[Ovmsdev] OVMS V3 power consumption readings
Wed Oct 23 21:31:16 HKT 2019
Glyn,
Powered exclusively by ext12v, @12v, I get:
Wifi off/sleeping: 25mA
Wifi only: 49mA
Wifi + 3G: 85mA
Powered exclusively by USB, @5v, I get:
Wifi off/sleeping: 46mA
Wifi only: 104mA
Wifi + 3G: 180mA
Note that in areas of low signal, the 3G power consumption can be higher. Similarly, if GPS is enabled that can have an affect as well. I’ve never seen it go over about 220mA (and even that was just for short bursts).
If I power it from both USB and 12V simultaneously, I get:
Wifi off/sleeping: 8mA (USB 5v) and 19mA (ext 12v)
Deep sleep: 8mA (USB 5v) and <1mA (ext 12v)
(The 8mA is mostly from the CP2102 which is powered off when not in use)
> On 22 Oct 2019, at 2:41 AM, Glyn Hudson <glyn.hudson at openenergymonitor.org> wrote:
> I've just measured the power consumption of the OVMS V3 module using a
> bench power supply set to exactly 12.0V.
> OVMS consumed:
> 60mA = 0.72W with WiFi on (AP active) and GSM/GPS modem off
> 100mA = 1.2W with everything switched on.
> This is less than I was expecting, I would take weeks for OVMS to
> drain a healthy lead acid battery.
> All the best,
> Glyn Hudson
> +44(0)1248672607
> https://openenergymonitor.org
> https://zerocarbonadventures.co.uk
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191023/59137e1b/attachment.htm>
