.
>>>>>>>>> (dev)marxx exlpained to me: There is a gateway between the
>>>>>>>>> CAN-Buses and the OBD Connector in all VW-AG vehicles which
>>>>>>>>> only replies to polls and also acts as security gateway if you
>>>>>>>>> want to write to the buses.
>>>>>>>>> So I think I cannot really do a can log or use re tool as the
>>>>>>>>> OBD interface stays quiet if I'm not polling it...
>>>>>>>>> And as there is no other vehicle from VW,Seat,Skoda,Audi,etc.
>>>>>>>>> in OVMS. So I have no cheat-sheet :(
>>>>>>>>> Anyhow... I would need to poll one ECU (is this the correct
>>>>>>>>> therm?) which doesn't shuts down... or maybe the issue is the
>>>>>>>>> OBD-gateway shutting down.
>>>>>>>>> What do you think?
>>>>>>>>> Soko
>>>>>>>>> On 30.07.2020 16:17, Michael Balzer wrote:
>>>>>>>>>> Soko,
>>>>>>>>>> nice progress :-)
>>>>>>>>>> If you can't detect vehicle state by listening to regular
>>>>>>>>>> status CAN frames, you can check the time since the last poll
>>>>>>>>>> reply in the per second ticker.
>>>>>>>>>> As poll replies normally come in fast, you should be able to
>>>>>>>>>> detect a switch-off by a small timeout, say 3 seconds…
>>>>>>>>>> probably need to add a counter, as a single poll may get lost
>>>>>>>>>> / ignored.
>>>>>>>>>> CAN tx errors can be caused by other issues as well, so
>>>>>>>>>> should generally not be interpreted that way.
>>>>>>>>>> But… are you sure there are no status frames on the bus? Have
>>>>>>>>>> you done a can log or tried the re tool?
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 30.07.20 um 14:43 schrieb Soko:
>>>>>>>>>>> Hi guys,
>>>>>>>>>>> Want to report success on connecting and reading my VW e-Up
>>>>>>>>>>> via OBD cable using the Poller. As you can see in the
>>>>>>>>>>> screenshot of the log attached I get an
>>>>>>>>>>> IncomingPollReply(..) call and an SoC value of 33.333%
>>>>>>>>>>> Once I turn of the ignition and lock the car though I don't
>>>>>>>>>>> get any replies no more (line D 793813) and then I get can1
>>>>>>>>>>> errors... I'm polling with 10 seconds intervall.
>>>>>>>>>>> I know that this is as it should be... but my issue is: I
>>>>>>>>>>> don't have any way to know if the ignition is on, the key is
>>>>>>>>>>> in, the car is running, the car is charging as the PIDs are
>>>>>>>>>>> not known for such values (afaik by the lists of sharkcow
>>>>>>>>>>> https://www.goingelectric.de/wiki/Liste-der-OBD2-Codes/).
>>>>>>>>>>> So what would be the best approach to change the different
>>>>>>>>>>> polling states? Can I somehow get called (in my
>>>>>>>>>>> vehicle-class) if an can-error is thrown? Then I would
>>>>>>>>>>> increase the poll frequency.
>>>>>>>>>>> Any suggestions?
>>>>>>>>>>> thanks
>>>>>>>>>>> Soko
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>> <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200812/52324e8a/attachment-0001.html>
