Wed Sep 4 13:04:54 HKT 2019
Michael,
I have not built the OVMS software in a while, so I need to update to
the current esp-idf, which I have done by the steps you prescribed a
while back.  But you also recommend the -93 toolchain; I currently
have -80 installed.  Where can I find the -93 tarball?  Google didn't
answer that question.
On Tue, 3 Sep 2019, Michael Balzer wrote:
> Everyone,
> I've pushed a change that needs some testing.
> I had the issue myself now parking at a certain distance from my garage wifi AP, i.e. on the edge of "in", after wifi had been disconnected for some hours, and
> with the module still connected via modem. The wifi blob had been trying to connect to the AP for about two hours.
> As seen before, the module saw no error, just the server responses and commands stopped coming in. I noticed the default interface was still "st1" despite wifi
> having been disconnected and modem connected. The DNS was also still configured for my wifi network, and the interface seemed to have an IP address -- but
> wasn't pingable from the wifi network.
> A power cycle of the modem solved the issue without reboot. So the cause may be in the modem/ppp subsystem, or it may be related (in some weird way) to the
> default interface / DNS setup.
> More tests showed the default interface again/still got set by the wifi blob itself at some point, overriding our modem prioritization. The events we didn't
> handle up to now were "sta.connected" and "sta.lostip", so I added these, and the bug didn't show up again since then. That doesn't mean anything, so we need to
> test this.
> The default interface really shouldn't affect inbound packet routing of an established connection, but there always may be strange bugs lurking in those libs.
> The change also reimplements the wifi signal strength reading, as the tests also showed that still wasn't working well using the CSI callback. It now seems to
> be much more reliable.
> Please test & report. The single module will be hard to test, as the bug isn't reproducable easily, but you can still try if wifi / modem transitions work well.
> Mark, you can check your server logs for history messages with ridiculous time offsets:
>     [sddexter at ns27 server]$ cat log-20190903 | egrep "rx msg h [0-9]+,-[0-9]{4}" | wc -l
>     455283
> The bug now severely affects the V2 server performance, as the server is single threaded and doesn't scale very well to this kind of bulk data bursts,
> especially when coming from multiple modules in parallel. So we really need to solve this now. Slow reactions or connection drops from my server lately have
> been due to this bug. If this change doesn't solve it, we'll need to add some reboot trigger on "too many server v2 notification retransmissions" -- or maybe a
> modem power cycle will do, that wouldn't discard the data.
> Thanks,
> Am 03.09.19 um 07:46 schrieb Mark Webb-Johnson:
> > No problem. We can hold. I won't commit anything for the next few days (and agree to hold-off on Markos's pull). Let me know when you are ready.
> > Regards, Mark.
> >> On 3 Sep 2019, at 1:58 AM, Michael Balzer <dexter at expeedo.de> wrote:
> >> Mark, please wait.
> >> I may just have found the cause for issue #241, or at least something I need to investigate before releasing.
> >> I need to dig into my logs first, and try something.
> >> Regards,
> >> Michael
> >> Am 02.09.19 um 12:23 schrieb Michael Balzer:
> >>> Nothing open from my side at the moment.
> >>> I haven't had the time to look in to Markos pull request, but from a first check also think that's going too deep to be included in this release.
> >>> Regards,
> >>> Michael
> >>> Am 02.09.19 um 04:15 schrieb Mark Webb-Johnson:
> >>>> I think it is well past time for a 3.2.003 release. Things seems table in edge (although some things only partially implemented).
> >>>> Anything people want to include at the last minute, or can we go ahead and build?
> >>>> Regards, Mark.
> >>>> _______________________________________________
> >>>> OvmsDev mailing list
> >>>> OvmsDev at lists.openvehicles.com
> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
