[Ovmsdev] Roadster: Some alerts not showing up
Thu Oct 31 18:25:06 HKT 2019
A suggestion: use error notifications for visible/real errors, and a history record table for all errors/debug messages?
Am 31.10.19 um 09:57 schrieb Mark Webb-Johnson:
> Chip,
> Good suggestion, But unfortunately we haven’t been able to find that signal on the can bus. I suspect it is never sent, but just entered and
> stored in the VDS; as the vms sends debug alerts regardless of the setting. The alert message strings are in the vds firmware, and vms only
> sends codes.
> To do this properly would require ovms doing what the vds does - have an alert code -> debug/user,message table and do the conversion and
> filtering there (not in the server). But that is quite a bit of code flash memory.
> Regards, Mark
>> On 31 Oct 2019, at 4:50 PM, Chip Cangialose <chip at cangmag.com> wrote:
>> Watching this thread with some interest as I, like Greg, would like to see the “Debug” alerts over OVMS. I would note that if the goal is to
>> have OVMS show what the VDS shows, if you have the Roadster set to “Show Debug”, then OVMS _will not_ show what VDS shows. Is it possible to
>> track the status of “Debug reporting to VDS” in the car, and have the OVMS server relay accordingly?
>> Thanks, and apologies for jumping in.
>> Chip
>> Sent from my tablet
>> On Thu, Oct 31, 2019 at 1:30 AM +0100, "Mark Webb-Johnson" <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> The server doesn’t have any per-vehicle configuration (other than authentication), so not sure how this could be easily done server side.
>> A kludge might be to pickup the notification event in a javascript on the module, and then raise a new different textual event for
>> specific IDs - but not sure if the vehicle module javascript framework gets enough about the raised notification in order to do that.
>> An alternate kludge would be to manually list vehicle IDs to be exempted from the DMC policy in the ovms_server.conf file, and have code
>> to check that in ovms_server.pl.
>> But, that said, I’m not really sure why we would want this. Our goal has always been to mirror what it says on the little VDS in the car,
>> and that doesn’t show these debug-only alerts. The solution we have is not perfect, but it does avoid the worst of them. I have received
>> so many support questions and concerns from roadster users of OVMS asking about these over the years - Tesla is aware that they false
>> positive so labelled them as debug-only, so why would we want to bombard the user with these alerts every time he drives/charges the car?
>>> On 31 Oct 2019, at 7:39 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Bummer.
>>> Can we make this configurable? While I understand that debug messages aren't intended to be seen by the user, in the 10 years since
>>> these cars launched we have come to know a lot more about some of the, um, "quirks" in their design. These alerts can be important!
>>> Greg
>>> Mark Webb-Johnson wrote:
>>>> Greg,
>>>> Yes, this change to the server code:
>>>> * bcc02c27 Ignore DMC push alert messages
>>>> That won’t notify debug-only messages, but will still continue to notify the user-visible ones (to better mimick the behaviour in the
>>>> car itself). Including, for the roadster:
>>>> * 1144=DMC: Powertrain Problem Service Required
>>>> * 1146=DMC: Motor Fan Problem
>>>> Regards, Mark.
>>>>> On 31 Oct 2019, at 7:01 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>> Hi folks (Mark, probably),
>>>>> Interesting... My Tesla Roadster has been having trouble with its PEM
>>>>> fan, causing a bunch of 1146 Alerts to be generated while driving and/or
>>>>> charging. I've been monitoring the situation via OVMSv3.
>>>>> The alerts suddenly stopped a bit over a week ago. Other events
>>>>> continue to be received (charge start, stop, key in / door open, etc.),
>>>>> but not the 1146's. I do a monthly download of the car logs, and to my
>>>>> surprise (and disappointment), the 1146s are still happening.
>>>>> Was there a change to the plumbing somewhere such that these diagnostic
>>>>> alerts (perhaps versus user-visible events) are now being filtered out?
>>>>> Thanks,
>>>>> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191031/48ad6d50/attachment.htm>
