[Ovmsdev] Smart ED question
Thomas Heuer egon at heuer-humfeld.de
Mon Oct 28 16:59:29 HKT 2019
The problem was resolved in a private message in the German forum. It was a display error in the iOS app. Now everything works as it should.
> Mark Webb-Johnson <mark at webb-johnson.net> hat am 28. Oktober 2019 um 04:09 geschrieben:
> There is a question that came in to support, regarding Smart ED. Can someone with experience of that car have a look, and help answer?
> > https://www.openvehicles.com/node/2335
> > Battery display in the App I have the smart ED 451. It has a 18 KWh battery and charges very slowly with max 3,7 KW. The display of the battery In the OVMS app is not quite right.- In the green to the left it says 8 KWh. I assume this is the used power from full. So it should be on the other side, as the green area with 70% represents around 13 KWh of power remaining. However, the numbers don’t add up.- to recharge fully I will need over 1 hr. But the app only estimates 16 mins. How can I change that?
> Thanks, Mark.
