[Ovmsdev] make apt-flash destination location?
Wed Apr 22 15:51:03 HKT 2020
Yes, that looks correct.
> On 22 Apr 2020, at 2:43 PM, Eddy Vromen <eddy_vromen at hotmail.com> wrote:
> Thanks! The trick with the esptool.py is what i was looking for. Looking at partitions.csv, the offset for OTA_0 is 0x10000 + 4MByte?
> # OVMS 16MB flash ESP32 Partition Table
> # Name, Type, SubType, Offset, Size
> nvs, data, nvs, 0x9000, 0x4000
> otadata, data, ota, 0xd000, 0x2000
> phy_init, data, phy, 0xf000, 0x1000
> factory, app, factory, 0x10000, 4M
> ota_0, app, ota_0, , 4M
> ota_1, app, ota_1, , 4M
> store, data, fat, , 1M
> Thanks,
> Eddy
> From: OvmsDev <ovmsdev-bounces at lists.openvehicles.com <mailto:ovmsdev-bounces at lists.openvehicles.com>> on behalf of Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
> Sent: Wednesday, April 22, 2020 2:28 PM
> To: OVMS Developers <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
> Subject: Re: [Ovmsdev] make apt-flash destination location?
> The app-flash always flashes the ‘factory’ partition. If you ‘make flash’ it will also overwrite the bootloader, partition table, and switch back to factory for you.
> You can also tell the module to boot from factory with ‘ota boot factory’ (and ota_0, ota_1 for the ota partitions).
> P.S. You can manually flash (using the esptool.py script) to a specific partition, using partitions.csv to tell you the offsets.
>> On 22 Apr 2020, at 2:23 PM, Eddy Vromen <eddy_vromen at hotmail.com <mailto:eddy_vromen at hotmail.com>> wrote:
>> Hi All,
>> Quick question: I am experimenting with some code changes and i am using the sdcard method to get a new .bin file on the device. It will automatically alternate between the 2 OTA image loactions which is great.
>> I would like to make this process a little less labor intensive:
>> When i use "make apt-flash", where does the code get flashed? With this method, how can i pick between the 2 OTA image locations?
>> Thanks,
>> Eddy
>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <https://apc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.openvehicles.com%2Fmailman%2Flistinfo%2Fovmsdev&data=02%7C01%7C%7C15e8f2a1e8fd4bca686908d7e68678fd%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637231337740235000&sdata=MIy7R4VpHZpPzdScx2k%2BazvjgmvVvzFiPCjT%2Bf11HnY%3D&reserved=0>
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200422/5849a2ae/attachment.html>
