[Ovmsdev] 3.2.011 BUG for MIEV based cars
Tamás Kovács kommykt at gmail.com
Sat Apr 18 23:46:48 HKT 2020
And please send some information from your car.
example the "xmi vin" command, the car vin not necessary
Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2020. ápr. 18., Szo,
17:28):
>  If the problem appear on AC  you use 230V or 110V?
> I tested now but not reproduce, only the type of charging (type1 ...) not
> show when i reboot the OVMS module when the charging at almost full.
> [image: Screenshot 2020-04-18 at 17.24.43.png]
> [image: Screenshot 2020-04-18 at 17.27.47.png]
> 5:41):
>> Please send the following command output during charge. AC (Type1) or
>> DC(CHAdeMO charge the problem?
>> *me li v.c.*
>> Michael Eric Menk <mikeemenk at gmail.com> ezt írta (időpont: 2020. ápr.
>> 17., P, 21:38):
>>> On 17.04.2020 20:51, Tamás Kovács wrote:
>>> What is the previous version of OVMS fw installed. The charge detection
>>> commited at 2019 dec 25 the next OVMS release is 3.2.009.
>>> My previous version is 3.2.008
>>> No crash/reboot/fw update during charge?
>>> No, completely stable. But I do not have a SD car installed for logging.
>>> But it is partially working...
>>> The DC kWh number is stored and updating when charging.
>>> the only place I find that it updates is inside :
>>> if (StandardMetrics.ms_v_charge_inprogress->AsBool())
>>>           ms_v_charge_dc_kwh->SetValue((ms_v_charge_dc_kwh->AsFloat() +
>>> (StandardMetrics.ms_v_bat_power->AsFloat() / -360000.0)));
>>> This indicates that the StandardMetrics.ms_v_charge_inprogress is set
>>> correctly, but there is no charge status in the app, command-line or on
>>> web-page.
>> Üdvözlettel:
>> Kovács Tamás
> Üdvözlettel:
> Kovács Tamás
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200418/e0cb4201/attachment.htm>
Name: Screenshot 2020-04-18 at 17.24.43.png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200418/e0cb4201/attachment-0004.png>
Name: Screenshot 2020-04-18 at 17.27.47.png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200418/e0cb4201/attachment-0005.png>
