Bernd Geistert
b_ghosti at gmx.de
Wed Sep 25 02:21:13 HKT 2019
IMHO, currently:
- in MAIN is 3.2.002
- in EAP is 3.2.003
- in EDGE is 3.2.005-1-g7f86e9c
Am 19.09.2019 um 10:22 schrieb Mark Webb-Johnson:
> OK, I’ve built:
> 2019-09-19 MWJ 3.2.005 OTA release
> - Default module/debug.tasks to FALSE
> Users that volunteer to submit tasks debug historical data to
> the Open Vehicles
> project, should (with appreciation) set:
> config set module debug.tasks yes
> This will be transmit approximately 700MB of data a month (over
> cellular/wifi).
> 2019-09-19 MWJ 3.2.004 OTA release
> - Skipped for Chinese superstitous reasons
> In EAP now, and I will announce.
>> On 19 Sep 2019, at 3:34 PM, Michael Balzer <dexter at expeedo.de
>> Correct.
>> Am 19.09.19 um 09:29 schrieb Mark Webb-Johnson:
>>> I’m just worried about the users who don’t know about this new
>>> feature. When they deploy this version, they suddenly start sending
>>> 6MB of data a month up to us.
>>> I think the ‘fix’ is just to change ovms_module.c:
>>> MyConfig.GetParamValueBool("module", "debug.tasks", true)
>>> to
>>> MyConfig.GetParamValueBool("module", "debug.tasks", false)
>>> That would then only submit these logs for those that explicitly
>>> turn it on?
>>>> On 19 Sep 2019, at 3:23 PM, Michael Balzer <dexter at expeedo.de
>>>> Sorry, I didn't think about this being an issue elsewhere -- german
>>>> data plans typically start at minimum 100 MB/month flat (that's my
>>>> current plan at 3 € / month).
>>>> No need for a new release, it can be turned off OTA by issueing
>>>> config set module debug.tasks no
>>>> Regards,
>>>> Michael
>>>> Am 19.09.19 um 09:08 schrieb Mark Webb-Johnson:
>>>>> Yep:
>>>>> 758 bytes * (86400 / 300) * 30 = 6.5MB/month
>>>>> That is going over data (not SD). Presumably cellular data for a
>>>>> large portion of the time.
>>>>> I think we need to default this to OFF, and make a 3.2.004 to
>>>>> avoid this becoming an issue.
>>>>> Regards, Mark.
>>>>>> On 19 Sep 2019, at 2:04 PM, Stephen Casner <casner at acm.org
>>>>>> <mailto:casner at acm.org>> wrote:
>>>>>> That's 6.55MB/month, unless you have unusually short months! :-)
>>>>>> In what space is that data stored? A log written to SD? That's not
>>>>>> likely to fill up the SD card too fast, but what happens if no SD
>>>>>> card
>>>>>> is installed?
>>>>>> -- Steve
>>>>>> On Thu, 19 Sep 2019, Mark Webb-Johnson wrote:
>>>>>>>> To enable CPU usage statistics, apply the changes to sdkconfig
>>>>>>>> included.
>>>>>>>> New history record:
>>>>>>>> - "*-OVM-DebugTasks" v1: <taskcnt,totaltime> + per task:
>>>>>>>> <tasknum,name,state,stack_now,stack_max,stack_total,
>>>>>>>> heap_total,heap_32bit,heap_spi,runtime>
>>>>>>>> Note: CPU core use percentage = runtime / totaltime
>>>>>>> I’ve just noticed that this is enabled by default now (my
>>>>>>> production build has the sdkconfig updated, as per defaults).
>>>>>>> I am seeing 758 bytes of history record, every 5 minutes. About
>>>>>>> 218KB/day, or 654KB/month.
>>>>>>> Should this be opt-in?
>>>>>>> Regards, Mark.
>>>>>>>> On 8 Sep 2019, at 5:43 PM, Michael Balzer <dexter at expeedo.de
>>>>>>>> I've pushed some modifications and improvements to (hopefully)
>>>>>>>> fix the timer issue or at least be able to debug it.
>>>>>>>> Some sdkconfig changes are necessary.
>>>>>>>> The build including these updates is on my edge release as
>>>>>>>> 3.2.002-258-g20ae554b.
>>>>>>>> Btw: the network restart strategy seems to mitigate issue #241;
>>>>>>>> I've seen a major drop on record repetitions on my server since
>>>>>>>> the rollout.
>>>>>>>> commit 99e4e48bdd40b7004c0976f51aba9e3da4ecab53
>>>>>>>> Module: add per task CPU usage statistics, add task stats
>>>>>>>> history records
>>>>>>>> included. The CPU usage shown by the commands is calculated
>>>>>>>> against
>>>>>>>> the last task status retrieved (or system boot).
>>>>>>>> Command changes:
>>>>>>>> - "module tasks" -- added CPU (core) usage in percent per task
>>>>>>>> New command:
>>>>>>>> - "module tasks data" -- output task stats in history record
>>>>>>>> form
>>>>>>>> New config:
>>>>>>>> - [module] debug.tasks -- yes (default) = send task stats
>>>>>>>> every 5 minutes
>>>>>>>> New history record:
>>>>>>>> commit 950172c216a72beb4da0bc7a40a46995a6105955
>>>>>>>> Build config: default timer service task priority raised to 20
>>>>>>>> Background: the FreeRTOS timer service shall only be used
>>>>>>>> for very
>>>>>>>> short and non-blocking jobs. We delegate event processing
>>>>>>>> to our
>>>>>>>> events task, anything else in timers needs to run with high
>>>>>>>> priority.
>>>>>>>> commit 31ac19d187480046c16356b80668de45cacbb83d
>>>>>>>> DukTape: add build config for task priority, default lowered
>>>>>>>> to 3
>>>>>>>> Background: the DukTape garbage collector shall run on lower
>>>>>>>> priority than tasks like SIMCOM & events
>>>>>>>> commit e0a44791fbcfb5a4e4cad24c9d1163b76e637b4f
>>>>>>>> Server V2: use esp_log_timestamp for timeout detection,
>>>>>>>> add timeout config, limit data records & size per second
>>>>>>>> New config:
>>>>>>>> - [server.v2] timeout.rx -- timeout in seconds, default 960
>>>>>>>> commit 684a4ce9525175a910040f0d1ca82ac212fbf5de
>>>>>>>> Notify: use esp_log_timestamp for creation time instead of
>>>>>>>> monotonictime
>>>>>>>> to harden against timer service starvation / ticker event
>>>>>>>> drops
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 07.09.19 um 10:55 schrieb Michael Balzer:
>>>>>>>>> I think the RTOS timer service task starves. It's running on
>>>>>>>>> core 0 with priority 1.
>>>>>>>>> Taks on core 0 sorted by priority:
>>>>>>>>> Number of Tasks = 20 Stack: Now Max Total Heap
>>>>>>>>> 32-bit SPIRAM C# PRI
>>>>>>>>> 3FFC84A8 6 Blk ipc0 388 500 1024 7788
>>>>>>>>> 0 0 0 24
>>>>>>>>> 3FFC77F0 5 Blk OVMS CanRx 428 428 2048 3052
>>>>>>>>> 0 31844 0 23
>>>>>>>>> 3FFAFBF4 1 Blk esp_timer 400 656 4096 35928
>>>>>>>>> 644 25804 0 22
>>>>>>>>> 3FFD3240 19 Blk wifi 460 2716 3584 43720
>>>>>>>>> 0 20 0 22
>>>>>>>>> 3FFC03C4 2 Blk eventTask 448 1984 4608 104
>>>>>>>>> 0 0 0 20
>>>>>>>>> 3FFC8F14 17 Blk tiT 500 2308 3072 6552
>>>>>>>>> 0 0 * 18
>>>>>>>>> 3FFE14F0 26 Blk OVMS COrx 456 456 4096 0
>>>>>>>>> 0 0 0 7
>>>>>>>>> 3FFE19D4 27 Blk OVMS COwrk 476 476 3072 0
>>>>>>>>> 0 0 0 7
>>>>>>>>> 3FFCBC34 12 Blk Tmr Svc 352 928 3072 88
>>>>>>>>> 0 0 0 1
>>>>>>>>> 3FFE7708 23 Blk mdns 468 1396 4096 108
>>>>>>>>> 0 0 0 1
>>>>>>>>> I don't think it's our CanRx, as that only fetches and queues
>>>>>>>>> CAN frames, the actual work is done by the listeners. The CO
>>>>>>>>> tasks only run for CANopen jobs, which are few for normal
>>>>>>>>> operation.
>>>>>>>>> That leaves the system tasks, with main suspect -once again-
>>>>>>>>> the wifi blob.
>>>>>>>>> We need to know how much CPU time the tasks actually use now.
>>>>>>>>> I think I saw some option for this in the FreeRTOS config.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 06.09.19 um 23:15 schrieb Michael Balzer:
>>>>>>>>>> The workaround is based on the monotonictime being updated
>>>>>>>>>> per second, as do the history record offsets.
>>>>>>>>>> Apparently, that mechanism doesn't work reliably. That may be
>>>>>>>>>> an indicator for some bigger underlying issue.
>>>>>>>>>> Example log excerpt:
>>>>>>>>>> 2019-09-06 22:07:48.126919 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h 964,0,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:03.089031 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-10,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:05.041574 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-20,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:05.052644 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-30,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:05.063617 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-49,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:05.077527 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-59,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:05.193775 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-70,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:13.190645 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-80,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:22.077994 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-90,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:09:54.590300 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-109,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:11:10.127054 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-119,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:11:16.794200 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-130,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:11:22.455652 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-140,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:12:49.423412 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-150,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:12:49.442096 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-169,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:12:49.461941 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-179,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:14:39.828133 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-190,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:14:39.858144 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-200,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:14:52.020319 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-210,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:14:54.452637 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-229,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:15:12.613935 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-239,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:15:35.223845 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-250,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:16:09.255059 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-260,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:17:31.919754 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-270,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:19:23.366267 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-289,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:21:57.344609 +0200 info main: #173 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-299,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:23:40.082406 +0200 info main: #31 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-1027,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> 2019-09-06 22:25:58.061883 +0200 info main: #31 C MITPROHB
>>>>>>>>>> rx msg h
>>>>>>>>>> 964,-1040,RT-BAT-C,5,86400,2,1,3830,3795,3830,-10,25,25,25,0
>>>>>>>>>> This shows the ticker was only run 299 times from 22:07:48 to
>>>>>>>>>> 22:21:57.
>>>>>>>>>> After 22:21:57 the workaround was triggered and did a
>>>>>>>>>> reconnect. Apparently during that network reinitialization of
>>>>>>>>>> 103 seconds, the per second ticker was run 628 times.
>>>>>>>>>> That can't be catching up on the event queue, as that queue
>>>>>>>>>> has only 20 slots. So something strange is going on here.
>>>>>>>>>> Any ideas?
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 06.09.19 um 08:04 schrieb Michael Balzer:
>>>>>>>>>>> Mark & anyone else running a V2 server,
>>>>>>>>>>> as most cars don't send history records, this also needs the
>>>>>>>>>>> change to the server I just pushed, i.e. server version 2.4.2.
>>>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commits/master
>>>>>>>>>>> <https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commits/master>
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 05.09.19 um 19:55 schrieb Michael Balzer:
>>>>>>>>>>>> I've pushed the nasty workaround: the v2 server checks for
>>>>>>>>>>>> no RX over 15 minutes, then restarts the network (wifi &
>>>>>>>>>>>> modem) as configured for autostart.
>>>>>>>>>>>> Rolled out on my server in edge as 3.2.002-237-ge075f655.
>>>>>>>>>>>> Please test.
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>>> Am 05.09.19 um 01:58 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>> Mark, you can check your server logs for history messages
>>>>>>>>>>>>>> with ridiculous time offsets:
>>>>>>>>>>>>>> [sddexter at ns27 server]$ cat log-20190903 | egrep "rx msg
>>>>>>>>>>>>>> h [0-9]+,-[0-9]{4}" | wc -l
>>>>>>>>>>>>>> 455283
>>>>>>>>>>>>> I checked my logs and see 12 vehicles showing this. But, 2
>>>>>>>>>>>>> only show this for a debugcrash log (which is expected, I
>>>>>>>>>>>>> guess, if the time is not synced at report time). I’ve got
>>>>>>>>>>>>> 4 cars with the offset > 10,000.
>>>>>>>>>>>>> Regards, Mark.
>>>>>>>>>>>>>> On 4 Sep 2019, at 4:45 AM, Michael Balzer
>>>>>>>>>>>>>> <dexter at expeedo.de <mailto:dexter at expeedo.de>
>>>>>>>>>>>>>> Everyone,
>>>>>>>>>>>>>> I've pushed a change that needs some testing.
>>>>>>>>>>>>>> I had the issue myself now parking at a certain distance
>>>>>>>>>>>>>> from my garage wifi AP, i.e. on the edge of "in", after
>>>>>>>>>>>>>> wifi had been disconnected for some hours, and with the
>>>>>>>>>>>>>> module still connected via modem. The wifi blob had been
>>>>>>>>>>>>>> trying to connect to the AP for about two hours.
>>>>>>>>>>>>>> As seen before, the module saw no error, just the server
>>>>>>>>>>>>>> responses and commands stopped coming in. I noticed the
>>>>>>>>>>>>>> default interface was still "st1" despite wifi having
>>>>>>>>>>>>>> been disconnected and modem connected. The DNS was also
>>>>>>>>>>>>>> still configured for my wifi network, and the interface
>>>>>>>>>>>>>> seemed to have an IP address -- but wasn't pingable from
>>>>>>>>>>>>>> the wifi network.
>>>>>>>>>>>>>> A power cycle of the modem solved the issue without
>>>>>>>>>>>>>> reboot. So the cause may be in the modem/ppp subsystem,
>>>>>>>>>>>>>> or it may be related (in some weird way) to the default
>>>>>>>>>>>>>> interface / DNS setup.
>>>>>>>>>>>>>> More tests showed the default interface again/still got
>>>>>>>>>>>>>> set by the wifi blob itself at some point, overriding our
>>>>>>>>>>>>>> modem prioritization. The events we didn't handle up to
>>>>>>>>>>>>>> now were "sta.connected" and "sta.lostip", so I added
>>>>>>>>>>>>>> these, and the bug didn't show up again since then. That
>>>>>>>>>>>>>> doesn't mean anything, so we need to test this.
>>>>>>>>>>>>>> The default interface really shouldn't affect inbound
>>>>>>>>>>>>>> packet routing of an established connection, but there
>>>>>>>>>>>>>> always may be strange bugs lurking in those libs.
>>>>>>>>>>>>>> The change also reimplements the wifi signal strength
>>>>>>>>>>>>>> reading, as the tests also showed that still wasn't
>>>>>>>>>>>>>> working well using the CSI callback. It now seems to be
>>>>>>>>>>>>>> much more reliable.
>>>>>>>>>>>>>> Please test & report. The single module will be hard to
>>>>>>>>>>>>>> test, as the bug isn't reproducable easily, but you can
>>>>>>>>>>>>>> still try if wifi / modem transitions work well.
>>>>>>>>>>>>>> 455283
>>>>>>>>>>>>>> The bug now severely affects the V2 server performance,
>>>>>>>>>>>>>> as the server is single threaded and doesn't scale very
>>>>>>>>>>>>>> well to this kind of bulk data bursts, especially when
>>>>>>>>>>>>>> coming from multiple modules in parallel. So we really
>>>>>>>>>>>>>> need to solve this now. Slow reactions or connection
>>>>>>>>>>>>>> drops from my server lately have been due to this bug. If
>>>>>>>>>>>>>> this change doesn't solve it, we'll need to add some
>>>>>>>>>>>>>> reboot trigger on "too many server v2 notification
>>>>>>>>>>>>>> retransmissions" -- or maybe a modem power cycle will do,
>>>>>>>>>>>>>> that wouldn't discard the data.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>> Am 03.09.19 um 07:46 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>>> No problem. We can hold. I won’t commit anything for the
>>>>>>>>>>>>>>> next few days (and agree to hold-off on Markos’s pull).
>>>>>>>>>>>>>>> Let me know when you are ready.
>>>>>>>>>>>>>>> Regards, Mark.
>>>>>>>>>>>>>>>> On 3 Sep 2019, at 1:58 AM, Michael Balzer
>>>>>>>>>>>>>>>> <dexter at expeedo.de <mailto:dexter at expeedo.de>>
>>>>>>>>>>>>>>>> <mailto:dexter at expeedo.de> wrote:
>>>>>>>>>>>>>>>> Mark, please wait.
>>>>>>>>>>>>>>>> I may just have found the cause for issue #241, or at
>>>>>>>>>>>>>>>> least something I need to investigate before releasing.
>>>>>>>>>>>>>>>> I need to dig into my logs first, and try something.
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>>>> Am 02.09.19 um 12:23 schrieb Michael Balzer:
>>>>>>>>>>>>>>>>> Nothing open from my side at the moment.
>>>>>>>>>>>>>>>>> I haven't had the time to look in to Markos pull
>>>>>>>>>>>>>>>>> request, but from a first check also think that's
>>>>>>>>>>>>>>>>> going too deep to be included in this release.
>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>>>>> Am 02.09.19 um 04:15 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>>>>>> I think it is well past time for a 3.2.003 release.
>>>>>>>>>>>>>>>>>> Things seems table in edge (although some things only
>>>>>>>>>>>>>>>>>> partially implemented).
>>>>>>>>>>>>>>>>>> Anything people want to include at the last minute,
>>>>>>>>>>>>>>>>>> or can we go ahead and build?
>>>>>>>>>>>>>>>>>> Regards, Mark.
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190924/42ac5a04/attachment-0001.html>
