[Ovmsdev] Error compiling 3.2.005
Timo Penttilä
timo.penttila at codetap.se
Tue Oct 1 17:59:56 HKT 2019
Solved it.
It was not enough to update esp-idf.
Had to clone a fresh one.
Regards
TIMO PENTTILÄ
Från: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> För Timo Penttilä
Skickat: den 30 september 2019 20:53
Till: ovmsdev at lists.openvehicles.com
Ämne: [Ovmsdev] Error compiling 3.2.005
Hi
I get this error when trying to compile 3.2.005
I have done everything in the developer guide.
$ make app
CXX build/can/src/canlog_tcpserver.o
In file included from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.h:34:0,
from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_peripherals.h:67,
from D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/canlog_tcpserver.cpp:37:
D:/Users/Tipe/msys32/home/Tipe/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:43:30: fatal error: netif/ppp/pppapi.h: No such file or directory
compilation terminated.
make[1]: *** [/home/Tipe/esp/esp-idf/make/component_wrapper.mk:286: src/canlog_tcpserver.o] Fel 1
make: *** [D:/Users/Tipe/msys32/home/Tipe/esp/esp-idf/make/project.mk:468: component-can-build] Fel 2
Regards
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191001/659021a9/attachment.htm>
