[Ovmsdev] 3G / 2G fallback on SIM5360 Europe?
Wed Aug 5 14:01:19 HKT 2020
Chris,
two additional thoughts:
- maybe the VW antenna contains a GSM and a GPS antenna (?), and you
connected the wrong one?
- maybe the VW antenna is an active one and needs a supply voltage which
is currently missing?
Am 05.08.20 um 07:24 schrieb Mark Webb-Johnson:
> Maybe,
> Or the VW antenna is way off on specification.
>> On 5 Aug 2020, at 1:17 PM, Chris van der Meijden <chris at arachnon.de
>> <mailto:chris at arachnon.de>> wrote:
>> Thank you for your response.
>> That leaves me with a poor home made SMA to Fakra adapter cable, I
>> guess ...
>> Regards
>> Chris
>> Am Mittwoch, den 05.08.2020, 09:27 +0800 schrieb Mark Webb-Johnson:
>>> The antenna surely helps, but in some locations you can receive a
>>> signal with a piece of wet string resting on the antenna connection.
>>> Seriously. At my office desktop, I still get 3G without an antenna
>>> connected (but I don’t recommend it due to possible feedback in the
>>> modem module).
>>> These are not binary on/off situations. An antenna rated to
>>> 1710-1990 will still work at 1991, or even 2100, but just not
>>> optimally with the best reception or transmission.
>>> The original Fasttech antennas were designed for 2G (OVMS v2), but
>>> should still cover some 3G ranges optimally. The newer ones (from
>>> Medlock in USA and OpenEnergyMonitor in UK) should cover all ranges
>>> (up to and including 4G LTE) - and we used these for radio
>>> certification so have been very thoroughly tested at all the
>>> supported 2G and 3G frequency ranges.
>>>> On 5 Aug 2020, at 12:21 AM, Chris van der Meijden
>>>> <chris at arachnon.de <mailto:chris at arachnon.de>> wrote:
>>>> Still digging on the subject ...
>>>> Today I took my original Fasttech OVMS v2 antenna out of my Nissan
>>>> Leaf and connected it to the OVMS v3 in our VW e-Up. And surprise,
>>>> surprise I got direct connection over the SIM to the network.
>>>> The VW antenna gives me -101 dBm, the Fasttech antenna gives me -91
>>>> dBm.
>>>> So I took a look at the frequencies ...
>>>> The old fasttech antenna has a frequency range of 824-960 / 1710-1990.
>>>> o2 (my SIM card provider) uses GSM 900 and GSM+LTE 1800 for 2g (4g
>>>> LTE cannot be used on the SIM5360) and uses UMTS 2100 for 3g.
>>>> Now I have two theories on what make things go wrong with the VW
>>>> antenna, but work with the fasttech antenna:
>>>> 1. My home made sma / fakra adapter cable to the VW antenna is bad
>>>> (could be, but in the city it connects)
>>>> 2. Because 3g on 2100 mHz is not available through the fasttech
>>>> antenna, OVMS v3 is forced to 2g and everything runs fine.
>>>> Any corrections on the second theory are welcome. I'm guessing ...
>>>> I will buy an other sma 2g/3g antenna just to get rid of the
>>>> problem, but will also continue thinking on this one.
>>>> Greetinx
>>>> Chris
>>>> Am Montag, den 03.08.2020, 12:31 +0200 schrieb Chris van der Meijden:
>>>>> Hi Michael
>>>>> yeah, economical visionaries are always a lot of fun :-))
>>>>> I read that "GSM voices services" line too and checked on that
>>>>> with my mobile phone. I restricted the connection of the phone
>>>>> with *#*#4636#*#* to "GSM auto (PRL)" and it connects to EDGE. So
>>>>> data over GSM is available ...
>>>>> Still mysterious. Will dig some more ...
>>>>> Greetinx
>>>>> Chris
>>>>> Am Montag, den 03.08.2020, 12:21 +0200 schrieb Michael Balzer:
>>>>>> Chris,
>>>>>> we don't tell the modem to restrict itself in any way. Bugs in
>>>>>> the modem firmware are likely, but I think a serious bug like
>>>>>> this would have been solved early.
>>>>>> I've read the pilot description now, and you need to pay
>>>>>> attention to this section:
>>>>>>> statt der üblichen drei Dienste LTE, UMTS und GSM kommen in
>>>>>>> Kirchfarrnbach "nur" LTE 800 und LTE 900 für die Datenversorgung
>>>>>>> sowie GSM für Sprachdienste und SMS zum Einsatz. Auf UMTS haben
>>>>>>> die Funknetzplaner hier verzichtet, weil bereits LTE und GSM
>>>>>>> alle Anforderungen der Bevölkerung erfüllen.
>>>>>> …translated…
>>>>>>> Instead of the usual three services LTE, UMTS and GSM, "only"
>>>>>>> LTE 800 and LTE 900 are used in Kirchfarrnbach for data supply
>>>>>>> as well as GSM for voice services and SMS. The radio network
>>>>>>> planners have dispensed with UMTS here because LTE and GSM
>>>>>>> already meet all the requirements of the population.
>>>>>> So you have neither UMTS nor EDGE. GSM is only available for
>>>>>> voice streams and SMS. Data is only available via LTE.
>>>>>> Your only option is to tell them they're a bunch of … outstanding
>>>>>> economical visionaries, who could possibly consider rethinking
>>>>>> their IoT compatibility ;-)
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 03.08.20 um 11:33 schrieb Chris van der Meijden:
>>>>>>> I did some more reading on the SIM5360 and also digged a bit
>>>>>>> through the simcom source. Found loads of AT-commands there :-)
>>>>>>> I could not find an AT command to restrict the selection to 2g.
>>>>>>> Perhaps I did not look deep enough, but if someone knows the
>>>>>>> command ...
>>>>>>> I'm still thinking why the automatic fallback to 2g does not
>>>>>>> happen.
>>>>>>> - The transmitter offers only 2g (GSM 900 mHz) and LTE (800 or
>>>>>>> 1800). No 3g.
>>>>>>> - I have a signal strength of -110 to -100 dBm
>>>>>>> - AT+COPS? gives me an empty response.
>>>>>>> Could it be possible, that somewhere in the code something like
>>>>>>> - I don't have 3g
>>>>>>> - I do have LTE
>>>>>>> - Lets try LTE
>>>>>>> - I see LTE
>>>>>>> - I have no hardware for LTE
>>>>>>> - OK, don't do anything
>>>>>>> happens? So somehow fallback to 2g never happens?
>>>>>>> Just guessing around ...
>>>>>>> Regards
>>>>>>> Chris
>>>>>>> Am Montag, den 03.08.2020, 10:10 +0800 schrieb Mark Webb-Johnson:
>>>>>>>> The SIM5360E should auto-switch between 2G and 3G. It supports
>>>>>>>> the following frequency bands:
>>>>>>>> GSM/GPRS/EDGE 850/900/1800/1900MHz;
>>>>>>>> UMTS/HSPA+ 900/2100MHz
>>>>>>>> There are SIMCOM options/commands to restrict the selection,
>>>>>>>> but the default is automatic.
>>>>>>>> Regards, Mark
>>>>>>>>> On 2 Aug 2020, at 6:40 PM, Chris van der Meijden
>>>>>>>>> Hey Michael
>>>>>>>>> Thanx for the help :-)
>>>>>>>>> The AT commands are working now, but as expected no connection
>>>>>>>>> at all. So also no fallback to 2g. Or no GPRS offered on 2g ...
>>>>>>>>> Here some (German) information on the "site lite" transmitters:
>>>>>>>>> https://www.telekom.com/de/blog/netz/artikel/standort-light-pilotprojekt-552152
>>>>>>>>> I also did not find any AT command for the SIM5360 to force
>>>>>>>>> 2g. I will play a bit around with the modem in the next days.
>>>>>>>>> Will also try congstar, I do have a congstar SIM laying around
>>>>>>>>> here ...
>>>>>>>>> Greetinx
>>>>>>>>> Chris
>>>>>>>>> Am Sonntag, den 02.08.2020, 10:59 +0200 schrieb Michael Balzer:
>>>>>>>>>> Chris,
>>>>>>>>>> how to send modem commands and read the responses:
>>>>>>>>>> OVMS# log level debug simcom
>>>>>>>>>> Logging level for simcom set to debug
>>>>>>>>>> OVMS# simcom cmd AT+COPS?
>>>>>>>>>> SIMCOM command has been sent.
>>>>>>>>>> D (164488782) simcom: tx mcmd ch=4 len=10 : AT+COPS?
>>>>>>>>>> D (164488792) simcom: rx line ch=4 len=23 : +COPS:
>>>>>>>>>> 0,0,"congstar",2
>>>>>>>>>> D (164488802) simcom: rx line ch=4 len=2 : OK
>>>>>>>>>> Now let's see if we have 3G:
>>>>>>>>>> OVMS# simcom cmd AT+CPSI?
>>>>>>>>>> D (164693462) simcom: tx mcmd ch=4 len=10 : AT+CPSI?
>>>>>>>>>> D (164693482) simcom: rx line ch=4 len=85 : +CPSI:
>>>>>>>>>> WCDMA,Online,262-01,0x16C3,7824927,WCDMA IMT
>>>>>>>>>> 2000,454,10836,0,7.5,104,18,8,500
>>>>>>>>>> D (164693482) simcom: rx line ch=4 len=2 : OK
>>>>>>>>>> Yes. Well, no surprise, Telekom network :-).
>>>>>>>>>> The SIM5360 is supposed to automatically fall back to 2G if
>>>>>>>>>> 3G isn't available. On a quick browse through the manual, I
>>>>>>>>>> didn't find a command to force 2G, just one to lock to a
>>>>>>>>>> specific 2G cell… you could do that depending on your
>>>>>>>>>> location, but maybe you should first inspect your modem
>>>>>>>>>> status now.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 02.08.20 um 09:39 schrieb Chris van der Meijden:
>>>>>>>>>>> Hi all
>>>>>>>>>>> I'm trying to understand some principals of the SIM
>>>>>>>>>>> connection methods of OVMS.
>>>>>>>>>>> Reason is that I recently moved from "the big city" Munich
>>>>>>>>>>> to the very much rural village Thalham. In Thalham we have
>>>>>>>>>>> so called "lite" mobile transmitters. These transmitters are
>>>>>>>>>>> installed, as far as I understood, to safe money and to
>>>>>>>>>>> prepare the transition of the providers to 4g / 5g. They are
>>>>>>>>>>> forcing the frequencies towards the 4g band with those.
>>>>>>>>>>> So these transmitters seem to offer only 2g and 4g, but no
>>>>>>>>>>> more 3g (really ???).
>>>>>>>>>>> I don't have any network connection with the SIM in my OVMS
>>>>>>>>>>> here in Thalham. In the next village Zolling I have
>>>>>>>>>>> connection. In Zolling they don't have the "lite"
>>>>>>>>>>> transmitters, but still have full 3g support. The antenna of
>>>>>>>>>>> my OVMS is working well (-100 dBm to -70 dBm).
>>>>>>>>>>> Now my questions ...
>>>>>>>>>>> Does OVMS have a fallback on SIM5360 Europe to 2g (EDGE) if
>>>>>>>>>>> 3g is not available?
>>>>>>>>>>> I also did some reading in the modem documentation and tried
>>>>>>>>>>> to send some AT commands. Goal is to try to force the SIM
>>>>>>>>>>> into 2g mode. I tried i.e.
>>>>>>>>>>> simcom muxtx 2 AT+COPS?
>>>>>>>>>>> to get some information from the SIM, but I don't get an
>>>>>>>>>>> answer on that command at all. No matter what channel I try.
>>>>>>>>>>> Am I missing something there?
>>>>>>>>>>> Thanx for input.
>>>>>>>>>>> Regards
>>>>>>>>>>> Chris
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200805/041cd9b9/attachment-0001.html>
