Fri Sep 13 21:03:51 HKT 2019
I'd say we should release this version now.
No new issues so far, the #241 workaround works as designed, and crash ratio is low.
Am 09.09.19 um 17:18 schrieb Michael Balzer:
> Mark,
> I did the same checks as you and came to the same conclusion.
> For the webserver timer, that looks non-trivial but really only pushes requests into the job queue and takes care to never block. A bit of a potential issue
> there is it does some logging in case of trouble (job queue full), and that may be bad if logging to an SD file is enabled. We still need to rework the file
> logging to use a separate task as well (issue #107).
> From my task data today, here are some first impressions on our normal CPU load:
> a) Idle tasks:
> b) Active tasks:
> 10:00 - 10:30 was a drive from home (wifi) to office (no wifi), then another drive 13:00 - 13:30 and back home 14:00 - 14:15.
> Driving load on the NetMan is caused by the web dashboard. The half hour peaks are from the 12V topping from the main battery the Twizy does when parked.
> So that's nowhere near "too much" in terms of CPU load -- normally. I'm waiting to catch the issue situation with this instrumentation.
> Am 09.09.19 um 05:43 schrieb Mark Webb-Johnson:
>> tldr; Perhaps we should be using esp_timer and esp_timer_get_time() to update monotonic time then dispatch the ticker.* events?
>> Long story: Trying to see how monotonic time could not be updating...
>> I never really worked out how this operates in ESP32 IDF freertos. We have three tasks involved in timers:
>>   * esp_timer
>>   * Tmr Svc
>>   * eventTask
>> From my understanding, Tmr Svc provides high level timer support for freertos (xTimerCreate, etc). And esp_timer provides esp32 specific timer support
>> (https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/system/esp_timer.html). We use Tmr Svc, and note the warnings provided in the espressif
>> documentation:
>>   * Maximum resolution is equal to RTOS tick period
>>   * Timer callbacks are dispatched from a low-priority task
>> Currently, our housekeeping uses xTimerCreate to create a 1 second timer (calling HousekeepingTicker1). So, in which task is HousekeepingTicker1() called
>> (esp_timer or Tmr Svc) - I always suspected the latter (but never checked). Then HousekeepingTicker1() raises a signal (using ovms events) that pushes it
>> onto a queue (if the queue is full, it discards). The eventTask will then read that queue, and dispatch it to our ticker.1 listeners.
>> HousekeepingTicker1 is responsible for updating monotonictime, and given it’s simple calling of MyEvents.SignalEvent (which just queues it and discards on
>> overflow), I don’t think that can block for any substantial time.
>> I did a search for xTimerCreate in our code base, and find these used:
>>   * components/ovms_webserver/src/ovms_webserver.cpp
>>     m_update_ticker = xTimerCreate("Web client update ticker", 250 / portTICK_PERIOD_MS, pdTRUE, NULL, UpdateTicker);
>>     This seems to do quite a bit. In particular queue handling and semaphores. All seem to be non-blocking, but the flow is non-trivial.
>>   * components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp
>>     m_remoteCommandTimer = xTimerCreate("Nissan Leaf Remote Command", 100 / portTICK_PERIOD_MS, pdTRUE, this, remoteCommandTimer);
>>     m_ccDisableTimer = xTimerCreate("Nissan Leaf CC Disable", 1000 / portTICK_PERIOD_MS, pdFALSE, this, ccDisableTimer);
>>     Seem ok, and non-blocking.
>>   * components/vehicle_renaulttwizy/src/rt_sevcon.cpp
>>     m_kickdown_timer = xTimerCreate("RT kickdown", pdMS_TO_TICKS(100), pdTRUE, NULL, KickdownTimer);
>>     Seems ok.
>>   * components/vehicle_smarted/src/vehicle_smarted.cpp
>>     m_locking_timer = xTimerCreate("Smart ED Locking Timer", 500 / portTICK_PERIOD_MS, pdTRUE, this, SmartEDLockingTimer);
>>     This code looks a bit dodgy because CommandLock and CommandUnlock both create this timer, and start it - but neither check if it is already created. That
>>     said, after it fires the timer is deleted by the handler.
>>   * components/vehicle_teslaroadster/src/vehicle_teslaroadster.cpp
>>     m_speedo_timer = xTimerCreate("TR ticker",
>>     m_homelink_timer = xTimerCreate("Tesla Roadster Homelink Timer", durationms / portTICK_PERIOD_MS, pdTRUE, this, TeslaRoadsterHomelinkTimer);
>>     Similar lack of checking for duplicate timers. But I don’t see any blocking.
>> So, I don’t really think _we_ are starving the TmrSvc. Most likely something in the core framework.
>>> On 7 Sep 2019, at 4:55 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> I think the RTOS timer service task starves. It's running on core 0 with priority 1.
>>> Taks on core 0 sorted by priority:
>>> Number of Tasks = 20      Stack:  Now   Max Total    Heap 32-bit SPIRAM C# PRI
>>> 3FFC84A8  6 Blk ipc0              388   500  1024    7788      0      0  0  24
>>> 3FFC77F0  5 Blk OVMS CanRx        428   428  2048    3052      0  31844  0  23
>>> 3FFAFBF4  1 Blk esp_timer         400   656  4096   35928    644  25804  0  22
>>> 3FFD3240 19 Blk wifi              460  2716  3584   43720      0     20  0  22
>>> 3FFC03C4  2 Blk eventTask         448  1984  4608     104      0      0  0  20
>>> 3FFC8F14 17 Blk tiT               500  2308  3072    6552      0      0  *  18
>>> 3FFE14F0 26 Blk OVMS COrx         456   456  4096       0      0      0  0   7
>>> 3FFE19D4 27 Blk OVMS COwrk        476   476  3072       0      0      0  0   7
>>> 3FFCBC34 12 Blk Tmr Svc           352   928  3072      88      0      0  0   1
>>> 3FFE7708 23 Blk mdns              468  1396  4096     108      0      0  0   1
>>> I don't think it's our CanRx, as that only fetches and queues CAN frames, the actual work is done by the listeners. The CO tasks only run for CANopen jobs,
>>> which are few for normal operation.
>>> That leaves the system tasks, with main suspect -once again- the wifi blob.
>>> We need to know how much CPU time the tasks actually use now. I think I saw some option for this in the FreeRTOS config.
>>> Am 06.09.19 um 23:15 schrieb Michael Balzer:
>>>> The workaround is based on the monotonictime being updated per second, as do the history record offsets.
>>>> Apparently, that mechanism doesn't work reliably. That may be an indicator for some bigger underlying issue.
>>>> Example log excerpt:
>>>> 2019-09-06 22:07:48.126919 +0200 info  main: #173 C MITPROHB rx msg h 964,0,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:03.089031 +0200 info  main: #173 C MITPROHB rx msg h 964,-10,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:05.041574 +0200 info  main: #173 C MITPROHB rx msg h 964,-20,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:05.052644 +0200 info  main: #173 C MITPROHB rx msg h 964,-30,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:05.063617 +0200 info  main: #173 C MITPROHB rx msg h 964,-49,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:05.077527 +0200 info  main: #173 C MITPROHB rx msg h 964,-59,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:05.193775 +0200 info  main: #173 C MITPROHB rx msg h 964,-70,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:13.190645 +0200 info  main: #173 C MITPROHB rx msg h 964,-80,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:22.077994 +0200 info  main: #173 C MITPROHB rx msg h 964,-90,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:09:54.590300 +0200 info  main: #173 C MITPROHB rx msg h 964,-109,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:11:10.127054 +0200 info  main: #173 C MITPROHB rx msg h 964,-119,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:11:16.794200 +0200 info  main: #173 C MITPROHB rx msg h 964,-130,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:11:22.455652 +0200 info  main: #173 C MITPROHB rx msg h 964,-140,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:12:49.423412 +0200 info  main: #173 C MITPROHB rx msg h 964,-150,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:12:49.442096 +0200 info  main: #173 C MITPROHB rx msg h 964,-169,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:12:49.461941 +0200 info  main: #173 C MITPROHB rx msg h 964,-179,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:14:39.828133 +0200 info  main: #173 C MITPROHB rx msg h 964,-190,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:14:39.858144 +0200 info  main: #173 C MITPROHB rx msg h 964,-200,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:14:52.020319 +0200 info  main: #173 C MITPROHB rx msg h 964,-210,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:14:54.452637 +0200 info  main: #173 C MITPROHB rx msg h 964,-229,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:15:12.613935 +0200 info  main: #173 C MITPROHB rx msg h 964,-239,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:15:35.223845 +0200 info  main: #173 C MITPROHB rx msg h 964,-250,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:16:09.255059 +0200 info  main: #173 C MITPROHB rx msg h 964,-260,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:17:31.919754 +0200 info  main: #173 C MITPROHB rx msg h 964,-270,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:19:23.366267 +0200 info  main: #173 C MITPROHB rx msg h 964,-289,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:21:57.344609 +0200 info  main: #173 C MITPROHB rx msg h 964,-299,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:23:40.082406 +0200 info  main: #31 C MITPROHB rx msg h 964,-1027,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> 2019-09-06 22:25:58.061883 +0200 info  main: #31 C MITPROHB rx msg h 964,-1040,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>> This shows the ticker was only run 299 times from 22:07:48 to 22:21:57.
>>>> After 22:21:57 the workaround was triggered and did a reconnect. Apparently during that network reinitialization of 103 seconds, the per second ticker was
>>>> run 628 times.
>>>> That can't be catching up on the event queue, as that queue has only 20 slots. So something strange is going on here.
>>>> Any ideas?
>>>> Regards,
>>>> Michael
>>>> Am 06.09.19 um 08:04 schrieb Michael Balzer:
>>>>> Mark & anyone else running a V2 server,
>>>>> as most cars don't send history records, this also needs the change to the server I just pushed, i.e. server version 2.4.2.
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commits/master
>>>>> Regards,
>>>>> Michael
>>>>> Am 05.09.19 um 19:55 schrieb Michael Balzer:
>>>>>> I've pushed the nasty workaround: the v2 server checks for no RX over 15 minutes, then restarts the network (wifi & modem) as configured for autostart.
>>>>>> Rolled out on my server in edge as 3.2.002-237-ge075f655.
>>>>>> Please test.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 05.09.19 um 01:58 schrieb Mark Webb-Johnson:
>>>>>>>> Mark, you can check your server logs for history messages with ridiculous time offsets:
>>>>>>>>     [sddexter at ns27 server]$ cat log-20190903 | egrep "rx msg h [0-9]+,-[0-9]{4}" | wc -l
>>>>>>>>     455283
>>>>>>> I checked my logs and see 12 vehicles showing this. But, 2 only show this for a debugcrash log (which is expected, I guess, if the time is not synced at
>>>>>>> report time). I’ve got 4 cars with the offset > 10,000.
>>>>>>> Regards, Mark.
>>>>>>>> On 4 Sep 2019, at 4:45 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>> Everyone,
>>>>>>>> I've pushed a change that needs some testing.
>>>>>>>> I had the issue myself now parking at a certain distance from my garage wifi AP, i.e. on the edge of "in", after wifi had been disconnected for some
>>>>>>>> hours, and with the module still connected via modem. The wifi blob had been trying to connect to the AP for about two hours.
>>>>>>>> As seen before, the module saw no error, just the server responses and commands stopped coming in. I noticed the default interface was still "st1"
>>>>>>>> despite wifi having been disconnected and modem connected. The DNS was also still configured for my wifi network, and the interface seemed to have an
>>>>>>>> IP address -- but wasn't pingable from the wifi network.
>>>>>>>> A power cycle of the modem solved the issue without reboot. So the cause may be in the modem/ppp subsystem, or it may be related (in some weird way) to
>>>>>>>> the default interface / DNS setup.
>>>>>>>> More tests showed the default interface again/still got set by the wifi blob itself at some point, overriding our modem prioritization. The events we
>>>>>>>> didn't handle up to now were "sta.connected" and "sta.lostip", so I added these, and the bug didn't show up again since then. That doesn't mean
>>>>>>>> anything, so we need to test this.
>>>>>>>> The default interface really shouldn't affect inbound packet routing of an established connection, but there always may be strange bugs lurking in
>>>>>>>> those libs.
>>>>>>>> The change also reimplements the wifi signal strength reading, as the tests also showed that still wasn't working well using the CSI callback. It now
>>>>>>>> seems to be much more reliable.
>>>>>>>> Please test & report. The single module will be hard to test, as the bug isn't reproducable easily, but you can still try if wifi / modem transitions
>>>>>>>> work well.
>>>>>>>>     455283
>>>>>>>> The bug now severely affects the V2 server performance, as the server is single threaded and doesn't scale very well to this kind of bulk data bursts,
>>>>>>>> especially when coming from multiple modules in parallel. So we really need to solve this now. Slow reactions or connection drops from my server lately
>>>>>>>> have been due to this bug. If this change doesn't solve it, we'll need to add some reboot trigger on "too many server v2 notification retransmissions"
>>>>>>>> -- or maybe a modem power cycle will do, that wouldn't discard the data.
>>>>>>>> Thanks,
>>>>>>>> Michael
>>>>>>>> Am 03.09.19 um 07:46 schrieb Mark Webb-Johnson:
>>>>>>>>> No problem. We can hold. I won’t commit anything for the next few days (and agree to hold-off on Markos’s pull). Let me know when you are ready.
>>>>>>>>> Regards, Mark.
>>>>>>>>>> On 3 Sep 2019, at 1:58 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>>>>>> Mark, please wait.
>>>>>>>>>> I may just have found the cause for issue #241, or at least something I need to investigate before releasing.
>>>>>>>>>> I need to dig into my logs first, and try something.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 02.09.19 um 12:23 schrieb Michael Balzer:
>>>>>>>>>>> Nothing open from my side at the moment.
>>>>>>>>>>> I haven't had the time to look in to Markos pull request, but from a first check also think that's going too deep to be included in this release.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 02.09.19 um 04:15 schrieb Mark Webb-Johnson:
>>>>>>>>>>>> I think it is well past time for a 3.2.003 release. Things seems table in edge (although some things only partially implemented).
>>>>>>>>>>>> Anything people want to include at the last minute, or can we go ahead and build?
>>>>>>>>>>>> Regards, Mark.
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190913/68f36313/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190913/68f36313/attachment-0004.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190913/68f36313/attachment-0005.png>
