[Ovmsdev] Polling keeps car awake (VW e-Up at least)
Soko
ovms at soko.cc
Sun Aug 9 01:09:10 HKT 2020
Hmmm... ok lets forget the 2nd log and talk about the first one.
It must somehow be related to OVMS though as the replies get in immediately I swap the poll states. If I change the threshold from 5 secs to 3 or to 6 its always the same: once the poll state swaps the replies come in. So it must be related to the poll stat switch. The canlog shows all polls look the same... so the gateway must get confused every time exactly when the threshold*4 is over?
Hmmm... or maybe the gateway gets confused after a certain number of polls. So the threshold doesnt matter.
When I change the factor 4 to i.e. 6 I could validate this hypothesis.
Havent had time for session implementation yet.
Is there a OVMS framework for a tester session? Or at least a vehicle implementation which does it?
On 8 August 2020 16:58:25 CEST, Michael Balzer <dexter at expeedo.de> wrote:
>Soko,
>lines 33 and 34 of your second log are due to the CAN TX buffer, which
>seems to have held back the frame until the bus became available.
>Besides that, I don't see an RX in that log after switching the polling
>state. So I assume the RX in your first log also isn't related to the
>poll state switch.
>There is an RX buffer, but that's just the internal queue of the
>vehicle
>CAN listener task. There is no delay on the processing unless you block
>the task somehow, for example by doing long term loops / communication
>in that context (which you shouldn't do).
>You still don't send a session login or tester presence, so maybe the
>gateway is simply confused by the requests, runs into some timeout,
>then
>restarts… something like that.
>Regards,
>Michael
>Am 08.08.20 um 13:20 schrieb Soko:
>> Soooo....
>> I've finally found time to test this again.
>> Basically the same behaviour as described below.
>> *VWUP_OFF_TICKER_THRESHOLD 5 with 4 trys.log*
>> Car was locked initially. Unlocked the car before line 21 (around
>time
>> mark 60.000). Locked around time mark 80.000. Car stayed responsive
>> until line 108 (time mark 100.000).
>> At line 130 (tm=116.814) I swap back to PollState=0. The poll for
>> PollState=0 gets an immediate reply (line 131-133) and therefore I
>> swap back to PollState=1.
>> The weird thing is that line 132 (which got a reply) is exactly the
>> same as 126 (or 118 or 110) which didn't get a reply!?!? So the car
>> has no idea of the poll states as the data is the same? There must be
>> some issue/bug/behavior inside OVMS (maybe even in the hardware
>> buffer) which gets triggered by a PollState change. Or the
>> canlog-monitor uses somehow a cache and doesn't show the messages
>> immediately.
>> *VWUP_OFF_TICKER_THRESHOLD 10 with 4 trys.log*
>> Same as below. One thing I've noticed though: Car was locked until
>> line 32 (tm=63.814). Then I've unlocked it and the lines 33 and 34
>> showed up immediately. This indicates a buffer/cache/etc. issue with
>> the canlog-monitor as well (imho).
>> Soko
>> On 03.08.2020 13:10, Michael Balzer wrote:
>>> Soko,
>>> I don't see any obvious mistakes on a first check.
>>> Please do the tests again with CAN monitoring, so we can see what's
>>> actually going on on the bus.
>>> An OBD device normally logs into the device sending a UDS diag
>>> session command (0x10), then keeps that session alive by sending
>>> tester present (0x3E) evers 30-60 seconds. See the UDS documentation
>>> I sent you, or for an overview, see
>>> https://de.wikipedia.org/wiki/Unified_Diagnostic_Services
>>> You should be able to get the session type and protocol by logging
>>> what your VCDS does on the bus.
>>> Am 03.08.20 um 06:19 schrieb Soko:
>>>> Mornin,
>>>> Source is here:
>https://github.com/devmarxx/Open-Vehicle-Monitoring-System-3/tree/master/vehicle/OVMS.V3/components/vehicle_vweup/src
>>>> Attached are two logs. I haven't had the can-monitor active
>>>> unfortuantely..
>>>> As the name says it polls every 5 seconds in PollState=1 and swaps
>>>> back to PollState=0 after 5*4=20 seconds.
>>>> Until line 35 you see the CAN errors as the vehicle is OFF. Then I
>>>> unlocked the car and in line 38 I get the first reply.
>>>> Around line 90 I locked the car again. It polls, but gets no reply,
>>>> _but not error either_ (?!).
>>>> Line 118 sets the PollState=0 and suddenly a response comes in. So
>>>> in Line 123 I set the PollState=1 again.
>>>> The the game starts again: Polls get send, no reply but no error
>>>> either. After 21 CarOffTickers I switch to PollState=0 and suddenly
>>>> a reply comes in...
>>>> *Here I unlocked at line 57 and locked around line 100. After that
>>>> polls get send, no reply, _but errors happen_. And the car is
>>>> finally off.
>>>> Although I've tried the same thing later that day and the car
>didn't
>>>> even go to sleep with Threshold=30!?!? So the behavior is not 100%
>>>> reproducible (yet)...
>>>> @gateway throttling: In VCDS (which - hopefully - does only polling
>>>> too) I have a little number showing me the refresh rates of the
>>>> values. It indicates ~8 refreshes per second. So with 1 second
>>>> shouldn't be any throttling.
>>>> @OBD "tester": I have no clue what this is ;) So if the polling
>>>> framework doesn't do it, I don't do it. All I do is in the
>obd_eup.*
>>>> files.
>>>> Soko
>>>> On 02.08.2020 20:12, Michael Balzer wrote:
>>>>> Soko,
>>>>> polling may keep the car awake, that's also an issue on the Kia
>>>>> e-Niro IIRC.
>>>>> Changing the PollState can only affect the car indirectly via the
>>>>> changed polls. Maybe you could add your code & a log?
>>>>> Regarding the poll replies stopping, is that also reflected in a
>>>>> CAN log? Maybe the OBD gateway throttles if it sees too many
>>>>> requests? (Hopefully not…)
>>>>> If the gateway does throttling: do you login to the OBD as a
>>>>> "tester" and keep the session active by periodically sending the
>>>>> "tester present" frame?
>>>>> Regards,
>>>>> Michael
>>>>> Am 02.08.20 um 19:30 schrieb Soko:
>>>>>> Heya again,
>>>>>> I'm trying to develop a detection for when the car is off/locked
>>>>>> but I'm encountering a weird phenomena:
>>>>>> * Car is shut down and locked
>>>>>> * OVMS connected
>>>>>> * CAN poll for voltage (only one poll value active) with 30
>secs
>>>>>> fails with error (so far nothing weird)
>>>>>> * Unlock the car via car-key remote
>>>>>> * Poll succeeds and I'm switching from PollState=0 to
>>>>>> PollState=1 where I poll every 2 secs
>>>>>> * Lock the car via car-key remote
>>>>>> * _After 1 hour the polls still work and the car is active_
>>>>>> Is something like this known from other vehicles? So basically my
>>>>>> car never shuts down :(
>>>>>> Another secondary weird thing:
>>>>>> When increasing the time to 5 secs for PollState=1 the polls get
>>>>>> no reply and after 20 secs I swap back to PollState=0.
>>>>>> BUT the second the PollState changes the car replies again...
>>>>>> Even more weirdness: When PollState=1 time is 10 secs and I swap
>>>>>> back to Pollstate=0 after 40 secs the same thing happens!
>>>>>> Immediately I swap to PollState=0 the car replies again.
>>>>>> As if the PollState switching somehow wakes the car up??!
>>>>>> Any ideas?
>>>>>> Soko
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200808/620e8f94/attachment-0001.html>
