[Ovmsdev] 3.2.012 test
Tamás Kovács
kommykt at gmail.com
Wed Apr 29 13:27:04 HKT 2020
i only now created a pull request with AC charge detection fix.
Michael Eric Menk <mikeemenk at gmail.com> ezt írta (időpont: 2020. ápr. 28.,
K, 16:46):
> I have downloaded and tested 3.2.012
> The C-zero (MiEV clone) charge bug was not included.
> On 25.04.2020 20:24, Tamás Kovács wrote:
> Thanks the log, now i modified the AC charge detection code.
> If you want to try add the following to config / firmware / flash from web
> : kommykt-nas.ddns.net:22289/ovms3.bin
> This is my NAS, the internet speed is not very high.
> The changes that Tamás did worked. It tould have been nice that this would
> be included in 3.2.012 before it goes in prod.
> As far as I can see, the code is not committed into master yet.
> A better range_est while fastcharing can worked on later.
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200429/6e4430d6/attachment.htm>
