[Ovmsdev] What happened to TPMS?
Greg D
gregd2350 at gmail.com
Wed Apr 22 14:53:57 HKT 2020
Ok, EAP is set. Let's see what happens at 2am...
Greg
On April 21, 2020 11:05:01 PM PDT, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>I think best to move to EAP and see if that improves the situation. On
>‘edge’, you will be getting an update (and reboot) once every night or
>two.
>Regards, Mark.
>> On 22 Apr 2020, at 12:58 PM, Greg D. <gregd2350 at gmail.com> wrote:
>> Hi Mark,
>> Yes, I understand that. Not expecting such a dramatic change as
>saving data in NV RAM. The end user presumably won't have their module
>rebooting very often, so this isn't worth trying to save stuff across
>reboots.
>> I'm trying think back to when the behavior started to change. It
>might have been when I moved off the Main branch to Edge because of the
>bug with OBD2ECU CAN initialization, so module reboots are far more
>frequent. I'm tempted to get back on Main, or at least EAP, but I'm
>also vaguely remembering that there was a change related specifically
>to "stale" data that put a lot of data out of reach for a day. This
>latest UI behavior change was the straw that caused me to write.
>> It seems like populating data takes a lot longer now than, say, 6
>months ago. Did something change a while back that has led to this?
>Part of the puzzle, perhaps, is that we have two moving pieces, the
>Module and the App. I'm on Android, if that matters.
>> Greg
>> Mark Webb-Johnson wrote:
>>> Greg,
>>> I think the issue you have is that after a firmware update the
>module will reboot. That will mean it will lose the metrics for TPMS.
>>> Those metrics won’t come back until the car has been driven.
>>> I don’t see a simple solution. We could address it in v2 protocol by
>not sending the tpms message unless the metrics are defined, but that
>might still mess up the stale indicator. That wouldn’t affect the
>individual metrics and v3 protocol we are trying to move to for the
>future.
>>> There is a small amount of RTC ram that is retained through a
>reboot. Perhaps we could have a mechanism to save+restore certain
>metrics there? But not at all simple.
>>>> On 22 Apr 2020, at 11:07 AM, Greg D. <gregd2350 at gmail.com
><mailto:gregd2350 at gmail.com>> wrote:
>>>> Hi Mark, Michael,
>>>> I am on Edge, and it updated 2am local on the 20th (2 days ago).
>Firmware: 3.2.011-13-g7d83320/ota_0/edge (build idf
>v3.3-beta3-775-gdc1ca69 Apr 20 2020 15:10:37). The app is 3.16.1
>(2020031801).
>>>> I just put the car in Drive for a few minutes, and all the stats
>got populated. The car is off and sleeping now, so I'll check it again
>in the morning.
>>>> Greg
>>>> p.s. Just saw your EAP announcement. With the 3.2.012 code
>coming, it will be interesting to see what happens after the reset.
>I'll let you know!
>>>>> Greg,
>>>>> What firmware version are you running in the module? If EAP/MAIN
>3.2.011, can you try updating to the edge release? I suspect you are
>seeing the bug with 3.2.011 and the TPMS protocol v2 message.
>>>>> Regards, Mark.
>>>>>> On 22 Apr 2020, at 4:09 AM, Greg D. <gregd2350 at gmail.com
>>>>>> Hi folks,
>>>>>> So, I seem to be going backwards with OVMS and my Tesla
>Roadster...
>>>>>> I'm looking at the OVMS app on my Android phone.
>>>>>> Used to be that I'd see the TPMS data - pressure and temperature
>- as it was the last time the car was driven.
>>>>>> Then it turned into zeros.
>>>>>> Today I see it's gone altogether. This is not progress.
>>>>>> What I want to see is the data from the car, as last it was read.
>I do not care that it is not live. In fact, if it were live, that
>would mean that the car is in Drive, which (hopefully) means that I am
>in my car. If so, I have no use for the OVMS, as the data is sitting
>right there on the car's display.
>>>>>> Is there any way to get the old functionality back?
>>>>>> Greg
>>>>>> OvmsDev mailing list
><mailto:OvmsDev at lists.openvehicles.com>
><http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
This space for rent...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200421/426f9034/attachment.html>
