[Ovmsdev] 3.2.011 BUG for MIEV based cars
Tamás Kovács
kommykt at gmail.com
Wed Apr 22 02:00:10 HKT 2020
Please create a log file while you charging with 230V (1-2 minutes enough),
start logging before connect charger and send it to me.
- can log crtd /sd/file.crtd 286
- …record…
- can log stop
- http://ovmsname.local/file.crtd
The Ideal range is based on 16.1kWh/100km consumption and the battery
health (this updated during charge, quick and normal charge). My car is
2012 Peugoet iOn, with SOH 78%, and my RR at 100% is 113km, the old code
calc the RR during quickcharge with last rr 20 and range 8km if soc < 20
this is too optimistic i think.
Ideal range calculation is = cell_number * 3.7 * bat_cac * bat_soc /
16100. So my full charge ideal range is ~75km.
In your car the bms cell monitor working?
Michael Eric Menk <mikeemenk at gmail.com> ezt írta (időpont: 2020. ápr. 21.,
K, 12:58):
> On 18.04.2020 05:41, Tamás Kovács wrote:
> Please send the following command output during charge. AC (Type1) or
> DC(CHAdeMO charge the problem?
> *me li v.c.*
> I hava a 80 cell 2015 Citroën C-Zero. VIN: VF71NZKYZFU900455 230V 6A
> charge after 1.1kWh charged.
> v.c.charging no
> v.c.climit 0A
> v.c.current 0A
> v.c.duration.full
> v.c.duration.range
> v.c.duration.soc
> v.c.kwh 0kWh
> v.c.limit.range
> v.c.limit.soc
> v.c.mode None
> v.c.pilot no
> v.c.state stopped
> v.c.substate interrupted
> v.c.temp 25°C
> v.c.time 0Sec
> v.c.timermode
> v.c.timerstart
> v.c.type None
> v.c.voltage 0V
> Fast charging (start) CC mode
> v.c.charging yes
> v.c.climit 124A
> v.c.current 124.6A
> v.c.duration.full
> v.c.duration.range
> v.c.duration.soc
> v.c.kwh 0kWh
> v.c.limit.range
> v.c.limit.soc
> v.c.mode CHAdeMO
> v.c.pilot yes
> v.c.state charging
> v.c.substate onrequest
> v.c.temp 19°C
> v.c.time 20Sec
> v.c.timermode
> v.c.timerstart
> v.c.type Quickcharge
> v.c.voltage 320.7V
> Fast charg CV mode
> v.c.charging yes
> v.c.climit 38A
> v.c.current 38.88A
> v.c.duration.full
> v.c.duration.range
> v.c.duration.soc
> v.c.kwh 0kWh
> v.c.limit.range
> v.c.limit.soc
> v.c.mode CHAdeMO
> v.c.pilot yes
> v.c.state charging
> v.c.temp 21°C
> v.c.time 817Sec
> v.c.timermode
> v.c.timerstart
> v.c.voltage 328.1V
> As you can se, the v.c.kwh do not increase, but xmi.e.trip.park.energy.used
> while charging. An other bug, RR (Range Remaining) is set to 255 on the CAN
> bus while fast charging, this is now set to 255 out to the user. [1] The
> code earlier saved the last known value of RR and of SOC, and calculated
> the RR base on SOC while fastcharging. I find it weird that CC-max goes
> down during the CV stage of the charging. I started a change of code. The
> idea was to warn user about reduced speed due to temperature. I stopped
> when I saw the code change. Coldest cell under 1°C => Max 25A (C/2) Coldest
> cell under 11°C => Max 50A (C) Warmest cell over 46°C => Max 85A (looks
> like its more dynamic, no cell goes above 47) Warmest cell over 30°C => Max
> 100A (2C) Optimal (11-29°C) => Max 125A (2.5C) BTW: If someone know how to
> start the heater + fanspeed low when Type-1 charging (the DC-bus is
> energized when type-1 charging), that would bee neat.
> [1] https://tjinfo.uib.no/Vedlegg?id=e9d1c4031a9f03d196f07e6be82bbe2f
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200421/9ff9dfa4/attachment-0001.html>
