Nicholas Prefontaine prefontaine at cwpc.ca
Thu Sep 19 17:16:20 HKT 2019
Thanks for the fix, sending that much data would drain my Hologram account
quite rapidly. I'm still using the included $5. So far OVMS has drained
about 15c in 8 months and that already seems like too much.
On Thu., Sep. 19, 2019, 05:04 Mark Webb-Johnson, <mark at webb-johnson.net>
wrote:
> It has been a very very very long day  😵
> Fixed to 7MB.
> On 19 Sep 2019, at 4:52 PM, Michael Balzer <dexter at expeedo.de> wrote:
> OK, but 700 MB is a bit exaggerated now ;)
> Am 19.09.19 um 10:22 schrieb Mark Webb-Johnson:
> OK, I’ve built:
> 2019-09-19 MWJ  3.2.005  OTA release
> - Default module/debug.tasks to FALSE
>   Users that volunteer to submit tasks debug historical data to the Open
> Vehicles
>   project, should (with appreciation) set:
>     config set module debug.tasks yes
>   This will be transmit approximately 700MB of data a month (over
> cellular/wifi).
> 2019-09-19 MWJ  3.2.004  OTA release
> - Skipped for Chinese superstitous reasons
> In EAP now, and I will announce.
> On 19 Sep 2019, at 3:34 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Correct.
> Am 19.09.19 um 09:29 schrieb Mark Webb-Johnson:
> I’m just worried about the users who don’t know about this new feature.
> When they deploy this version, they suddenly start sending 6MB of data a
> month up to us.
> I think the ‘fix’ is just to change ovms_module.c:
> MyConfig.GetParamValueBool("module", "debug.tasks", true)
> to
> MyConfig.GetParamValueBool("module", "debug.tasks", false)
> That would then only submit these logs for those that explicitly turn it
> on?
> On 19 Sep 2019, at 3:23 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Sorry, I didn't think about this being an issue elsewhere -- german data
> plans typically start at minimum 100 MB/month flat (that's my current plan
> at 3 € / month).
> No need for a new release, it can be turned off OTA by issueing
> config set module debug.tasks no
> Am 19.09.19 um 09:08 schrieb Mark Webb-Johnson:
> Yep:
> 758 bytes * (86400 / 300) * 30 = 6.5MB/month
> That is going over data (not SD). Presumably cellular data for a large
> portion of the time.
> I think we need to default this to OFF, and make a 3.2.004 to avoid this
> becoming an issue.
> On 19 Sep 2019, at 2:04 PM, Stephen Casner <casner at acm.org> wrote:
> That's 6.55MB/month, unless you have unusually short months!  :-)
> In what space is that data stored?  A log written to SD?  That's not
> likely to fill up the SD card too fast, but what happens if no SD card
> is installed?
> On Thu, 19 Sep 2019, Mark Webb-Johnson wrote:
>    To enable CPU usage statistics, apply the changes to sdkconfig
>    included.
>    New history record:
>    - "*-OVM-DebugTasks" v1: <taskcnt,totaltime> + per task:
>        <tasknum,name,state,stack_now,stack_max,stack_total,
>         heap_total,heap_32bit,heap_spi,runtime>
>      Note: CPU core use percentage = runtime / totaltime
> I’ve just noticed that this is enabled by default now (my production build
> has the sdkconfig updated, as per defaults).
> I am seeing 758 bytes of history record, every 5 minutes. About 218KB/day,
> or 654KB/month.
> Should this be opt-in?
> On 8 Sep 2019, at 5:43 PM, Michael Balzer <dexter at expeedo.de> wrote:
> I've pushed some modifications and improvements to (hopefully) fix the
> timer issue or at least be able to debug it.
> Some sdkconfig changes are necessary.
> The build including these updates is on my edge release as
> 3.2.002-258-g20ae554b.
> Btw: the network restart strategy seems to mitigate issue #241; I've seen
> a major drop on record repetitions on my server since the rollout.
> commit 99e4e48bdd40b7004c0976f51aba9e3da4ecab53
>    Module: add per task CPU usage statistics, add task stats history
> records
>    included. The CPU usage shown by the commands is calculated against
>    the last task status retrieved (or system boot).
>    Command changes:
>    - "module tasks" -- added CPU (core) usage in percent per task
>    New command:
>    - "module tasks data" -- output task stats in history record form
>    New config:
>    - [module] debug.tasks -- yes (default) = send task stats every 5
> minutes
>    New history record:
> commit 950172c216a72beb4da0bc7a40a46995a6105955
>    Build config: default timer service task priority raised to 20
>    Background: the FreeRTOS timer service shall only be used for very
>      short and non-blocking jobs. We delegate event processing to our
>      events task, anything else in timers needs to run with high
>      priority.
> commit 31ac19d187480046c16356b80668de45cacbb83d
>    DukTape: add build config for task priority, default lowered to 3
>    Background: the DukTape garbage collector shall run on lower
>      priority than tasks like SIMCOM & events
> commit e0a44791fbcfb5a4e4cad24c9d1163b76e637b4f
>    Server V2: use esp_log_timestamp for timeout detection,
>      add timeout config, limit data records & size per second
>    New config:
>    - [server.v2] timeout.rx -- timeout in seconds, default 960
> commit 684a4ce9525175a910040f0d1ca82ac212fbf5de
>    Notify: use esp_log_timestamp for creation time instead of monotonictime
>      to harden against timer service starvation / ticker event drops
> Am 07.09.19 um 10:55 schrieb Michael Balzer:
> I think the RTOS timer service task starves. It's running on core 0 with
> priority 1.
> Taks on core 0 sorted by priority:
> Number of Tasks = 20      Stack:  Now   Max Total    Heap 32-bit SPIRAM C#
> PRI
> 3FFC84A8  6 Blk ipc0              388   500  1024    7788      0      0  0
>  24
> 3FFC77F0  5 Blk OVMS CanRx        428   428  2048    3052      0  31844  0
>  23
> 3FFAFBF4  1 Blk esp_timer         400   656  4096   35928    644  25804  0
>  22
> 3FFD3240 19 Blk wifi              460  2716  3584   43720      0     20  0
>  22
> 3FFC03C4  2 Blk eventTask         448  1984  4608     104      0      0  0
>  20
> 3FFC8F14 17 Blk tiT               500  2308  3072    6552      0      0  *
>  18
> 3FFE14F0 26 Blk OVMS COrx         456   456  4096       0      0      0  0
>   7
> 3FFE19D4 27 Blk OVMS COwrk        476   476  3072       0      0      0  0
>   7
> 3FFCBC34 12 Blk Tmr Svc           352   928  3072      88      0      0  0
>   1
> 3FFE7708 23 Blk mdns              468  1396  4096     108      0      0  0
>   1
> I don't think it's our CanRx, as that only fetches and queues CAN frames,
> the actual work is done by the listeners. The CO tasks only run for CANopen
> jobs, which are few for normal operation.
> That leaves the system tasks, with main suspect -once again- the wifi blob.
> We need to know how much CPU time the tasks actually use now. I think I
> saw some option for this in the FreeRTOS config.
> Am 06.09.19 um 23:15 schrieb Michael Balzer:
> The workaround is based on the monotonictime being updated per second, as
> do the history record offsets.
> Apparently, that mechanism doesn't work reliably. That may be an indicator
> for some bigger underlying issue.
> Example log excerpt:
> 2019-09-06 22:07:48.126919 +0200 info  main: #173 C MITPROHB rx msg h
> 964,0,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:03.089031 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-10,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:05.041574 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-20,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:05.052644 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-30,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:05.063617 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-49,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:05.077527 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-59,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:05.193775 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-70,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:13.190645 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-80,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:22.077994 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-90,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:09:54.590300 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-109,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:11:10.127054 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-119,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:11:16.794200 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-130,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:11:22.455652 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-140,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:12:49.423412 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-150,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:12:49.442096 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-169,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:12:49.461941 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-179,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:14:39.828133 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-190,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:14:39.858144 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-200,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:14:52.020319 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-210,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:14:54.452637 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-229,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:15:12.613935 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-239,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:15:35.223845 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-250,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:16:09.255059 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-260,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:17:31.919754 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-270,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:19:23.366267 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-289,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:21:57.344609 +0200 info  main: #173 C MITPROHB rx msg h
> 964,-299,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:23:40.082406 +0200 info  main: #31 C MITPROHB rx msg h
> 964,-1027,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> 2019-09-06 22:25:58.061883 +0200 info  main: #31 C MITPROHB rx msg h
> 964,-1040,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
> This shows the ticker was only run 299 times from 22:07:48 to 22:21:57.
> After 22:21:57 the workaround was triggered and did a reconnect.
> Apparently during that network reinitialization of 103 seconds, the per
> second ticker was run 628 times.
> That can't be catching up on the event queue, as that queue has only 20
> slots. So something strange is going on here.
> Any ideas?
> Am 06.09.19 um 08:04 schrieb Michael Balzer:
> Mark & anyone else running a V2 server,
> as most cars don't send history records, this also needs the change to the
> server I just pushed, i.e. server version 2.4.2.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commits/master
> Am 05.09.19 um 19:55 schrieb Michael Balzer:
> I've pushed the nasty workaround: the v2 server checks for no RX over 15
> minutes, then restarts the network (wifi & modem) as configured for
> autostart.
> Rolled out on my server in edge as 3.2.002-237-ge075f655.
> Please test.
> Am 05.09.19 um 01:58 schrieb Mark Webb-Johnson:
> Mark, you can check your server logs for history messages with ridiculous
> time offsets:
> [sddexter at ns27 server]$ cat log-20190903 | egrep "rx msg h
> [0-9]+,-[0-9]{4}" | wc -l
> 455283
> I checked my logs and see 12 vehicles showing this. But, 2 only show this
> for a debugcrash log (which is expected, I guess, if the time is not synced
> at report time). I’ve got 4 cars with the offset > 10,000.
> On 4 Sep 2019, at 4:45 AM, Michael Balzer <dexter at expeedo.de <
> mailto:dexter at expeedo.de <dexter at expeedo.de>>> wrote:
> Everyone,
> I've pushed a change that needs some testing.
> I had the issue myself now parking at a certain distance from my garage
> wifi AP, i.e. on the edge of "in", after wifi had been disconnected for
> some hours, and with the module still connected via modem. The wifi blob
> had been trying to connect to the AP for about two hours.
> As seen before, the module saw no error, just the server responses and
> commands stopped coming in. I noticed the default interface was still "st1"
> despite wifi having been disconnected and modem connected. The DNS was also
> still configured for my wifi network, and the interface seemed to have an
> IP address -- but wasn't pingable from the wifi network.
> A power cycle of the modem solved the issue without reboot. So the cause
> may be in the modem/ppp subsystem, or it may be related (in some weird way)
> to the default interface / DNS setup.
> More tests showed the default interface again/still got set by the wifi
> blob itself at some point, overriding our modem prioritization. The events
> we didn't handle up to now were "sta.connected" and "sta.lostip", so I
> added these, and the bug didn't show up again since then. That doesn't mean
> anything, so we need to test this.
> The default interface really shouldn't affect inbound packet routing of an
> established connection, but there always may be strange bugs lurking in
> those libs.
> The change also reimplements the wifi signal strength reading, as the
> tests also showed that still wasn't working well using the CSI callback. It
> now seems to be much more reliable.
> Please test & report. The single module will be hard to test, as the bug
> isn't reproducable easily, but you can still try if wifi / modem
> transitions work well.
> time offsets:
> 455283
> The bug now severely affects the V2 server performance, as the server is
> single threaded and doesn't scale very well to this kind of bulk data
> bursts, especially when coming from multiple modules in parallel. So we
> really need to solve this now. Slow reactions or connection drops from my
> server lately have been due to this bug. If this change doesn't solve it,
> we'll need to add some reboot trigger on "too many server v2 notification
> retransmissions" -- or maybe a modem power cycle will do, that wouldn't
> discard the data.
> Thanks,
> Am 03.09.19 um 07:46 schrieb Mark Webb-Johnson:
> No problem. We can hold. I won’t commit anything for the next few days
> (and agree to hold-off on Markos’s pull). Let me know when you are ready.
> On 3 Sep 2019, at 1:58 AM, Michael Balzer <dexter at expeedo.de> <
> mailto:dexter at expeedo.de <dexter at expeedo.de>> wrote:
> Mark, please wait.
> I may just have found the cause for issue #241, or at least something I
> need to investigate before releasing.
> I need to dig into my logs first, and try something.
> Am 02.09.19 um 12:23 schrieb Michael Balzer:
> Nothing open from my side at the moment.
> I haven't had the time to look in to Markos pull request, but from a first
> check also think that's going too deep to be included in this release.
> Am 02.09.19 um 04:15 schrieb Mark Webb-Johnson:
> I think it is well past time for a 3.2.003 release. Things seems table in
> edge (although some things only partially implemented).
> Anything people want to include at the last minute, or can we go ahead and
> build?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190919/d0de8a9f/attachment.htm>
