[Ovmsdev] Crash random time
Tamás Kovács
kommykt at gmail.com
Tue Apr 14 11:51:05 HKT 2020
I used ovms.dexters-web.de/firmware/ota url to download the
3.2.011-172-g51b71688 version fw.
Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2020. ápr.
14., K, 3:34):
> Which firmware are you using (the URL you download from).
> Best approach is to use Michael’s a2l script, give it the backtrace
> addresses, and the .elf file for firmware, and it will output an annotated
> backtrace that we can see where the crash occurred.
> On 12 Apr 2020, at 10:49 PM, Tamás Kovács <kommykt at gmail.com> wrote:
> More info from crash. I see the following errors before crash (picture
> attached). Now i disable vfs logging, and run a can loggint to savyyCAN,
> this is the fastest mode to crash the module. i receive ~700k can messages.
> Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2020. ápr. 12., V,
> 9:14):
>> Car Peugeot iOn used TRIO vehicle type.
>> Last crash: abort() was called on core 0 Backtrace: 0x4008b03f 0x4008b2d5
>> 0x400e709c 0x40083d96 Version: 3.2.011-172-g51b71688/ota_1/eap (build idf
>> v3.3-beta3-776-g3d198cd50 Apr 11 2020 11:57:14)
>> Crash at 2020.04.11 18:59 and 20:59, 04.12 09:06
>> Created a log file the first 2 time only info level, but last with debug
>> level. And another on OVMS SHELL is see many dropped ticker event before
>> crash, but not show in log file.
> Üdvözlettel:
> Kovács Tamás
> <Screenshot 2020-04-12 at 16.42.20.png>
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200414/d1372cf3/attachment.html>
