[Ovmsdev] What happened to TPMS?
Thu Apr 23 02:34:32 HKT 2020
Hi all
I would like to point to this thread:
http://lists.openvehicles.com/pipermail/ovmsdev/2020-March/006730.html
The code for TMPS has been changed for vehicles that don't support TPMS
Regards
Chris
Am Mittwoch, den 22.04.2020, 11:23 -0700 schrieb Greg D.:
>     Ok...  So the module updated to EAP last night, as expected.  The
>     display (screen shot) shows zeros for Ambient, Charger/PEM,
> Motor,
>     and battery; 12v is live, as is the odometer.  TPMS is missing.
> Is
>     there a reason that the bulk of the metrics aren't read?  Are
> they
>     not present on the CAN bus, or is the module explicitly not
> watching
>     for them until the car wakes up?
>     If I wake the car up, Ambient, Charger/PEM, motor, and battery
> are
>     immediately updated, but TPMS is still missing.
>     For consistency and less confusion, I would like for the TPMS to
> be
>     populated in both screen shots, and showing zeros until the car
> is
>     driven.  And by "consistency" I do NOT mean "remove the other
>     metrics too".  I'm trying to be careful what I wish for...
>     When I put it in Drive for a few minutes, the TPMS icons do
> appear
>     with live data.  I'll let the car sit for a few days, and see
> what
>     happens to the display.  What I expect is that they will remain
>     present, even if not live.
>     Greg
>     Greg D wrote:
> >       Ok, EAP is set. Let's see what happens at 2am...
> >       Greg
> >       On April 21, 2020 11:05:01 PM PDT, Mark
> >         Webb-Johnson <mark at webb-johnson.net> wrote:
> > >           I think best to move to EAP and see if that improves
> > > the
> > >           situation. On ‘edge’, you will be getting an update
> > > (and
> > >           reboot) once every night or two.
> > >           Regards, Mark.
> > > >                 On 22 Apr 2020, at 12:58 PM, Greg D. <gregd2350
> > > > @gmail.com>
> > > >                   wrote:
> > > >                    Hi
> > > >                     Mark,
> > > >                     Yes, I understand that.  Not expecting such
> > > > a
> > > >                     dramatic change as saving data in NV RAM.
> > > > The end
> > > >                     user presumably won't have their module
> > > > rebooting
> > > >                     very often, so this isn't worth trying to
> > > > save stuff
> > > >                     across reboots.
> > > >                     I'm trying think back to when the behavior
> > > > started
> > > >                     to change.  It might have been when I moved
> > > > off the
> > > >                     Main branch to Edge because of the bug with
> > > > OBD2ECU
> > > >                     CAN initialization, so module reboots are
> > > > far more
> > > >                     frequent.  I'm tempted to get back on Main,
> > > > or at
> > > >                     least EAP, but I'm also vaguely remembering
> > > > that
> > > >                     there was a change related specifically to
> > > > "stale"
> > > >                     data that put a lot of data out of reach
> > > > for a day.
> > > >                     This latest UI behavior change was the
> > > > straw that
> > > >                     caused me to write.
> > > >                     It seems like populating data takes a lot
> > > > longer now
> > > >                     than, say, 6 months ago.  Did something
> > > > change a
> > > >                     while back that has led to this?  Part of
> > > > the
> > > >                     puzzle, perhaps, is that we have two moving
> > > > pieces,
> > > >                     the Module and the App.  I'm on Android, if
> > > > that
> > > >                     matters.
> > > >                     Greg
> > > >                     Mark Webb-Johnson
> > > >                       wrote:
> > > > >                       Greg,
> > > > >                       I think the issue you have is that
> > > > >                         after a firmware update the module
> > > > > will reboot.
> > > > >                         That will mean it will lose the
> > > > > metrics for
> > > > >                         TPMS.
> > > > >                       Those metrics won’t come back until
> > > > >                         the car has been driven.
> > > > >                       I don’t see a simple solution. We
> > > > >                         could address it in v2 protocol by
> > > > > not sending
> > > > >                         the tpms message unless the metrics
> > > > > are defined,
> > > > >                         but that might still mess up the
> > > > > stale
> > > > >                         indicator. That wouldn’t affect the
> > > > > individual
> > > > >                         metrics and v3 protocol we are trying
> > > > > to move to
> > > > >                         for the future.
> > > > >                       There is a small amount of RTC ram
> > > > >                         that is retained through a reboot.
> > > > > Perhaps we
> > > > >                         could have a mechanism to
> > > > > save+restore certain
> > > > >                         metrics there? But not at all simple.
> > > > >                       Regards, Mark.
> > > > > >                             On 22 Apr 2020, at 11:07 AM,
> > > > > >                               Greg D. <gregd2350 at gmail.com>
> > > > > >                               wrote:
> > > > > >                                Hi Mark, Michael,
> > > > > >                                 I am on Edge, and it
> > > > > > updated 2am local
> > > > > >                                 on the 20th (2 days ago).
> > > > > >                                 Firmware: 3.2.011-13-
> > > > > > g7d83320/ota_0/edge
> > > > > >                                 (build idf v3.3-beta3-775-
> > > > > > gdc1ca69 Apr
> > > > > >                                 20 2020 15:10:37).  The app
> > > > > > is 3.16.1
> > > > > >                                 (2020031801).
> > > > > >                                 I just put the car in Drive
> > > > > > for a few
> > > > > >                                 minutes, and all the stats
> > > > > > got
> > > > > >                                 populated.  The car is off
> > > > > > and sleeping
> > > > > >                                 now, so I'll check it again
> > > > > > in the
> > > > > >                                 morning.
> > > > > >                                 Greg
> > > > > >                                 p.s.  Just saw your EAP
> > > > > > announcement.
> > > > > >                                 With the 3.2.012 code
> > > > > > coming, it will be
> > > > > >                                 interesting to see what
> > > > > > happens after
> > > > > >                                 the reset.  I'll let you
> > > > > > know!
> > > > > >                                 Mark
> > > > > >                                   Webb-Johnson wrote:
> > > > > > >                                   Greg,
> > > > > > >                                   What firmware version
> > > > > > >                                     are you running in
> > > > > > > the module? If
> > > > > > >                                     EAP/MAIN 3.2.011, can
> > > > > > > you try
> > > > > > >                                     updating to the edge
> > > > > > > release? I
> > > > > > >                                     suspect you are
> > > > > > > seeing the bug with
> > > > > > >                                     3.2.011 and the TPMS
> > > > > > > protocol v2
> > > > > > >                                     message.
> > > > > > >                                   Regards, Mark.
> > > > > > > >                                         On 22 Apr 2020,
> > > > > > > > at
> > > > > > > >                                           4:09 AM, Greg
> > > > > > > >                                           wrote:
> > > > > > > >                                             Hi folks,
> > > > > > > >                                             So, I seem
> > > > > > > > to be going
> > > > > > > >                                             backwards
> > > > > > > > with OVMS and my
> > > > > > > >                                             Tesla
> > > > > > > > Roadster...
> > > > > > > >                                             I'm looking
> > > > > > > > at the OVMS app
> > > > > > > >                                             on my
> > > > > > > > Android phone.
> > > > > > > >                                             Used to be
> > > > > > > > that I'd see the
> > > > > > > >                                             TPMS data -
> > > > > > > > pressure and
> > > > > > > >                                             temperature
> > > > > > > > - as it was the
> > > > > > > >                                             last time
> > > > > > > > the car was
> > > > > > > >                                             driven.
> > > > > > > >                                             Then it
> > > > > > > > turned into zeros.
> > > > > > > >                                             Today I see
> > > > > > > > it's gone
> > > > > > > >                                             altogether.
> > > > > > > >   This is not
> > > > > > > >                                             progress.
> > > > > > > >                                             What I want
> > > > > > > > to see is the
> > > > > > > >                                             data from
> > > > > > > > the car, as last
> > > > > > > >                                             it was
> > > > > > > > read.  I do not care
> > > > > > > >                                             that it is
> > > > > > > > not live.  In
> > > > > > > >                                             fact, if it
> > > > > > > > were live, that
> > > > > > > >                                             would mean
> > > > > > > > that the car is
> > > > > > > >                                             in Drive,
> > > > > > > > which (hopefully)
> > > > > > > >                                             means that
> > > > > > > > I am in my car.
> > > > > > > >                                             If so, I
> > > > > > > > have no
> > > > > > > >                                               use for
> > > > > > > > the OVMS, as
> > > > > > > >                                             the data is
> > > > > > > > sitting right
> > > > > > > >                                             there on
> > > > > > > > the car's display.
> > > > > > > >                                             Is there
> > > > > > > > any way to get the
> > > > > > > >                                             old
> > > > > > > > functionality back?
> > > > > > > >                                             Greg
> > > > > > > > _______________________________________________
> > > > > > > >                                           OvmsDev
> > > > > > > > mailing list
> > > > > > > >                                           OvmsDev at lists
> > > > > > > > .openvehicles.com
> > > > > > > >                                           http://lists.
> > > > > > > > openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > > OvmsDev mailing list
> > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > m
> > > > > ________
> > > > __
> > > > o/ovmsdev
> >       This space for rent...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200422/2cb32399/attachment.htm>
