[Ovmsdev] New Joiner: Jaunius
Thu Oct 31 11:52:54 HKT 2019
> I think we will create a general place / path scheme for plugins. Mark already suggested that for web plugins some time ago, but it seems it won't be unusual for plugins to consist of a backend and frontend part.
How about a ‘PluginStore’? We could put them in the source tree, and then link that from the github checkout used to do the automated builds. They would then be available under http(s)://api.openvehicles.com/firmware/ <http://api.openvehicles.com/firmware/>… The server side would be trivial. If we had an index with plugin name, version, and description, we could have a simple interface on the module to download/update.
That might drive plugin development and sharing, but also incentivise improving the plugin architecture itself.
Opinions?
Mark.
> On 30 Oct 2019, at 7:39 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Welcome Jaunius :)
> Sounds like some nice extra features for the Leaf, especially for cold climates. As the Leaf has some degradation issues with hot climates as well, maybe a battery cooling assist could also be valuable. I still don't understand why Nissan -again- decided against an active battery temperature management.
> Am 29.10.19 um 19:59 schrieb Jaunius Kapkan:
>> Hi,
>> Great! Figured it's time to introduce myself as initially suggested by Michael.
>> My name is Jaunius Kapkan.
>> I have 2013 leaf for over 3 years now with 107k km and ~70 SOH.
>> I am familiar with low level networking and dissecting packets on wireshark. But don’t have much experience with CAN communication. I work with Bash, Python, Javascript, HTML daily, but have no problems using other languages when needed.
>> My goal is to make some cool stuff for my Leaf and if possible make it compatable for use with other cars. All during my spare time.
>> Current Projects:
>> Local Climate Control Timer.
>> Story:
>> Built-in Timer only works if connected to the charger and only has 2 timers available.
>> Features:
>> Unlimited amount of timers (as long as RAM allows it)
>> Unrestricted CC operation time
>> Ability to set all timers in GUI by implementing it as plugin
>> Status:
>> Backend module done. Now Testing & working onthe frontend.
>> Heating Assist
>> Story:
>> My PTC Heater fried so I have bought a 2x 200W 12V PTCs for 30 EUR in total (meanwhile  original replacement unit is 400-800 EUR) and put them in the old heater's place. I connected them trough relay, but did not want to control them manually. So I have wired the relay switch to ext12v power output of the OVMS.
>> Features:
>> Each 5 seconds script checks if the heater is on and if so it will engage the ext12v power and vice-versa.
>> Still thinking if GUI is needed for this, very limited usage for others.
>> Status:
>> Initial module done. Now beta testing.
>> Future Development:
>> One of the first things after these two is to make smart charge JS module/plugin to charge battery to specific % for specific departure time. The goal here is to have the battery sitting at high SOC the least possible amount of time.
>> Once I believe it's safe ENOUGH for others to use these plugins/modules I will make them open source.
>> Meanwhile you can follow me on twitter (boring..) https://twitter.com/mjkapkan <https://twitter.com/mjkapkan>
>> And also I just created a youtube channel where I will be posting videos of my experience with EV & Solar projects.
>> https://www.youtube.com/channel/UCTPA0HdTCBmzwpxNtNaY4tg <https://www.youtube.com/channel/UCTPA0HdTCBmzwpxNtNaY4tg>
>> PS: My initial plan was to work on the iOS app, but it seems that one needs to have a MAC for that (and I don't). I am just a Linux Lover that happens to own an iPhone :).
>> Feel free to reach out!
>> Warmly,
>> Jaunius
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191031/27e3ecd5/attachment.htm>
