[Ovmsdev] New Joiner: Jaunius
Jaunius Kapkan jaunius at gmx.com
Wed Oct 30 22:02:34 HKT 2019
Agreed!
Btw, managed to make my first build & flash yesterday (added some missing climate control metrics under xnl). As it is less complicated than I tought I plan to continue and add everythig that has been discovered so far in regards to climate control for the Leaf. You can track progress here: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/281
Jaunius
> Sent: Wednesday, October 30, 2019 at 12:39 PM
> From: "Michael Balzer" <dexter at expeedo.de>
> To: ovmsdev at lists.openvehicles.com
> Subject: Re: [Ovmsdev] New Joiner: Jaunius
> Welcome Jaunius :)
> Sounds like some nice extra features for the Leaf, especially for cold climates. As the Leaf has some degradation issues with hot climates as
> well, maybe a battery cooling assist could also be valuable. I still don't understand why Nissan -again- decided against an active battery
> temperature management.
> I think we will create a general place / path scheme for plugins. Mark already suggested that for web plugins some time ago, but it seems it
> won't be unusual for plugins to consist of a backend and frontend part.
> Am 29.10.19 um 19:59 schrieb Jaunius Kapkan:
> > Hi,
> > Great! Figured it's time to introduce myself as initially suggested by Michael.
> > My name is Jaunius Kapkan.
> > I have 2013 leaf for over 3 years now with 107k km and ~70 SOH.
> > I am familiar with low level networking and dissecting packets on wireshark. But don’t have much experience with CAN communication. I work
> > with Bash, Python, Javascript, HTML daily, but have no problems using other languages when needed.
> > My goal is to make some cool stuff for my Leaf and if possible make it compatable for use with other cars. All during my spare time.
> > Current Projects:
> >   * *Local Climate Control Timer. *
> >       o Story:
> >           + Built-in Timer only works if connected to the charger and only has 2 timers available.
> >       o Features:
> >           + Unlimited amount of timers (as long as RAM allows it)
> >           + Unrestricted CC operation time
> >           + Ability to set all timers in GUI by implementing it as plugin
> >       o Status:
> >           + Backend module done. Now Testing & working onthe frontend.
> >   * *Heating Assist*
> >       o Story:
> >           + My PTC Heater fried so I have bought a 2x 200W 12V PTCs for 30 EUR in total (meanwhile  original replacement unit is 400-800
> >             EUR) and put them in the old heater's place. I connected them trough relay, but did not want to control them manually. So I have
> >             wired the relay switch to ext12v power output of the OVMS.
> >       o Features:
> >           + Each 5 seconds script checks if the heater is on and if so it will engage the ext12v power and vice-versa.
> >           + Still thinking if GUI is needed for this, very limited usage for others.
> >       o Status:
> >           + Initial module done. Now beta testing.
> > Future Development:
> > One of the first things after these two is to make smart charge JS module/plugin to charge battery to specific % for specific departure time.
> > The goal here is to have the battery sitting at high SOC the least possible amount of time.
> > Once I believe it's safe ENOUGH for others to use these plugins/modules I will make them open source.
> > Meanwhile you can follow me on twitter (boring..) https://twitter.com/mjkapkan
> > And also I just created a youtube channel where I will be posting videos of my experience with EV & Solar projects.
> > https://www.youtube.com/channel/UCTPA0HdTCBmzwpxNtNaY4tg
> > PS: My initial plan was to work on the iOS app, but it seems that one needs to have a MAC for that (and I don't). I am just a Linux Lover that
> > happens to own an iPhone :).
> > Feel free to reach out!
> > Warmly,
> > Jaunius
> > OvmsDev mailing list
